Setting up Mini Knuckles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-18-2004, 10:00 AM   #1 (permalink)
Member # 19739
Just got my new Hy-Steer in and I had a question about setting up the knuckles. I have a 78 and when I did the rebiuld the 1st time, I had cone washers and split washers on all 16 studs. In the new kit I got from Marlin, there are 8 split washers, 8 cone washers, and 8 regular washers. Obviously, the cone washers hold the arms on at the top of knuckle, but where do the split washers go and where do the regular washers go? I am guessing that the regular washers go on top of the cone washers, since the cone washers are split themselves. Then that would mean that the splits go on the bottom on the bearing caps and then bolts. Right? They are mini-truck knuckles, but I didn't want to post up in there and waste their "HARDCORE EXTREME" time
Thanks guys-
Keith
By the way, Marlins Hy-steer should be the only one out there. Machined billet arms that are 3 times the size of the stock arms in every dimension, and $60 - $150 cheaper than any other company and have the most complete kit. I am a very happy customer
[QUOTE=Father Guido Sarducci]Beauty is truely in the Eye of the [COLOR=DarkOrange]Tiger[/COLOR].[/QUOTE]
Del3030k is offline   Reply With Quote
Old 01-18-2004, 11:36 AM   #2 (permalink)
Member # 19739
Replies???? Is this thing on????
Come on, I need to get these done....please?!?!?!
Old 01-18-2004, 02:33 PM   #3 (permalink)
Member # 507
Have you contacted Marlin? He should be able to answer your ?
78fj40 alum tub 2.5 lift and lots more
mobiltoy is offline   Reply With Quote
Old 01-18-2004, 02:38 PM   #4 (permalink)
Member # 1599
Location: Indianapolis, IN. Home of the Brickyard 400, Indy 500, and USGP!
Send a message via Yahoo to SpaceGhost
Mini truck knuckles don't have cone washers in the bottom cap. Did you get the correct stuff?
Mike "SpaceGhost" Smythe
R U gettin' it?
UROC Team #180 running:
BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)!
SpaceGhost is offline   Reply With Quote
Old 01-19-2004, 12:52 PM   #5 (permalink)
Member # 3931
Send a message via AIM to Adam F
Yea Keith, just regular washers and nuts on the bottom 8 studs, and cone washers and regular washers on the top 8 studs.
Get it put together so we can wheel!!!
http://staff.4x4wire.com/adamf/
Adam F is offline   Reply With Quote
Old 01-19-2004, 01:15 PM   #6 (permalink)
cruzila's Avatar
Member # 6650
Don't forget that 8 cone washers per side are torqued to 35 lbs and 4 per side are 75 lbs.
Scott Johnston
Rubicon Trail Foundation
Founding Director and Past President 2010-2012
WIN a fully built Toyota pickup at Cantina 2013
Davez Off Road and Trail Gear are supporting Rubicon Trail Foundation
Racer Jack tm
Almar Mfg 530-333-2496
Find us on Facebook
cruzila is offline   Reply With Quote
