Shackle Reversal on an FJ60? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-07-2003, 02:27 PM   #1 (permalink)
Registered - Active
Member # 9461
We recently put the full on OME lift on my wife's FJ60. We also installed some 33x12.5" SSR's on the 4wheel parts rockcrawler rims. Everything works well, but the front tires rub pretty hard on the front of each fender opening with even mild articulation. I talked with her about trimming the fenders, but she is not going for it.
Sooo,
I think my options are this:
Add a leaf in front for a bit more lift (too stiff as it is)
Longer shackles in the front (and rear to balance) for some more lift (maybe use the rear OME shackles up front as they are a bit taller)
Shackle reversal using the stock spring hangers (moved from rear of front to front of front) - no lift, but the tire will move rearward during compression, instead of forward into the fender.
MAF Shackle reversal - adds about 1.5" to the front lift (with front hangers that hand WAY down). May need to adjust driveline angle for this amount of lift (2.5" with OME, 1.5" with MAF SR).
I have done some searching here and on IH8MUD.com and most of the info is on FJ40's which was somewhat helpful. What do you guys think? And keep in mind CruiserWench (wife) will likely go down in tire size to avoid fender trimming if it comes to that.
Billster
FrankenRover is offline   Reply With Quote
Old 10-07-2003, 03:35 PM   #2 (permalink)
Member # 23196
Send a message via AIM to 4doorFJ
I ran OME +MAF reversal w/ 33's for awhile. No driveline mods needed. No rubbing.
87FJ60
4doorFJ is offline   Reply With Quote
Old 10-07-2003, 03:36 PM   #3 (permalink)
Member # 23196
oh ya, also ran 2 inch lift shackles in rear to "level out"
87FJ60
Old 10-07-2003, 06:45 PM   #4 (permalink)
Member # 10679
Also consider lowering your bumpstops to match the added lift and resetting the limiting screws in the knuckles (it will increase your turning circle, but there's worse things to worry about). Lower bumpstops will increase the life of your springs, by preventing the positive to negative cycling that fatigues them into flatness. My Alcans lasted me two years of Moab and Rubicon, and I now broke a mainleaf during an outing to the 'con . I can rework them but it won't be free. I left my stops at stock height, and they went flat early, I think.
Ben
Springville, UT
TLCA#11511
'73 VJ40-the project-
'86 FJ60-35s, 4.56s, ARBs, SUAlcans
'91 FJ80-stocker
crawlin'60 is offline   Reply With Quote
Old 10-07-2003, 07:32 PM   #5 (permalink)
theSherpa's Avatar
Member # 21374
2" body lift. use UHMW Poly body lift kit from Roger Brown (http://4crawler.cruiserpages.com/4x4...yLiftKit.shtml). he'll even color 'em. we've done a bunch of 'em in TornadoAlley, two in one day. no-brainer, no downside.
Steve Fox
theSherpa is offline   Reply With Quote
Old 10-08-2003, 04:36 AM   #6 (permalink)
Kool Arrow
kling-on's Avatar
Member # 13666
if it counts i have 2.5 BDS (HARD HARD HARD) and 1.5 j/t shackles(i'm told) no drive line mods it would drive ALOT better with cross over there is a fair bit of bump steer i want to make a rev like MAF's but move the axle as far forwad as i can to clear on competion mabey a 1 1/2 or 2 but i bet i will have to lenthen the frnt shaft then... my 02.ct
82 FJ60 5.3, 4L60E, SOA, 35's, 456's, lockrights, ARB bull & side bars and warn 12k
85FJ60 SOLD
82BJ42 3B,H55, Fj60 p/s.... And a boat load of parts in the garage
GIT-R-DONE!!!!
low riders want SWITCHES... 4 wheelers want SHIFTERS
kling-on is offline   Reply With Quote
Old 10-08-2003, 10:48 AM   #7 (permalink)
Member # 16968
SOA!!!
lakotastoy is offline   Reply With Quote
Old 10-08-2003, 11:15 AM   #8 (permalink)
Kool Arrow
kling-on's Avatar
Member # 13666
Originally posted by lakotastoy
SOA!!!
i wish BUT my dad has to get in mine and both knees replaced and back surgery ... its too big now i'm gona have to remove the shackels ... but if i do a shackle rev. i cant
85FJ60 SOLD
GIT-R-DONE!!!!
