TBI - stumped...
1991 350 Chev TBI - idles great, "casual" accelleration is great, mash the pedal and it bogs down. Back off the pedal, and it accellerates casually...mash again, and it bogs.
Ran WinALDL, pulled a code 44, replaced the O2 sensor. no change. Replace the TBI basegasket, no change. Air cleaner is new. Fuel pump is new. Fuel filters are new. NO other codes....drove it last night about 10pm (my neighbors love me), WinALDL shows nothing. Did not turn on the DataLogger, but can if someone thinks that info will note something. All sensors appear to be sending information in correctly. I want to mash
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
Member # 9950
I have the identical problem....my fuel filter was bad so I replaced it...that improved things but still bogged when mashed....I finally went to carb and HEI for the rest of the season....I was pulling code 43....my Certified GM buddy thinks it's a bad ECM....this winter I'll be installing a Howell TBI harness and finding a different ECM (7747)....you may want to check the filters one more time....mine was new and it was still plugged....good luck.....
Hope you can mash soon.....
[SIZE="4"][COLOR="Blue"]Operator, Quick...give me the number for 911!!![/COLOR][/SIZE] |
Member # 12180
long shot...
may be a stupid question but... thought I would speak up to make sure -- is your fuel pump strong enough?
My RamJet needs a TON of fuel, pressure filled lines (45psi min.) and a return line... not sure of the pressure requirements for a TBI... Hope it helps, RamJet 350 MASHES GREAT... |
#4 (permalink) | |
Re: long shot...
Swaying between TPS and MAP right now....probably need to read the datalogger tonite and see if I can spot something amiss, or hope that some added road time kicks up a code...
Member # 4828
Hey Woody,
Has it run good before and this is a new problem, or is it a new TBI setup and this problem is there? Base timing set with EST unplugged? You running EGR? (open at wrong time?) Have a knock sensor? (ping causes timing retard) GM prom or custom burn? Good fuel pressure/volume? Fuel filter on the suction side (bad) or pressure side (good) of the fuel pump? Note: I see you posted some of the answers while I was typing.
David TLCA 14788 71 FJ-40 TBI 327 w/TH-350 76 FJ-40 "project" Last edited by yoda; 08-19-2003 at 08:44 AM. |
#6 (permalink) | |
It appears to be a load-related issue. Rev it up in the garage, and it does fine. Put in gear to drive, and it bogs down hard.
filter is on the suction side....standard old clear filter tho, and "shouldn't" cause any issues IMO....from "all I've researched" you should run a filter before the pump to ensure any debris from the tank doesn't wreck the pump....
Plus, I've "always" run the pre-filter, and the problem is new.
Member # 3245
Woody -
ARe you running an HEI? (Assume so...) Anyway what kind of advance do you have? If mechanical, maker sure everything is clean (rust-free) and smooth - no grease, light oil. You can change the weights and springs. If Vacumn is your diagram intact? I had an HEI that would not pick up acceleration properly (not on an HEI) and I chesed fuel problems and finally figuredout there was too much white lithium grease under the weights. Jim
Never subscribe to a conspiracy theory when the stupidity theory will suffice. |
Member # 14339
I'm liking the knock sensor idea. If it started in BHCC and continues, maybe it's something loose in or around your stock fuel pump area. (where you have the knock sensor mounted) Can you run WINALDL while driving and check timing advance? Pull the distributer cap and rotate the crank by hand and see how much timing chain slop you have. Lots will cause problems in itself, but might also contribute to the knock sensor picking up stray noises.
73 FJ50, 64 FZJ45LV "Young girls and gin may be the cure" - The Reverend Horton Heat |
#11 (permalink) | ||
Thanks for the thoughts gang...keep 'em coming!
#12 (permalink) |
Woody,
I had the same symptoms with my 92 350 TBI that came OUT OF A VAN - DOWN BY THE RIVER. (In my best Chris farley imitation). I replaced the TPS (Throttle Position Sensor) and now it runs like a scalded cat. Bruce
Bruce Mitchell KTM - 450EXC |
#13 (permalink) |
Member # 6863
Sounds like an ECM, I would guess. It could be running on the netres(the "limp home" mode resistor pack that is part of the memcal) cause they run, but like shit and dont like any kind of rapid changes...
Is there anychance the computer got really hot at BHCC? this can wreak havoc on them... Also, is the little window in the PROM chip covered? I have seen a few that werent and ambient sunlight can eventually erase them...
I have enough projects for the next decade. Need two? |
#14 (permalink) |
Metal-tech'in
Member # 10420
Brian,
I keep thinking fuel delivery problem. I run a small oil filled fuel pressure gage under the hood. It is plumed right in the primary fuel line just off the manifold. (Mounted off the fender) This has proven it’s self invaluable with trouble shooting issues. If you don’t have one I strongly suggest installing one, $19.00 from Jegs, so cost is not a major issue. (Unless you run AN lines like I do, then your looking at about $30 more in fittings) Once you have the gauge in place you can quickly rule out ANY fuel delivery issues just by opening the hood. (Great for on the trail! Or in your case on your side on the trail ) The new pump or new filter may have issues right out of the box that you recently put in. 1. I am still thinking delivery fuel problems. 2. I would try another "Known heathy" ECM. Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service! |
#15 (permalink) |
i am having the same problem with my uncles truck i borrowed. changed cap, rotor, fuel filter, o2 sensor and still no change. when you figure it out, let us know! btw, my bet is also on the TPS.
Nick Hietpas...1985-2003 Rest In Peace |
#16 (permalink) |
Member # 15682
Just a couple other ideas.
What type of exhaust are you running? My dad had a truck that did the same thing (actually it was a .... VAN G1500) and he found out that the distributor gear had spun, the roll pin had failed. Corey
What are you looking at, my eyes are up here... |
#17 (permalink) | |||
I don't recall the problem occurring prior to BHCC...it was not a problem during our trips to Slade/Tellico in June or our trip to Attica in mid-June. Quote:
lolQuote:
TPS is a cheap/easy fix. Hopefully, the datalogger will note some "odd" numbers tonight and I can track it to something specific...just hate to start changing things since the sensors get pricey quick! Thanks for all the comments and ideas!!
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR Last edited by woody; 08-19-2003 at 11:39 AM. |
#18 (permalink) |
TPS: Basically its probably not giving you enough fuel boost and leaning it out real bad, which will then cause the knock sensor to hear the pinging and then retard the hell outta the timing. Thus you get nothing...
The datalogger should show you the TPS percentages as you depress the accellerator. I initially had mine hooked up backwards and it backfired every time I hit the gas... Let us know if you find the culprit!
Dave Perry 84 FJ60 SOA, TBI 2F, SM465+split-case, 36 IROKs, locked F/R (For Sale) |
#19 (permalink) |
Last nights work:
replaced the cap/rotor reset the timing adjusted the idle speed grounded the park/neutral wire tested the TPS...all ranges normal (5 volt constant, ground solid, variable seemed very smooth thru the range) took it for a spin with the laptop recording everything, got a code (don't recall number) noting a bad MAP Sensor My guess all along has been a vacuum issue, so it was nice to see that confirmed. Will be picking one up at lunch today, installing it while the truck is on the trailer tonight, then leaving for a weekend of wheeling...hope this solves it! thanks for all the input gang!
#20 (permalink) | |
Member # 12349
Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
#21 (permalink) | |
day late, $30 short....lol
#22 (permalink) | |
Member # 12349
which we swapped most of them out during that cluster F*** trying to fix my junk..... Butch
#23 (permalink) |
Member # 16988
hello,
Was this issue ever resolved? I am having similiar issues, been searching forums for long times learning and trying different things. My TBI 350 gives me a code at idle, runs really rich too, then the code dissapears when I raise the RPM's over 1000. When I come to a stop, the idle is at 1000, after 15-20 secs it kicks down and the "soft-code" turns my friendly little green SES light on, like I said, it then turns off when I am driving. Runs really rich. I had to adjust the "throttle" screw (so I thought, not sure now) when I dropped the V8 in my 55 to make it runs at all as the mechanism was not touching the "at rest position". I did this to get it at 500 RPMS for idle, then put the ALDL in diagnostic mode, disconnecting the IAC, set the rough idle to 450RPM's, shut it down, disconnected the A/B, reconnected the IAC, then drove for 20 minutes..no codes....then.. code appeared when I came to a stop like before. Stumped me .... new TPS, EGR works mechanically at least, IAC reads proper OHMS, new O2 sensor, knock sensor, MAP sensor (got code for this )... uh what else, I get a code reading "rich exahust" .. sent me to the EGR and it is OK, like I said, been trying some things.. anyhelp would be appreciated. 93 TBI 350 5.7 stock harness weeded(from 2wd K1500, wish I knew more), SM465, 7447 ECM...
#24 (permalink) |
Member # 6816
i've found a couple of very common problems on the tbi's.
1) oxygen sensor too far from exhaust port. this sensor should never be mounted more than 16" from the head to header/manifold surface. 2) fuel pump and filter. i've had very good luck with the walbro pump sold by howell. needs to be 18psi, not 10, not 35, not 45. too low a pressure and the injectors won't fire properly. too high, and you're gonna blow up the lines and possibly diaphram in the throttle body itself. the knock sensor is not essential, and can be mounted just about anywhere on the vehicle. it does NOT have to be mounted in the stock location. a lot of competition rigs run them on a bung on the frame itself to avoid knock sensor to exhaust clearance issues. and that works just fine.
Maybe you outta stick to legos! |
#25 (permalink) |
Member # 27592
I have run into this quite a bit on different vehicles. I went through two new fuel pumps from Downey on the first one. Plenty of pressure but no volume. Since then, I have found numerous fuel pumps that were not supplying proper volume. Airtex makes a good TBI replacement pump.
Also try running with your fuel cap loose or off.
75 SOA Land Cruiser (Gentle Giant) TLCA, LCML, BRC, CA4WDC, Motherlode Rockcrawlers-Jackson, CA. |
