Member # 22217
Io searched and couldn't find anything, but the problem is that my PCV hose leaks oil into my air filter. I have replaced the pcv valve, the gromit that it goes into and the hose. I have looked in the chiltons manual and couldn't find anything,I also have adjusted teh valves already. Any suggestions, Ideas?
1977 FJ40 in the process of being restored |
Member # 12349
Either the intake line side of the PCV is stopped up or the engine is wore and has blow-by.
Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
Member # 22217
Thanks, I'm assuming it is the blow by, since nothing in the intake side of the pcv is clogged. I was kind of afraid that it would be something like that. Is there any semi-cheap repair or would only a rebuild fix it?
Member # 12349
About the only thing you can do is put an inline fuel filter in and dump the oil out often, this way it won't get to the air filter element.
Butch
Member # 19837
Not sure of your set up but on a F,2F and 3F the PCV is past the airfilter. The air filter does not need to filter it as it is "clean" air that is just full of oil/gas vapor. How do you have it run?
If it does not go easy just force it David Dearborn Atlanta GA www.urbanlandcruisers.com TLCA Associate member Got a question, need an opinion, do you love puppies, just want to talk or stage a cage match? For all of these issues and more PM Mark, 65SWB45. |
I had a J**p that had mad blow by. I just put a really long hose on with an nice "S" bend in it. When I got to work, I uncoiled the snake and drained the oil back in. I found a trick chrome breather to stick in the end as well.
“He who goes unarmed in paradise had better be sure that that is where he is.”—James Thurber. |
