3D Fj40 Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-17-2014, 09:39 PM   #1 (permalink)
Bednar's Avatar
Member # 331529
3D Fj40 Build
I figured I'd post my build here since it seems like the mud guys don't like cut up 40s.
The details:
'74 Fj40
6.2 6l80
Atlas
Coilovers
Front radius arms
Rear trailing arms
Vintage air ac
I have a lot of inspiration from builds here on pirate. So I figured I'd throw it up here so Maby someone can get inspired by my junk. I'm building it at a local shop and the guys there are helping coach me thru the build.
MRAP Mall crawler.
My FJ40 build: http://www.pirate4x4.com/forum/toyot...j40-build.html
Bednar is offline   Reply With Quote Quick reply to this message
Old 01-17-2014, 09:54 PM   #2 (permalink)
Member # 64778
Sounds cool, what axles are you planning on running? Why the radius arm over a traditional 3 or 4 link? Post some pics!
Okiyota is offline   Reply With Quote Quick reply to this message
Old 01-17-2014, 09:57 PM   #3 (permalink)
Bednar's Avatar
Member # 331529
I got the truck while I was deployed to Kuwait. Drove it for a month when I got home, then decided to gut it.
MRAP Mall crawler.
Old 01-17-2014, 10:04 PM   #4 (permalink)
Bednar's Avatar
Member # 331529
Once I got it torn down I gave it a good wash and set my motor in.
MRAP Mall crawler.
Old 01-17-2014, 10:06 PM   #5 (permalink)
Bednar's Avatar
Member # 331529
I'm going to run a passenger drop 44 in the front and a 9" in the rear.
I decided to run the radius because my mentor swears by them and makes a wicked set.
MRAP Mall crawler.
Old 01-17-2014, 10:09 PM   #6 (permalink)
Bednar's Avatar
Member # 331529
Once I got my motor mounts done I decided to try my hand at bending some tube. It was rough at first, but I think I'm getting the hang of it. I used an idea I saw on the forum for my front fenders, I tried to maintain factory looking lines.
MRAP Mall crawler.
Old 01-17-2014, 10:13 PM   #7 (permalink)
Bednar's Avatar
Member # 331529
I want to tuck a vintage air compact unit behind the dash, the only way to do that was with a flat firewall. So..... I sliced it out. That brings me to where I am today.
MRAP Mall crawler.
Old 01-17-2014, 10:20 PM   #8 (permalink)
Bednar's Avatar
Member # 331529
MRAP Mall crawler.
Old 01-18-2014, 09:40 PM   #9 (permalink)
Member # 12567
Send a message via AIM to ChevotaSS
sounds like a great parts list. what do you plan on doing with the cruiser when its done? if your planning on any serious wheeling I would upgrade those axles now before you go about doing all the fab work,gears,lockers, 5 lug rims etc. that 6.2 is going to destroy a 44 and stock 9" in quick fashion.
everyone else is crying over what michigan has been dealing with for 6 years.
ChevotaSS is offline   Reply With Quote Quick reply to this message
Old 01-18-2014, 10:08 PM   #10 (permalink)
Bednar's Avatar
Member # 331529
You are right about that. I'm going to run. 3/8 spidertrax 9" and do a little extra work th the 44. I'll be running 6 on 5.5 rims with big studs. I'm also pretty much a mall crawler however, I do have a drinking problem witch usually leads to dumb stuff in whatever vehicle I'm in.
MRAP Mall crawler.
Old 01-19-2014, 10:31 AM   #11 (permalink)
Member # 12567
looking forward to the build.
Old 01-19-2014, 11:21 AM   #12 (permalink)
rockthedog's Avatar
Member # 19510
Nice build. Keep it up
77fj40, 1 TON
[url]www.wfoconcepts.com[/url] 530-268-9494
tlca# 12281
semi_budget 1ton build
[URL="http://www.pirate4x4.com/forum/showthread.php?t=530636"]http://www.pirate4x4.com/forum/showthread.php?t=530636[/URL]
linking the rear
[url]http://www.pirate4x4.com/forum/toyota-land-cruiser/860552-linking-rear.html[/url]
rockthedog is offline   Reply With Quote Quick reply to this message
Old 01-20-2014, 08:41 AM   #13 (permalink)
Member # 193299
i hope you plan to use a new steering box braket , i never seen one mounted that low
x2 on axles , stock cruiser diff with longfields are better than 44 , if you want wider axle find some fj60 diffs
jim land is offline   Reply With Quote Quick reply to this message
Old 01-20-2014, 06:42 PM   #14 (permalink)
Mr Roxy's Avatar
Member # 17537
I have argued the 44 front with him a few times, but at the end of the day his build. Better get to work, you were slacking today
Robert
TinBenders.org
Mr Roxy is offline   Reply With Quote Quick reply to this message
Old 01-21-2014, 06:15 AM   #15 (permalink)
toyota hoarder
rugburn's Avatar
Member # 45
Thank you for your service !
Build looks great and I look forward to seeing the snivelling purists cringe
John Runberg
Swedish American
rugburn is online now   Reply With Quote Quick reply to this message
Old 01-22-2014, 03:37 PM   #16 (permalink)
Member # 29
You can run the radius arms with the front 60 if you want. Personally I am not the biggest fan of the arms, but to each their own.
BTW, for the amout of money you are going to throw at a front 44, you can buy a front 60 and call it a day. Build it once, and build it right.
Love the way you cut down the dash. I may be doing the same thing.
Dima
1974 FJ40 in the works
2006 F250 crew cab longbed powerstroke for towing duties
Flatty is offline   Reply With Quote Quick reply to this message
Old 01-22-2014, 06:06 PM   #17 (permalink)
Bednar's Avatar
Member # 331529
Thanks guys, I'm seriously considering running a spidertrax 9 in the front as well. I'll have plenty of time to think about it still. My paycheck isn't as good as I'd like. I ordered the rear axel and got some brake parts in today. I am going to use a wilwood pedal, so now that I have it I can do a little more work on the firewall.
MRAP Mall crawler.
Old 01-23-2014, 07:35 PM   #18 (permalink)
Member # 64778
I see a CO license plate in one of the pics, you in Denver/Springs/West Slope, judging by the signature and avatar im guessing Carson? I'm right up the street in Woodland Park, nice to see another 40 getting built around here!
Old 01-23-2014, 08:30 PM   #19 (permalink)
Bednar's Avatar
Member # 331529
Yeah, I'm at Carson. I have a buddy who lives around woodland park. He also has a cruiser.........but he is a purist.
I got my brake setup in yesterday. I'm going to have to fab up a new brake pedal. The wilwood one I got won't work with the cruiser firewall lines. I'm trying to get everything situated on the firewall and trans tunnel while I wait on KOH and the bigger parts I need.
MRAP Mall crawler.
Old 01-23-2014, 09:05 PM   #20 (permalink)
Battle CHENG
Member # 20378
Holy crap, what's the low down on that piece of brake hardware? Please provide a part number or link...that's very cool!
Kuranosuke is offline   Reply With Quote Quick reply to this message
Old 01-23-2014, 09:53 PM   #21 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Standard hydroboost setup with a fancy willwood master.
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 01-31-2014, 10:23 PM   #22 (permalink)
Bednar's Avatar
Member # 331529
I got a pm from Medusa asking for more info on the brake setup.
The master is a 1 1/8" wilwood.
The hb unit is a late gm for a 3500.
It comes with a little pin that you insert into the plunger if you use a late model hb unit.
I got it all mocked up today. Cut some plates for reinforcement and set a seat in to see how she feels. ( yes.... I did pretend to drive.... And wave..... And make the brap sound)
MRAP Mall crawler.
Old 02-01-2014, 09:40 AM   #23 (permalink)
Old Rock Doc
Medusa's Avatar
Member # 915
What I was hoping to get was the part number for the Wilwood. I already have a GM Hydroboost and am very familiar with them.
Got Rice?
Medusa is offline   Reply With Quote Quick reply to this message
Old 02-01-2014, 01:22 PM   #24 (permalink)
Bednar's Avatar
Member # 331529
Oh, sorry. I didn't know you don't have google.
Part#: 261-13270-Bk
If you need me to find you any other parts please hesitate to ask.
MRAP Mall crawler.
Old 02-02-2014, 11:17 AM   #25 (permalink)
Old Rock Doc
Medusa's Avatar
Member # 915
I am thrilled you have discovered the practice of sarcasm
There actually was some tech justification for me asking about the Wilwood. Below is a pic of a stock GM master cylinder used with the hydroboost you pictured.
The o.d. of the collar that fits inside the bore of the hydroboost is 1.815". It is a snug fit and serves to align the master with the hydroboost unit. Also note that the flange attachment holes are round.
According to a Wilwood tech droid, the o.d. of the collar on the master cylinder with the part number you supplied is 1.481", producing 0.334" of slop in the alignment. Furthermore the flange mounting holes in the Wildwood unit have been elongated by 0.090" in order to fit a range of different OEM applications. I am a cheap old fart, and if I was to pay $300 for a brake master, I would expect that it would fit better.
I was naive enough to think that you might have found an esoteric Wilwood master that provided a better fit......Silly me And do not worry, I will not be bothering you about parts in the future.
Got Rice?
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
