Radiator for 350 ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-23-2001, 03:15 PM   #1 (permalink)
Junkyard's Avatar
Member # 522
Post Radiator for 350 ?
My stock FJ40 radiator just isn't cooling my 350 worth a damn.
I saw a thread a couple months ago about what radiators folks were using in their cruisers with 350-v8 conversions, but I wasn't looking to replace my radiator then. Now I am, and the thread is gone.
Where can I get a good radiator and what's a good size, and (last question) how did you mount it in your engine compartment (did it just bolt right in, or did you have to fab up a mount).
Probably get a new fan while I'm at it - I don't like my cheapo electric fan.
Thanks!
- Dave
You haven't lived a full life until you've delivered a baby in your bathroom at midnight...
Junkyard is offline   Reply With Quote
Old 08-23-2001, 03:58 PM   #2 (permalink)
Member # 4569
Post
I had the same problem. However, I originally fixed it by converting my original radiator to a (5) core. That worked well. Now I run (3) core aluminum cross flow GRIFFIN. It runs 185-205deg. DAREN
99landrover is offline   Reply With Quote
Old 08-23-2001, 04:02 PM   #3 (permalink)
Junkyard's Avatar
Member # 522
Post
I've looked at the aluminum Griffins. What size is your radiator and how did you mount it in your cruiser?
- Dave
Old 08-23-2001, 04:27 PM   #4 (permalink)
Member # 487
Post
don't know if chad is still making them, but redwood radiator made a four core with dimpled tubes that cooled some pretty hot running v8's, including bruce lutz's.
floyd bufkin in colorado, swears by a griffin and a black magic electric for this v8. said the griffin he got fits in the stock mount.
Jay
rubytoy is offline   Reply With Quote
Old 08-24-2001, 08:34 PM   #5 (permalink)
Erik D_lux's Avatar
Member # 1007
Post
My rad is stock top and bottom tanks with 5 core never had a problem even running for 4 hrs in the heat going to moab (105 deg) Almost any shop can do it. Mine only cost $225.
[B][COLOR="Gray"][SIZE="4"][url]www.DLUXfab.com[/url][/SIZE][/COLOR]
[/B]
Erik D_lux is offline   Reply With Quote
Old 08-24-2001, 08:54 PM   #6 (permalink)
Member # 293
Post
I also used one of Chad's 4 cores with the dimpled tubes. Lowered and moved my radiator mounts to the drivers side about an inch to get the fan closer to center on the radiator. Used a Steward stage one water pump, that pumps about 30% more than stock. For a fan I used a 7 blade off a Cadillac hooked to a K-5 Blazer fan clutch. Thermostat was also a Steward 180 deg. drilled for flow. So far the engine has never gone above 185 degrees.
Dave67cruiser is offline   Reply With Quote
Old 08-24-2001, 09:01 PM   #7 (permalink)
coyote's Avatar
Member # 170
Post
I use aa 2 row with 1" tubes from Ron Davis...no issue's here unless you run your 350 greater then 15 degree's advance...then it overheats other wise select the thermo and add 7 to 10 and your done....180 baby...at 110...
Red Racer I
Toyota FJ62
coyote is offline   Reply With Quote
Old 08-24-2001, 11:21 PM   #8 (permalink)
Sixgun's Avatar
Member # 515
Send a message via ICQ to Sixgun
Post
Originally posted by Junkyard:
<STRONG>I've looked at the aluminum Griffins. What size is your radiator and how did you mount it in your cruiser?</STRONG>
I recently purchased from summit the 26" x 19" (GRI-1-25222-x) and got a set of brackets from Arndog on this section. The brackets were easy to install and the rad fit without any inner headlight bezel trimming. my average temps on the road 180. Average temps wheelin 190-195. Griffies are the way to go and for the price of a 182 bucks, you can't beat it.
[ 08-25-2001: Message edited by: Sixgun ]
A slightly modified 69 FJ40..
Sixgun is offline   Reply With Quote
Old 08-24-2001, 11:28 PM   #9 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Post
Is the radiator the problem, or is it the cooling *system* as a whole?
Fan too far away from the radiator, poor shrouding, blocked airflow, etc. are all common problems...
Not that getting a new radiator won't help, but maybe a close look at the system as a whole with some changes there can solve the problem without the expense of a custom radiator.
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote
Old 08-25-2001, 09:28 AM   #10 (permalink)
Member # 1926
Post
Yup, gotta agree.. Griffin radiator are the way to go. I have wheeled in 110 degree temps during labor day and my FJ40 with a 350 TBI motor never got above 220 degrees.
Charles
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
