Fj40 4bt re power - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-21-2014, 06:41 PM   #1 (permalink)
trupster415's Avatar
Member # 107105
Fj40 4bt re power
I have from many of you know a 1967 stretched and linked fj40 on tons and 42s.. I am currently doing a engine swap from the full roller studded Tune port 350 with AFR heads to a fresh rebuilt 3.9 liter cummins 4bt that was machined and assembled by douglas machine that i head studed with compound turboed and should be around 200 hp and 500 plus foot pounds of torque .More to come as I get done.
trupster415 is offline   Reply With Quote
Old 01-21-2014, 06:42 PM   #2 (permalink)
Member # 107105
Another pic
Old 01-21-2014, 06:43 PM   #3 (permalink)
Member # 107105
The cruiser
Old 01-21-2014, 06:53 PM   #4 (permalink)
plasma dust huffer
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
hell yeah!......
i am almost done getting parts in hand to brake ground on my fj-4bt build. i decided to go with an p-pump 4bt and 5spd allison from a chevy along with d60 and 14b.
cant wait to see how you get things fitting and running.
Duramax and LS based motor tuning
www.exit0customs.com
Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep.
have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily
"it makes the mach5 look like a vagina" - ARCHER
carslut is offline   Reply With Quote
Old 01-21-2014, 07:30 PM   #5 (permalink)
Member # 107105
Originally Posted by carslut View Post
hell yeah!......
I wanted a p pump 4bt but I found a core ve pump 4bt for cheap so I went with it. .
Old 01-21-2014, 07:50 PM   #6 (permalink)
plasma dust huffer
carslut's Avatar
Member # 25823
i was hard pressed for any 4bt, so i bought an hostess delivery truck. problem is i liked the truck so much upon picking it up that i ended up getting a 6bt to put back into the hostess truck. now i have a low buck camper/tow rig to go with the fj-4bt build.
how stretched is your fj?
Old 01-21-2014, 07:59 PM   #7 (permalink)
Member # 107105
Very nice. It's stretched the tub 18"
Old 01-21-2014, 09:06 PM   #8 (permalink)
Scooterloo's Avatar
Member # 26149
What kind of wheeling do you plan on doing? Are you doing anything for slow throttle response? Some guys I talked to that have run them say the lag is a deal breaker for bumping ledges or "blip" throttle situations.
Tiny turbo for low rpm spool?
Love diesels but don't work for what I am building.
Scooterloo is offline   Reply With Quote
Old 01-21-2014, 09:14 PM   #9 (permalink)
Member # 107105
This is my mall crawler. In the spring I'm building a 4 seater ultra 4 style car.
And for throttle response I'm doing compound turbos HX30w over a HX35 or 40. I already have the HX30w for it.
Old 01-23-2014, 09:01 PM   #10 (permalink)
jedrattle's Avatar
Member # 21750
I like it! How wide is your back seat? Looks pretty wide.
Team RattleKann
**ROCKBRAWLERS**
jedrattle is offline   Reply With Quote
Old 01-24-2014, 05:39 PM   #11 (permalink)
Born to Lose
77WarPig's Avatar
Member # 160119
Fuck yes
77WarPig is offline   Reply With Quote
Old 01-24-2014, 06:04 PM   #12 (permalink)
knightkrawler's Avatar
Member # 179963
Nice
Rig stolen by evil bitches......
'Resistance to tyrants is obedience to God." Jefferson
knightkrawler is offline   Reply With Quote
Old 01-24-2014, 06:05 PM   #13 (permalink)
Member # 107105
Thanks. It's a aftermarket cj rear seat
Old 01-27-2014, 01:27 PM   #14 (permalink)
rugburn's Avatar
Member # 45
Originally Posted by 77WarPig View Post
Fuck yes
TOTALLY
John Runberg
etiquette states that you bring your own towel to put between the chocolate starfish and furniture.
rugburn is offline   Reply With Quote
Old 01-27-2014, 06:27 PM   #15 (permalink)
Member # 107105
Thanks everyone . I will be working alot more on this repower and keeping this thread updated when I get back from KOH
Old 03-20-2014, 06:44 PM   #16 (permalink)
Member # 107105
Not much progress besides cutting the old motor mounts and welding the frame up. And mounted my new tires
Old 03-23-2014, 09:09 PM   #17 (permalink)
Member # 107105
Well I have the engine bolted to the trans and held in place to make mounts. I also took off one of the coils on each C/O so it would be at full bump in the front so I could place the heighth of the engine!!!
Old 03-23-2014, 09:11 PM   #18 (permalink)
Member # 107105
Full bump in the front
Old 03-23-2014, 09:13 PM   #19 (permalink)
Member # 107105
Darn pictures keep turning on me.. Will a Moderator please fix them?
Old 03-24-2014, 10:09 AM   #20 (permalink)
Member # 429834
What are you doing for motor mounts?
I'm putting a 4BT in a FJ55 and still looking for a clean motor mount to use with the narrow frame.
J Mack is offline   Reply With Quote
Old 03-24-2014, 06:09 PM   #21 (permalink)
Member # 107105
I'm making my own like I did on my 6bt in my cc Chevy. Ill post pics when I get them made. I used the large rubber rear leave spring bushing off a jeep Cherokee!
I'm using this same design but using the 3 bolts at the front of the engine instead
Old 04-12-2014, 10:51 PM   #22 (permalink)
Member # 107105
Little more progress tonight. I was able to get the engine mounts done and a good start on the frame mounts!
Old 05-06-2014, 04:48 AM   #23 (permalink)
Newbie
Member # 461074
I can help you out with motor mounts. PM me
FarmStrongInc is offline   Reply With Quote
Old 05-06-2014, 04:51 AM   #24 (permalink)
Newbie
Member # 461074
I am not a fan of using the 3 bolts on the front of the 4BT for mounting in an automotive application. It puts too much stress on the bellhousing, so if you use the front holes on the 4BT, you should really add a support at the bellhousing.
Or just use the 4 holes at the mid-mount location.
Old 05-06-2014, 09:26 PM   #25 (permalink)
Member # 107105
I used the 4 bolt mid mount location with lord liquid motor mounts
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
