Member # 10010
2F - What is that ???
Look what I have in my barn now !!!
![]() Well, my buddy just bought a clean 1982 FJ40 w/ H41 & PS, and I have a few questions about what I couldn't find in the archives... 1. what is the avg. / acceptable oil consupmtion for a 2F 2. are this carb. and headers worth crap ? (pics to follow) The FJ will be used for on/ off road duties, and my friend is not looking for more power or anything, just wants a smooth running engine that works fine both on & off road, doesn't burn too much unnecessary fuel and doesn't overstress the engine... By now the engine is very hesitant when you push the accelerator quick, and seems to like the upper revs better than the lows. I would like to hear the wisdom about how the carb and headers affect the engine behaviour, and any related advice. shoulc we go back to stock carb and manifold ? The PO also said he had to adjust ignition at least a few times... Is this normal and can this be fixed ? As you probably guessed, I'm pretty much illiterate for petrol engines in general, and 2F in particular so I want to hear just every piece of advice about this... Thanks !!! ![]() ,
'71MS75 '73DW15 '75BJ40 '79FJ55 '84BJ45 '88LN65 '90HDJ80 '92LN85 '98CE110 |
Member # 10010
holley carb... couldn't find anything else written on it other than a buch of patents number...
Member # 10010
Theres also a strange cylinder between the MC and final brake lines... what is that ?
#8 (permalink) | |
Re: 2F - What is that ???
First off, you've been here long enough to know that you should try one of these first!! Second, use that button to search for "headers", "Holley", "carb" and "proportioning valve". Should give you a start!!
Sean 8/75 FJ-40 - 2F, 76 DBs, SR, SOA 55 rear springs, PS, 36X12.5 TSLs, SM420/ToyBox/3spd tcase - 154:1, Mini-Longfields/Aisin hubs and front/rear ARBs. :bounce2: [SIZE="3"][URL="http://gallery.mac.com/md11fr8dog#100070"]My Green Land Cruiser[/URL][/SIZE]:bounce: 03 Tacoma double cab, SR5, TRD, sliders, 3" Cornfed, Can-Back TLCA #11877 |
#9 (permalink) | ||
Member # 2157
This weekend I hope to finish the install of my H41 and 3-speed transfer case into my '76 FJ40. For now I'm leaving the 4.11 diffs in the axles, but will later install the 3.70s from the '83 FJ60 I just parted out. Even with 3.70s, the final ratio will be over 40:1, more than a 30% increase over stock, if I left it with 4.11s, the ratio would be over 45:1, almost 50% better than stock. I'm leaning towards the 3.70s, out here in Nevada I'd like to be able to cruise comfortably (if there is such a definition of comfortable with an FJ40) at 70 mph. Do you know what gearing you have in the diffs in your '82? John |
#11 (permalink) | |
Member # 10010
Re: Re: 2F - What is that ???
Remember, that's only the second F engine I see, and when I saw the first one 3 yrs ago I really didn't pay any attention... Come on...Thanks for the prop. valve though
#12 (permalink) | ||
Member # 10010
![]() The axles are 3.70, I had to check them quick because there was apprently a big question about it... On the highway at 55mph the (aftermarket) tach read 3200 with 33"... Actually it was way off, I guess it came from a 4 cyl. and hadn't been calibrated
#13 (permalink) | |
Member # 10010
#14 (permalink) |
Banned
Member # 17477
See now, the first thing you do is dump that Holley, and install a factory Aisin. Then you will have on and off-road performance and mileage. The timing should be set at around 7-9deg. BTDC
depending on your altitude. Above 2500 ft, then try 9-12 deg BTDC. Average oil consumption is not very much on a good solid engine. Maybe 1/2 to 1 full qt. btween changes. (3Kmiles) Should hold about 7qts. of oil maybe a little more depending on the filter you use. Change the coolant as well. And the rake fluid if it sat for more than a couple of months. Change the all the drivetrain fluids for sure. Rich Kruzrtek kruzrtk@xmission.com |
#15 (permalink) | |
Member # 2157
John |
#16 (permalink) |
Moderating Midget
Damn, we scramble all over each other for a "B" or "H" series and you are excited about an "F" series.
You are a Jackass! ![]() That thing is sweet! Did you get a good deal on it?
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
#17 (permalink) | |
Member # 10010
#18 (permalink) | |
Member # 10010
#19 (permalink) | |
Member # 10010
![]() the price was not really cheap, but it looks really super clean aside from a few details but no biggie. The big concern is the engine tuneup... Again, it's not mine, but I can play with it until next weekend when it leaves for its real new home... The 2F is starting to grow on me, feels like a racing tractor when compared to a B ![]() My buddy said it felt like it was running lean from the sound of it when freewheeling... Anybody know where is the mixture screw on the carb ? a tip on the idle would be cool, too, since I don't really have a stock carb handy right now... can I adjust the fuel/air ratio by just guessing the smell of the exhaust ?
#20 (permalink) | |
Member # 6588
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
#21 (permalink) |
Member # 6588
looks like a cool rig!
cage looks sorta like mine
#22 (permalink) | |
Member # 2157
The Toyota trucks and 4-Runners, and maybe later Land Cruisers, have load-sensing proportioning valves mounted on the frame near the rear axles. John |
#23 (permalink) |
Banned
Member # 17477
The mixture screw on the Holleys is usually horizontal in the base plate. Some models(depending on year) had them vertical, but not often.
Just look around the base of the carb for a couple of screws about 2 inches apart from each other horizontally. They may have a pointed style head with a slot for a flathead scredriver. Out should richen it up. In should lean it out. Unless they installed the PV in backwards then its opposite. But the smell and drive test is great to do. You'll want it so that it doesn't burn your throat to breathe. That is way past the richness of burning eyes!! Good luck. If you need help, email me. I am only on POR at night. Rich Kruzrtek kruzrtk@xmission.com |
#24 (permalink) |
Banned
Member # 17477
If you could get me a pic of the front of the carb at the bottom.
And a pic of the bottom of the carb in the back at the base, I'll tell you where the mixture screws are. The screws on either side of the metering block were used for somehwhat of a mixture adjustment for a while, but that carb looks a little later than that era. I basically just need pics of all angles and levels of that Holley to be sure. Rich Kruzrtek kruzrtk@xmission.com |
#25 (permalink) | |
The Holley is a great carb. Can work equally as well as an Asin in off camber situations and will give LOTS more power. Take the holley, put a center hung float bowl on it. (I'll take pics of my 72 tomorrow night and show you what it looks like) jet it properly and enjoy.. The factory Asin will get better mileage. But only because is sacrificies performance... I whole heartedly agree with the timing tho
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
