Need a couple of FJ40 dimensions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-13-2003, 02:04 PM   #1 (permalink)
76lcforty's Avatar
Member # 13325
I need a couple dimensions before I leave work but I don't have a 40 sitting here to look at, what I need...
What is the inside dimension of the frame width where your rear output for on the transfer case comes out?
The frame height at the same location is 5" correct?
Thanks
Degenerate
76lcforty is offline   Reply With Quote
Old 06-13-2003, 02:24 PM   #2 (permalink)
Member # 1797
Send a message via ICQ to Cruiser Ken
James, you might want to mention what drivetrain you are running since the frame width varies through that section. I'll help ya out.
He's got a 2F, SM420, and 3spd case.
82 FJ45 94 FZJ80
Cruiser Ken is offline   Reply With Quote
Old 06-13-2003, 02:29 PM   #3 (permalink)
76lcforty's Avatar
Member # 13325
Thanks Ken, This is actually for Kevin who is running a 350 with SM420 and 3 speed transfer case. But the frame stays the same until it starts its bend up for the rear axle. It is the lowest part of the frame.
Degenerate
Old 06-13-2003, 02:33 PM   #4 (permalink)
Member # 1797
That's funny cause I just built my skid plate and it goes from the front out put to the rear output and it gets wider the entire way... I'm pretty sure it's tapered in that part of the frame.
82 FJ45 94 FZJ80
Old 06-13-2003, 02:39 PM   #5 (permalink)
76lcforty's Avatar
Member # 13325
Ok your right, there probably is a taper there. I didn't think of that but the height which is what I thought you were refering to should stay the same until it bends up for axle clearance. Sorry man my bad
Degenerate
Old 06-13-2003, 03:54 PM   #6 (permalink)
Member # 12186
I've got a 350 w a 465 and a 3 spd tcase. How close do you think that is?
PISSING OFF THE WHOLE F*CKING PLANET.
ONE POST AT A TIME.
BMAN is offline   Reply With Quote
