WHich springs should I use for a SOA? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2001, 10:48 AM   #1 (permalink)
Member # 1159
I need more lift now that I've got bigger tires. I can currently fit 36" TSLs with no problems, however, my new 38.5s will not fit without more lift.
Before you answer the question as to which springs I should use (stock cruiser or wagoneer) , take a look at how the truck has been modified.
I've currently got a SOA using blazer springs (with a 2" body lift).
Reasons for using blazers springs:
1) I didn't have any stock cruiser springs (still don't)
2) my SUA lift springs were starting to sag a little and were longer than stock (at times my front shackle would go completely horizontal forwards)
3) My spring and shackle hangers and frame were all screwed up from some previous owners major HACK job
4) At the time I wanted a low profile (height wise) SOA. This SOA gives about 3.5" of lift.
If I use the wagoneers,
*the center pins are offset similar to a cruiser spring
*they are longer and easier to find in junkyards.
If I use the cruisers,
*they may give more lift than I need
* I may have to modify the mounts (PITA) for the springs to fit them on the cruiser)
What do you think?
Tankota is offline   Reply With Quote
Old 12-10-2001, 06:36 PM   #2 (permalink)
Member # 8029
Waggy Waggy Waggy
Everyday I add another name to my list of people that piss me off!!!! :mad3:
Avatar in Loving memory of my Papa 10-28-28 to 02-26-02 I will always love you!! :(
wheelinjps gal is offline   Reply With Quote
Old 12-10-2001, 06:42 PM   #3 (permalink)
Member # 77
Send a message via ICQ to Shawn
Wagoneer, and don't look back.
74 FJ40 Buggy 454,TH400, STAK 3 Speed, 14 Bolt, Dana 60, etc
Shawn is offline   Reply With Quote
Old 12-11-2001, 09:24 AM   #4 (permalink)
Member # 1028
Use the Waggy springs, with the 7 leaves, worked out great on mine, SOA, 2.5" BL and riding on 38 SX's. Flexes like crazy.
Red FJ is offline   Reply With Quote
Old 12-11-2001, 10:04 AM   #5 (permalink)
Member # 1159
Tanks for the input.
I'm definitely leaning towards waggie springs...not sure if I'll use the 5 or the 7 leaf springs cause I do have a 2" body lift.
Wheelinjp, (posted as Wheelinjps gal by accident) has some springs he said I could try out just for fitment purposes, unfortunately they have to go back on the 1 ton wrangler he is building . However, another friend does have a set of waggie springs that he recently got but decided to use something else instead...so I may have a line on some.
Old 12-11-2001, 01:16 PM   #6 (permalink)
TRD
TRD's Avatar
Member # 8286
Are they just stock waggies from the junkyard? Did you take both the front and rear ?
-Ryan
TRD is offline   Reply With Quote
Old 12-11-2001, 05:31 PM   #7 (permalink)
Member # 2119
No not the rears for the fj40. Too long of a spring for a good approach/departure angle.These are fronts Tank and I are referring to.
Dave I am interested in seeing which will work best. I think it will be the 7leafs. The 5leafs I hear are weak and will sag or break soon.
How many licks does it tak.... AWWW JUST SUCK IT
wheelinjp is offline   Reply With Quote
Old 12-11-2001, 06:07 PM   #8 (permalink)
Member # 77
[QUOTE]Originally posted by wheelinjp
[B]
I run both front and rear on my Cruiser.
To long,,, No Way.
Old 12-11-2001, 08:11 PM   #9 (permalink)
Member # 2619
Send a message via ICQ to DCruiser138 Send a message via AIM to DCruiser138
so when you do waggys..do you need get new hangers?..move them?..anything? or so they fit up allready? i know theyr longer...but long enough where you need to move the frame mount hangers? my springs are rusted to hell and might as well go waggy when i swap. probly not thouhg...i wish....
Dustin Crawford ---
OPEN DIFF DEUSH'
DCruiser138 is offline   Reply With Quote
Old 12-11-2001, 09:43 PM   #10 (permalink)
Member # 1282
Whats the length on Waggy springs?
ranger is offline   Reply With Quote
Old 12-12-2001, 03:03 PM   #11 (permalink)
Member # 1159
Someone back me up on this but I think the waggies are 48".
Aren't the cruiser ones 45"?
Old 12-12-2001, 08:19 PM   #12 (permalink)
Member # 77
Cruiser springs Flat =48"
Front Wag springs Flat= 50"
Rear Wag springs Flat=57"
Flat means with weight on the spring.
Yes, if you use the rear wag springs you will need to relocate the hangers.
Old 12-13-2001, 11:59 AM   #13 (permalink)
TRD
TRD's Avatar
Member # 8286
i see that the waggies are 2 inches longer. does it require moving the mounts?
-Ryan
