Fj60 birfields = FJ40 birfs? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-18-2003, 05:29 PM   #1 (permalink)
Member # 876
I'm getting a FJ60 axle for the front of my 1971 fj40 and wondered if the birfields are the same? If they are I'll be taking them up to canada on vacation to get them smurfed. Thanks
1971 FJ 40
85toyboy is offline   Reply With Quote
Old 08-18-2003, 05:34 PM   #2 (permalink)
Member # 12758
79 and later birfs the same, 78 to 76, a hair smaller. You want to use the larger ones. 75 and earlier, smaller, and coarse splined AKA won't work with a disk brake hub.
So basically... No, (EDIT, your '71 Birfields) won't work for smurfing. He might be able to smurf them for you anyways, Bobby Long is able to do it, he just doesn't carry them in stock and you have to mail them in...
You can run them in your 60 axle, they are less weak tho...
dieselcruiserhead is offline   Reply With Quote
Old 08-18-2003, 05:35 PM   #3 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
Aren't they the same as mini-truck birfs/knuckles
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote
Old 08-18-2003, 05:45 PM   #4 (permalink)
Member # 12758
It's the same size knuckle, the brake and hub parts are interchangable, but inside the knuckle is slightly smaller, this is why you need to grind either the birf or (preferably) the housing to get a mini birf to fit into an early axle. For example I just did this on my '71 that runs mini birfs, before I sent them off to get smurfed myself...
The birfs you'll be removing are course spline, somewhat useless unless you find a hub that will work for them with your disk brakes, which is possible, but they are still less desirable than mini truck / FJ60 birfs or anything from '79 and later...
Old 08-18-2003, 06:16 PM   #5 (permalink)
Box Rocket's Avatar
Member # 6754
Uh...didn't he say he's swapping an FJ60 axle into the truck? IF that's the case I'd assume he's swapping in a complete FJ60 housing and internals which will give him FJ60/minitruck birfs, not the course spline ones.
I doubt he's using the internals from his '71 axle with the FJ60 housing.
Adam
'93FZJ80 - '03 Tacoma V6 TRD DC
Box Rocket is offline   Reply With Quote
Old 08-18-2003, 06:22 PM   #6 (permalink)
Member # 12758
That's why I covered all bases
Old 08-18-2003, 07:12 PM   #7 (permalink)
Member # 6863
Re: Fj60 birfields = FJ40 birfs?
1971 fj40 birfs not equal to FJ60 birfs of any year.
fj60 birfs are the same as mini-truck birfs so plenty of donors out there. Keep the short side inner axle shaft(same as your FJ60 short side inner) from the 1971 axle, and the third member(4.10:1 ratio-but someone will want it). Sell the long side axle(shorter than the fj60 length) and shitcan the rest of the axle.
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
Old 08-18-2003, 07:16 PM   #8 (permalink)
cruiseroutfit's Avatar
Member # 1858
Originally posted by Box Rocket
...I doubt he's using the internals from his '71 axle with the FJ60 housing.
I think he is taking the 71' birfs up to Cananda to get them "smurfed"...
But then again.. I am wrong now and then....
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 08-18-2003, 08:19 PM   #9 (permalink)
Eskimo's Avatar
Member # 10429
Damn guys, you got me all confused.
he is getting a FJ60 axle, period.
The birfs in the 60 axle are the same as minitrucks.
They are NOT the same as your '71 birfs, which are basically a lost cause anyway. (coarse spline)
Take the 60 birfs out and get THOSE worked on.
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is online now   Reply With Quote
Old 08-18-2003, 08:47 PM   #10 (permalink)
Member # 876
Sorry to confuse you all. I'm getting a FJ60 axle from Nolen, but it won't be here before I go to Canada. I have the FJ 40 axle and was thinking I would just bring those birfs if they are the same. Since they are not, I'll just wait for the FJ60 axle to get here and send those off to get smurfed. Thanks everyone for the info. I'll be keeping the short side if it is the same and selling the rest.
1971 FJ 40
Old 08-20-2003, 02:21 PM   #11 (permalink)
Member # 17748
So would it be better to use mintruck Birfs in my 1976 TLC? Will the mintruck knuckles bolt in place of the FJ knuckles, allowing the bigger mintruck Birfs to slide in without modifications? I'm getting ready to have a couple of Smurfields made and want the biggest I can use. I have access to the mini Birfs but haven't picked them up yet.
Thanks,
swon
[img]http://www.rockcrawler.com/readersrides/photos/2475a.jpg[/img]
[img]http://www.rockcrawler.com/readersrides/photos/2475b.jpg[/img]
swon is offline   Reply With Quote
Old 08-20-2003, 02:34 PM   #12 (permalink)
Member # 12758
Yes, the min truck knuckles will bolt in place fine, that's what I'd doing to run disks. But it still will not fix the problem, the birfield won't fit into the axle housing. Take your 4.5" grinder (if you don't have one, they're cheap at Home Depot and are a great tool), and grind down the housing. It only needs to go maybe an 1/8" down on the top and bottom of the inside of the housing. Fr8dog (who hasn't posted here in a little while, wazzup w/ dat?) has a neat photo showing him doing it to his front axle.
If you search you can maybe find it.
The mini birfs are a hair larger. I think it's much more worth it to grind the housing than the birfs. A lot of the time if you break one on the trail and don't have a spare, you're SOL because everyone has the larger birfs that won't fit in otherwise. It also has little compromise on strength of the whole unit too IMO...
Old 08-23-2003, 09:38 AM   #13 (permalink)
Member # 17748
What part of the housing needs to be cut down? Sorry, I'm not getting it. You said the Mini Birf is longer are you talking about cutting the rear of the knuckle so it will fit and if I have to cut it down can I just use my stock knuckle?
swon
Old 08-23-2003, 11:03 AM   #14 (permalink)
Member # 16085
swon
bottom of the inner knuckle, picture everything unbolted off the axle housing, what left is what I'm talking about, you grind the bottom of the knuckle, its not much.....
a screw it......I suck at explaining stuff
http://internet.cybermesa.com/~chscu...irfield%20Prep
http://internet.cybermesa.com/~chscully/grind.jpg
John
2000UZJ100/92FJ80/90FJ62/86FJ60/82FJ40mustard/82FJ40green/78FJ55/67FJ45LBP/65FJ40LV/65FJ45LV/64FJ45LV/87 Chevy 3/4 ton beater
Landpimp is offline   Reply With Quote
Old 08-23-2003, 05:59 PM   #15 (permalink)
Member # 12758
Yes, here's the photo from that site, it shows the grinding...
Mini brifields are not longer, they are the same length. They are just a hair larger in diameter at the bell of the birf. So you need to grind, as seen in the photos, to get them to fit into an early axle...
Best of luck, started putting mine together with my new Smurfieds
Old 08-27-2003, 11:13 PM   #16 (permalink)
Member # 17748
Thanks for the information, guys! I was off the net for a few days. My computer harddrive crashed. My wife got it fixed and going again lastnight. I think I'll keep her around!
Anyway, I'm not sure if it's worth all the hassle of grinding the housing down to use minitruck birfs, if I have to go through realigning the knuckle. Travis can make my LC birfs into Smurfs and I have plenty of them. I'm going to send him two sets to modify for me. I have my hands full with my FJ-40 Hybrid rear axle and full-floating kit. It's going to be WAY COOL! I start cutting tomorrow!
Thanks again!
swon
Old 09-02-2003, 05:55 PM   #17 (permalink)
Member # 17748
Wow, is a heat treatment process done on the minitruck Birfields. I just tried the same method I used to separate my Land Cruiser Birfields (a great BIG hammer). The mintruck Birfs couldn't take it. The hammer marks from each hit show on the minis but not the LC birfs. They seem to be junk. Anyone have any thoughts about this.
swon
Old 09-02-2003, 06:52 PM   #18 (permalink)
Member # 12758
They might be softer but that's actualy a good thing. In theory, you want them softer then they're less brittle and less likely to break. That's exactly what travis is doing by heat treating them -- softening them
Old 09-02-2003, 07:41 PM   #19 (permalink)
Member # 876
Yup thats totally the point, Toyota made these things hard enough to go 500,000 miles. So when the force is too great the metal shears instad of giving. By softening them they can absorb more shock without grenading.
1971 FJ 40
Old 09-02-2003, 08:36 PM   #20 (permalink)
Member # 17748
Thanks for the info. I never did get them apart. I'm going to try it again tomorrow at work. Is the big hammer the prefered method of separation?
swon
Old 09-02-2003, 08:39 PM   #21 (permalink)
Box Rocket's Avatar
Member # 6754
I used a big peice of pipe (exhaust tubing) and slid the axle shaft down inside of it so the birf rest at the top, and then slam it hard against the ground on the other end. Shaft popped right out.
Adam
Old 09-02-2003, 08:50 PM   #22 (permalink)
Member # 18149
yup, the pipe is my preferred method
TRDV is offline   Reply With Quote
Old 09-02-2003, 09:01 PM   #23 (permalink)
Member # 876
da pipe....
1971 FJ 40
Old 09-03-2003, 02:15 AM   #24 (permalink)
Member # 17748
OK, the pipe it is. I'll try it.
swon
