Member # 12349
Benders
OK, I have been waddlling thru the search over in Gen 4x4
then I decided, Hell I don't know half those guys, nor trust them. so those of you that own benders, or have used one, only reply.(Nolen, watching don't count) If you had a grand to buy a bender.... brand and options......my only requirement so far, is that I can later adapt to electric/hydraulic. Post away....... Have any idea how many replys to the "bender" search involve some gay club out in California?????? Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] Last edited by texican; 01-21-2004 at 05:46 PM. |
Member # 23222
Butch,
I am very happy with the Hossfeld #2 universal bender that I have upgraded with hydraulics. Hope that helps. Good luck! -Steve http://www.hossfeldbender.com/ourhistory.htm
Member # 899
pro-tools all the way customer service is tops and the product is clean and well built .
as for which bender is better pro tools , jd2 or any others like this they all bend the same jd does not produce a better bend then pro-tool or vice versa i will say pro tools delivers a nicer product jd's can be rough around the edges . what i think it should boil down too is customer service , what vendor will keep his promiss and who has a competitive price . have fun bending alan
tubing $2 dollars per foot welder $800 grinder $70 tubing bender $500 having the skill to actually build something nice priceless |
Member # 21523
Butch,
I have had great luck with our JD2 benders.We have the model 4 but also have the model 3 manual bender in the shop for lighter jobs.You can upgrade the model 3 to a hydro later on for not much more. Simon |
Member # 4139
Butch,
Go through the bending 101 here on Pirate. There is some excellent info on how some folks have added an air powered hydro set up for like only about $100 by buying the ram direct from someone like harbor freight (need the one that can go horizontal vs most have to be mounted vertical). I only found it from hanging out on the hobart welder site and got referred back to here for it. Haven't bought the bender yet, but will in the next few weeks. Everyone I talked to said either stick with Protools or JD. As usual though, I know like next to nothing.
Warning: This user does not play well with others. |
Member # 10714
Very happy with my Pro Tools 105HD. Ordered from the factory, had it witihin a week, with 3 dies, shipping, degree ring, stand, handles, etc., for about $1100. People will argue all day about the accessories but this is a good bender with billet steel dies. Shipping is nothing to sneeze at, cosidering we're talking about a buncha steel here.
Chubby Chaser
You don't trust me Butch, I thought I knew you better than that
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
Metal-tech'in
Member # 10420
Butch,
I have been real happy with the JD2 model 4. Over this past year I have been looking at production benders from 6-30K and quite honestly the little model 4 beats or hangs w/ most under the 10k mark. (Iron worker is coming in first!) Yes with a pump it will shoot you past your $1k budget, but you may not need to buy one. I would think you might be able to draw hydro pressure from your muffler bender you have. If the output pressures are similar you might be able to put a standard port-a-power quick disconnect on one of your ram lines on the muffler bender. This would allow you to just unplug one line and plug it into the ram on the model 4. Even if the pressures are greater, you can put an inline regulator so you don’t over pressurize the ram on the tube bender. You cant beet being able to easily roll your bender around, or have it rotate if you have 10’ hanging out of it, as you bend. From the JD2 site: "With a high quality US or Swiss made 14" stroke hydraulic cylinder - $1045" Granted this is with no dies, but that was not part of your question. ![]() Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service! |
Moderating Midget
Butch, go with the ProTools and use Billji in the vendor section.
That is Mike Green, fellow Blacksheep and he will do you right. (Yellow jeep with hydrolics w/P option)
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
#12 (permalink) |
Member # 3245
I have a JD2, but I agree with the junkie - its about customer service. I would spend my money on dies instead of hydraulic - you can add that later - you will make fewer mistakes by starting out manual.
If you don't have one, I would buy a digital level and buy/make a clamp to use it on tube - very handy. Don't know if buying a degree ring is worth it - I have one, and I think its useless - a big pr0tractor and some vee blocks is better Just my $0.02, Jim
Never subscribe to a conspiracy theory when the stupidity theory will suffice. |
#13 (permalink) |
My cage was all done with a ProTools hydraulic with the HD seal kit (er something like that)....anyways, very impressed with the bends, very clean, and all the projects my fab guy has turned out look great off that machine.
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
#14 (permalink) |
Member # 2482
JD2, manual, 1.75" die.
Works great, needs air hydro in a baaaaaaaaad way. But with a longer handle on the bender it's just a bunch of walkin back and forther in the driveway. ![]() I agree, spend the money now on a few extra dies and upgrade to hydro later.
GET IT Dave!! save me a spot bro......i'll miss you... |
#15 (permalink) |
Member # 39
I have had a JD2 model 3 for a few years now and I think it is a good bender for the price. I have never had to use the customer service so I can't comment on it. It is a bender and it bends.....why do I need to call customer service (unless something brakes)? Spend the money on the dies first, then hydro if you begin to do lots of tube work. For my uses, there is no reason for hydro since I don't use it that often anymore. I have 2", 1.5" and 1" dies.
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank |
#16 (permalink) |
Member # 12451
One Big tip! Buy it yourself and own it yourself.
But Having had a pro-tools 105 before it was nice but here's my research I've been doing myself, getting ready to buy one again. M-TECH SUPPLY fabrication NE5 Tube Bender $370.00 1.75" Round Tube Die Set $209.99 75" Round Tube Die Set ?$105? -------- $684 105 bender has 1/2" Thick Arms HD 105 Bender has 5/8" thick main arms pro-tools reccomends HD bender when using 2" diameter dies hd 105 bender---- 282.75 105 bender------- 239.25 degree ring------- 118.00 1.75x6x240---------204.45 1.75x7x240---------243.60 ---------- 808.05 JD2 Model 3 Bender w/Degree Ring W/O Handle $266.50 M3B Round Tube Die Set - 3/4" (2.25-180) $105.00 M3B Round Tube Die Set - 1 3/4" (5.5-180) $200.00 -------------- $571.50 Thus with all that math. I'm down to the JD2 model #3 if you look at the pics the M tech and JD3 pictures are exactly the same. Both the Mtech and JD3 come with degree rings on them with the bender. A degree ring probably isn't needed that much but for repeat bends it would be a good thing. The Pro-tools I had didn't have a degree ring (can be purchased for another $118) but a square to find 90deg and a custom angle finder thingy are great. There might be differences between the Mtech and JD3 but my web reseach had the exact same pictures with about $100 price differences. The JD2 model 3 had a degree ring on it... I'm toying with the JD2 model 3 also because the manuf is located in Florida which is directly on the route home my parents take from their boat when they come visit me in Misery(Missouri) so I might just have them pick the bender up and save shipping. I'm no bender pro but have used one and have had one.. The Protools and JD3 can easily be converted to Hydro as well. A great feature in my opinion. PIcs are at http://www.jd2.com/M3B_Features.htm http://mtechsupply.com/display.php3?getcategory=Benders Sorry don't have ability to shrink em for posting here at work. I'll let the pro's respond now. EC out.
Erik FJ45, FJ40, FJ62 TLCA #5303 Secretary |
#17 (permalink) |
Member # 12451
Oh.. And don't waste your money on a stand or handle. Put some anchors in the shop floor and weld a stand up. Handles are usually 1x2" rect tube. Stands are a 2"x 3/8"plate on a 2x2" square tube welded to a plate on the floor.
You can also use the anchors for other stuff.
#18 (permalink) |
Member # 14953
wngrog
Pirate4x4 Addict! Butch, go with the ProTools and use Billji in the vendor section. That is Mike Green, fellow Blacksheep and he will do you right. (Yellow jeep with hydrolics w/P option) ya get it from Mike green he quoted me one of the best deals around. supper nice guy and he i think he is a texan
1964 fj-buggy (grass hopper) 42 tsl, bead locks chevy 350 propane 2.5 ton rockwells f/r ram steering onboard air, onboard welder onboard attitude. www.lcspec.com |
#19 (permalink) | |
Member # 12349
I see you are one of them Benders tho half or more of the search results come back as references to you guys Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
#21 (permalink) |
Member # 2567
Check out www.blindchickenracing.com and look under tools, he shows how to build a hydro jack version with the pro tools die.
I had a JD that worked really well. I'd rather get the kind with a jack next time. Do what I did, buy it, use it and sell it when your done. I was able to sell mine for what I paid for it. -Stumbaugh
64 FJ45 LWB TLCA #3531 |
#22 (permalink) |
Member # 6167
I have a JD2 model 3 and am very happy with it. I also like JD2 customer service. I orginallly bought a 1.75" and a 2" die. I did not use the 2" die as I do not need tube that large yet. After 1 year they swapped out the 2" die for a 1.5" die and charged me nothing. I relaize the shipping came in the price difference between the dies, but I was surprise to see it show up with no shipping/ restock fees.
I think most of the benders spoken of in this thread are excellent, but if you Know someone who at least recognizes your name in a positive way, thats who to get your bender from and what they sell is the bender you want. - Keith |
#23 (permalink) |
Member # 14670
No expierence with benders, doing a bit of reading and really like this particular setup.
http--www.mindspring.com-~jayk5-bender-
Ride it like you stole it. |
#24 (permalink) |
Member # 14670
Try this again.http://www.mindspring.com/~jayk5/bender/
#25 (permalink) |
Member # 9576
JD2 Model 4... Fully hydraulic.
Made the mistake of "saving money" by buying a electric pump (Barnes) off ebay. Then rigging the electric solenoids for pressure/hold. Then running around to find all the fittings. Turned out my surplus hydrualic ram -- part of a Snap On kit for doing BIG 18 wheel king pins -- didn't work. Ordered a new Nike Ram from JD2. So "saving money" meant about 8 weeks of running around collecting everything to work. Sheesh! Only comment... only bend clean tubing, and keep it greased. The dies will last forever doing that. Worst thing about no shop... having a bender in STORAGE while paying off credit card debt. You told me to keep the FJ40, which I have.... but really should sell off my bender, Plasma Cutter, and a few other things so I'm not paying $12% interest on stuff IN STORAGE!!! ![]() Keith... cool. Irony, I bought a 1", 1.5", and 2".... and only used to 1" before putting everything in storage. ![]() FJ40Guy ![]() P.S. Changed my user name... ex is stalking me as she didn't like what I posted in Chit Chat. How the fawk she found me on this BBS I haven't a clue... damn she is scary!
