Member # 2482
Summit racing has the line locks. I just ordered mine for the cruiser. Gonna lock just the front so I can do burn outs at Hot August Nights next year.
GET IT Dave!! save me a spot bro......i'll miss you... |
Member # 21597
It installs in the brake line between the master cylinder and the caliper or wheel cylinder. The racers use electric but those are eather on or off. ( no modulation) Manual works best in my humble opinion for rocks. when you depress the brake pedal and activate the line lock ( electric or manual ) then let off the brake pedal the line lock traps the pressurized brake fluid between the line lock and the brake. Keeping the brake applied untill you release it. Very handy for those of us still running carbs that like to kill the engine at extreme angles and have not mastered the whole three pedal two foot thing.
#7 (permalink) | |
Member # 2482
hahaha it will burn em now, no doubt about it, but it's usually associated with 2 gear, lots of RPM and launching towards the 100k nova in front of you.
Line Lock works ok but its definitely not an E-Brake. The only problem is, if your brakes go out, so does your line lock. We were able to get my bros cruiser to pass inspection with Line lock. The inspection to get that BAR sticker..... I would eventually get a mechanical hand brake but thats just me.
#9 (permalink) | |
Member # 12349
Line locks will bleed off, we have had them on wreckers for years, and they will hold for a few minutes with no re-pump.
Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
Old Rock Doc
Member # 915
I have two of the Sam Biondo Racing units on the FJ45. These are electrical and rated at 3000 psi.
I have had a manual Mico Lock on my Fj40 for almost five years now and it holds pressure for several hours (i.e., very little bleed down). While I admit that line locks will not work if the brake line fails, you should also admit that a stock LC parking brake will not work if the transfer case breaks and the rear output gear separates. Personally, I have seen a lot more broken transfer cases that resulted in no parking brakes than I have seen broken brake lines. I don't want to start a poll, but how many have actually broken a brake line on their rigs? Last edited by Medusa; 08-21-2003 at 02:53 PM. |
#12 (permalink) |
Member # 21597
I have the stock PB but it doesn't work worth a crap even with new shoe's. I manly want the line lock to free up a foot to get going again once I kill my eng. Does anyone sell the disc PB to replace the stock. Man a fre discontinued there's.
#13 (permalink) |
Member # 6588
On mine I have another smaller master cylinder it operates on a push button as long as you hold the button it provides pressure. Its air operated.
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
#14 (permalink) |
I run those same units on my comp rig. One each front and rear. They allow you to set them, then apply pressure. I have no regrets. I used relays and the same switches ARB uses, Carlingswitch brand.
Assuming my drivelines don't break, I am pretty confisent my junk won't move with them set, the tranny in low/reverse and both tcases in low. The traction of the tires becomes the limiting factor!
Mike "SpaceGhost" Smythe R U gettin' it? UROC Team #180 running: BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)! |
#16 (permalink) |
Member # 6588
As old a brake lines as I have used, I have never broken one. Yes I have split an old transfer case in half.
#17 (permalink) |
Member # 17748
I bought my linelock from FROR. It came with the metric brake lines and everything needed for the install. No, it does not replace your emergency brake but why would you want it to? I plan to use it during wheeling, only if the 40 needs to stay put for a few minutes. Don't forget to use a good covered aircraft type switch. My kit came with one.
swon
[img]http://www.rockcrawler.com/readersrides/photos/2475a.jpg[/img] [img]http://www.rockcrawler.com/readersrides/photos/2475b.jpg[/img] |
#18 (permalink) |
Member # 12388
FROR
Where and what is FROR? How do I contact them?
Jeff Moore 77 FJ-40 "PJ" (350 TBI, SM465, SO, PS, 38.5 TSL Swampers) 94 FZJ80 (OME, ARB Bull bar) cruzer17@mtaonline. |
#19 (permalink) |
Member # 17300
I'm running the Biondo line locks (Summit Racing) both front and rear, with independent switches. I am very pleased with their operation.
Ed Gilbert 1977 FJ40, 5.7L Vortec F-Toy #F006 build in-progress [email]vorteccruiser@charter.net[/email] |
