Member # 1282
running wide tires
Anyone running tires in the 15.5 width with stock axles, soa? If so what backspacing are you running on yor rims? Lucked upon a set of brand new tires for cheap, and was trying to figure out what rims to get without the problems associated with springs, calipers, steering. 2" backspacing is what I figure, but wanted to see in real application what works.
I have read several posts on the subject, but never anything mentioned about tires this wide.
Member # 1858
Clay (toy4fun on PBB) runs 35x15.5x15's on his FJ40, he has been running them for sometime, never really heard him comment about them either way.
I have several other customers that run wider tires, don't really see any major problems with it. 2" BS wheels will place alot more stress on the trunnions...
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
I've got 38.5x14.5 tires on 15x10 beadlocks with 2" backspacing and like it. Yeah, it'll probably go thru trunions quicker, but the added width has been nice.
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
Member # 1767
36x14.50 TSL radials on 15x10 aluminum wheels. They're either 3.5" or 3.75" backspacing. I run a thin spacer in the front to clear the caliper.
They work fine like this. I'm going to get some 2.5" backspaced wheels eventually to get the extra width.
TLCA #8123 Lone Star Land Cruisers - 79 FJ40 |
Member # 6588
im running 42 x 15 on stock SOA HJ60 axles. 2" BS on my 15x10" wheels.
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
I ran my 35x16wx15 with 3.5 bs with a .25 spacer when you go SOA and a hi-steer kit on the 62 you can run that same tire with no spacer. the problem with the 60-62 is the tie rod end hitting the wheel yes the caliper is close but it doesnt hit with my wheels anyway. they are 15x10 aluminium, I do know that steel wheels dont have the clearance but most of it is the tie rod end do a hi-steer kit and 3.5 or less will work.
[SIZE=4]Don't sing it Bring it[/SIZE] |
Member # 2533
Backing spacing......again
Now I am running 38.5 x 15 SXs on 15x10 stock Toyota Pickup back spacing type chrome rims. I think 3.5" Just put Hysteer on it but before that was just the standard welded mini truck arms for the SOA setup. Not a bit of problems. Well, I did have an ongoing problem with the inside of the tire rubbing aginst the passenger side shock(Ford Towers). That was fixed permantly when I put the new Hysteer system on and had to relocate the shock mounts on the axle. BTW, 1973 FJ40 with 2" skyjackers. stock axles.
Member # 15144
So where did everyone get they're 2.0 or 2.5 inch back space wheels? I'm tryin' to find the best place to get them (and the quickest) without obviously having to pay out my arse...
-Ferg- |
Member # 20879
Pick out the rims that you want or think that will fit and then go down to the tire store and see if they will mount one on you tires (only one) to see it they will work
that is what I did to see if the 35x15.5 on 15x10s rims would fit, some mods. and 1/4 spacer in the front, who needs zerk fittings in your tierod ends any way and a little rubbing on your spring and fenders
What? |
