Member # 1176
My 2f leaks oil where the skid plate is spot welded to the oil pan. Whats a good fix? I don't want to buy a new pan. I was told to remove the pan and mig-weld the skid plate perimeter to the pan itself. I was hoping for something easier. I have an extra cork gasket!I think this may be a common problem as I have seen several other fj40s doing the same thing. They get pinholerust between the skid plate and pan . What have you guys found for a cure??
bennett
June 28th 2003 |
Member # 2143
Back when my brother had a 2f in his '55 he had the exact same problem
Took off the pan sent it to an engine shop to be hot tanked (ie: totally 100% clean) then he simply laid a pool of braizing over each of the spot welds from the inside <IMG SRC="smilies/biggrin.gif" border="0"> |
Moderating Midget
Could you lay a bead between the skid plate and the oil pan?
Mine does the same thing and I can not get my $%#@$$ oil pan loose. I beat it to a pulp and hammered a wood chistle at it for 45 minutes and could not get it to break loose. I say screw it <IMG SRC="smilies/rolleyes.gif" border="0">
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
Member # 582
The brazing idea sounds fine, and the perimiter weld has always worked...
To get a stubborn pan off... Place a bottle jack against the frame and a 2X4 section on the side of the pan @ the skid plate... Apply pressure and go have a beer :-) Provided you removed all of the bolts from the pan... the pan should be hanging from the engine or lying on the ground when you get back. Cory
FJ-40 HP 2F SM420, 4:88, Locked F&R, 98" WB, Sawsalled, Welded, dented, 36" SX's, 3spd gears in a 4 spd case, Newfields, Lots of other mods all done by Me... Towed to the trail with a 97 Crew cab 4X4 PSD (slightly improved) |
