Metal-tech'in
Member # 10420
Suggestions for in-tank fuel pump?
I need 45 PSI any suggestions for an in-tank fuel pump? My Volvo external proved it could not handel 95-100* BHCC temps. I dont like taking the strap out. Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service! |
http://www.howell-efi.com
I used their external I believe they have internal pumps too. Why not use a stock GM pump?
Eric V. 99 built UZJ100 FJ68 Project 74 FJ15 www.WildWildWestArt.com |
#3 (permalink) | |
Metal-tech'in
Member # 10420
!Mark
Member # 12349
I would use a stock GM AC Delco for the engine you have in the truck, when you do it document how, all of us running EFI in the heat need this...............bad! BTW here, Autozone, can get AC pumps, in fact the local store stocks them because the shops prefer them. cheaper than the dealer and a lifetime warranty.
Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
Hot Rod EFI links
One of these guys should be able to do it. Toy4Todd just recently put a GM pump into his Cruiser tank (78 40). I'm not sure how easy it went in, but you might PM him or his email is toy4todd@yahoo.com
#6 (permalink) | |
Metal-tech'in
Member # 10420
Ok I will be the ginipig on this one. Just like some of the guys I wheel with.. “send Mark in first, if the water sucks up his truck we can go around” Mark
Member # 14339
Not too hard to put a GM pump in a cruiser tank. I had mine set up this way until I gave up on the tank location. Then I moved the same set up to the Beetle tank under the bed. Cut the top out of a stock GM tank so you keep the flange, cut a 4" hole in the top of the tank you want to use, weld the flange over the hole. Now you have a GM pump and sending unit in the other tank. Be sure to use the deepest part of the new tank as you want to pull out of the lowest area and the GM set up is often pretty long.
An alternative would be to use a surge tank with a welded on GM flange if your stock tank is not deep enough. That option might even keep the pump cool when the fuel is low in the main tank.
73 FJ50, 64 FZJ45LV "Young girls and gin may be the cure" - The Reverend Horton Heat |
Member # 12758
Hey Mark, I think I went through 2-3 of those Volvo pumps myself when I owned this POS:
![]() http://www.collegeinternetsolutions....images/me1.jpg I remember the Volvos (like most electric HP fuel pumps) use a pre pump that is low pressure, before the high pressure. The HP one will run alone for sometime, but if there isn't decent pressure it before then it will crap out at some point early. Hence why I went through 2-3 of them. I pulled about 4 from the JY one day for $20, it was cheaper and easier replacing them every 20K or so than dropping the tank and replacing the pre pump. They always have the same symptom of crapping out too. The car/truck turns off randomly usually under throttle. The conditions cause 'intermittent' failure. Those Volvo pumps will hold up for years and years, they need the right conditions tho. The heat probably just brought it out more easily. It also could be something related to Autozone though. You should have seen the 22RE timing chain kit they sold me
#9 (permalink) | |
Metal-tech'in
Member # 10420
Ballard, I thought about that as well. I just have to deal with all the tank liner (Kreem) I put inside my tank I built. Arrrrg! Also a tank fresh from having fuel in it. ! Mark
now, here's a thought...build a separate high-pressure resevoir (like a quart or two) and incorporate the internal high-pressure pump in there...supply it with a low-pressure pump outside the tank. That not only solves the cooling of the HP pump but also gives you reservoir for extreme camber situations
hhhhmmmmm
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
#12 (permalink) | |
Metal-tech'in
Member # 10420
YUP got it. It works for extreme camber situations. Now it is not two qts. more like a pint. (mmmmm a pint sounds good right now ) This is fed by the low pressure pump and also has the motor return line feeding into it. The HP pump draws from the lowest point on the tank and the highest point has the one and only RTN to the fuel tank. Works great and I would not run it another way. But remaking this would allow for an easier install of the HP pump. The only issue would be building it large enough to allow for good cooling. Mark
#13 (permalink) |
Member # 6863
Your discussing this jinxed my truck(FJ40 with TPI) yesterday on a trip out 8E to Sunrise highway for some camping... the JY high pressure fuel pump just got too hot and it quit pumping on sunrise highway. I run the same sort of setup wiht a LP pump pumping to a 1.5 quart reservior and the HP pump(the same pump in Volvos, Audis, Nissans, BMW's etc) draw from there...
Had to ice it down and it started working again for about another 30 minutes...was fine on the return trip, but it is all down hill...so less engine compartment heat. -Brett(now thinking about intank pumps too!
I have enough projects for the next decade. Need two? |
#14 (permalink) | |
Member # 14339
#15 (permalink) | |
Metal-tech'in
Member # 10420
DOH! *&**#$$%* fuel pumps! The other option is to build a cooler jacket for the pump then pump ice H20 through the jacket or set up AC just for the HP pump or..... Ballard, good thinking on putting it on the surg tank. Mark
#16 (permalink) | |
Member # 6863
#17 (permalink) |
Moderating Midget
Mark,
To me, going through one pump in 2 years tells me I just don't need to wheel when its 100 degrees ![]() I am sticking with the external pump and adding a cooler between the tank and the pump!
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
