Member # 6588
looks like a 60 on U1300s
anyways, i was just looking, and i dont think he will get full lock, but he prolly still has more turning angle than a stock cruiser
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
Metal-tech'in
Member # 10420
Is Peter going rear steer with that?
Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service! |
Member # 13912
If I remember right, and often I don't, he told me he was using to front mog axles...so, yes...
Visit [url]www.tlca.org[/url]; TLCA Member 6235 TLCA Prez Emeritus |
Member # 13912
Once again, if I recall right, the suspension is set up for mostly droop, so they don't need to flex up very much, but that's tunable by adding air, and if it's plumbed right, can be aired up or down on the fly. Peter's pretty sick, I'd expect him to have gone that route...
Member # 2046
Yep, dude has a serious case of the MIB syndrome! Althought I gotta say, if I could do that, I WOULD
1987 Dodge Raider - Stock except for 30" tires 340K miles and counting |
#12 (permalink) | |
Member # 6588
he could float if those tyres weren't so heavy!
#13 (permalink) |
Moderator
Member # 8568
That thing is sick more pics please.
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place. 2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th 2010 KOH Team CrossedUp Mike Klensin and Justin Reece. 2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH. TLCA# 5305 |
#14 (permalink) |
Member # 13584
Hey, that truck looks exactly like mine! Oh, wait.
So, those are indeed, 16.00R20 Michelins. (53") Those are Unimog 406 axles (a front and a rear, so no rear steer). I am at about 30 degrees of steering. I measured a stock LC at 28 Degrees. That's worked out much better than I had hoped. Steering is full hydraulic. Engine is a Toy 3.4L 3B with aftermarket Turbo est. 140HP/220lb-ft Tranny is a H41. Tcase is 203/205 Gearing in the axles is 4.1 diffs, with 2.2 portal, for 9.075:1 in the axles. Total crawl ration is 176:1 Total Groud Clearance to the lowest part of the diff is 23.5". To the bottom of the axle tube is 25". Oh, and get this... how much lift did I need to fit those tires?... would you believe a grand total of 1.5" body lift? That's not exactly true, as there is about 5" of lift from the portal hubs, but that 6.5" is it. Even though the hood line is pretty much at eye level, the truck actually looks positively slammed when it is at ride height. The tires are 65% of the height of the truck! Oh, and an answer to another question... the air bags suck when aired up. They droop nicely, which is what I want them for - the rig has only about 4" of compression at each wheel (plus whatever the 18" of sidewall will allow me) to soak up the bumps, but almost 16" of droop. How does it all work... I don't know. It's driven a total of aprox 1meter so far. Seemed to work OK for that trip. I hope to get it out of the shop tomorrow for a very preliminary shake down. Perhaps a first trail test run next weekend. And to Rock Hugger... I have fond memories of your welding assistance. I have my own Ready Welder now, so hopefully I can be a little more self repairing. This truck is a result of that Trip on the 'Con back in 2000, and the damage it suffered back then.. Few slightly more recent pics (with the grill/lights) at www.prairiedogparts.com/yabbse Peter Straub |
