Crawlin Cruiser has a line on a 60 rear for me and I need just a little more info before I purchase and dedicate.. I have a 69 FJ which means that I'll have to re drill the pinion flange to fit the smaller pattern of early FJ's ( no problem I have a new late model pinion flange I can re-drill to match driveshaft bolt patterns) I think I'll have to use my stock 4.11 w/locker 3rd member and am wondering if my stock 69 third member will bolt into the housing and inner axles of the FJ60....This seems too easy, I mean all I'm looking at is 2 perches $20, to weld onto the top of the axle and drilling a spare late model pinion flange to match the bolt pattern s of the early FJ's (it's the round after market type so I have room on the flange to redrill the holes) what am I missing?? Jeff said that the rear is easy to match up on perches cuz the rear springs are farther apart than the fronts, fronts are 27 1/4" rears are 32" and he's right, anything else?
is it really this simple?? Thanks, Rick
A slightly modified 69 FJ40.. |
Member # 474
Rick:
Putting the FJ60 under the rear of your 40 will be a snap. As Jeff has said, setting the perches is no big deal. While the axle is out of the rig take time to weld brackets for a traction bar on. The third members are interchangeable, with two caveats. 1) your 67 third member may have 9mm bolts holding it in, and the later 40's and 60's use 10mm. All you have to do is drill the flange holes larger. 2) the early 40's have course spline side gears in the third members - later 40's and 60's have fine spline, so the swap wont work, unless you get the side gears swapped over to fine spline. You know, it just might be worth you getting the FJ60 third re-geared, and put the lockright in. The bonus is a fine spline pinion, which is stronger. Also, dont waste your time and money doing a rear disc conversion on the FJ60 axle - the rear drums work great, they are self adjusting, and have a rear emergency brake that works. I will try and find Steve Tetu's number - I dont know why they dont put it on the web site? Cheers Andy
Rock on with the RockDogs! |
Thanks for the info Andy, my 3rd member is a 69 but I'll check it for bolt size. This might be a stupid rookie axle swapper question but didn't I replace the side gears with the lockrite flanges and couplers?? if so then it won't be a factor when swapping 3rds. Unless you are talking about the inner axle shaft spline count, but then they would sell 2 different types of lockrites for Cruisers.
-Rick
Member # 922
A '69 3rd will go into the FJ60 axle just fine, it is fine splined inners as well. the only thing that might not match up is the flange, but you're aware of that already. Yep, it's an easy install for sure.
Sweet!! it will be a hell of a lot easier than the front it's going to compliment. I'll have to cut off the 9mm pitched brake ends and swap in the 10mm's but I'm going to run a mini 7/8" bore master cylinder so the rear drums should be happy. (knock on wood)
<IMG SRC="smilies/biggrin.gif" border="0">
Member # 3760
Hey sixgun are you thinking about a 60 front end aswell? Tell me when you are coming up and i will show you my setup
83 BJ60 DD,74 FJ40 crawler Be Canadian, Eat beaver!! |
#9 (permalink) | |
Member # 3760
#11 (permalink) | |
Member # 2119
How many licks does it tak.... AWWW JUST SUCK IT |
#12 (permalink) |
Well I picked up the FJ60 rear axle, scraped the rust off of it, opened it up and found 37 x 10 stamped on the ring gear. Which is ok, because thats what it was advertised as and all I have to do is swap in my 4.11 third member with lockrite. I ground off the old spring perches and ordered a set of Warn 3" (3" X 5 1/2" X 1/4") spring pads. So all thats left now is to get an adapter to plug my 9mm brake end into a 10mm.....any ideas???
will my stock 69 master cylinder have too much pressure for the FJ60 rear drum setup?? two slave cyinders instead of four)I'm thinking about doing the rear before the Hybrid front, but if it's too much of a pain in the ass I'll just wait and do them both at the same time.....in fact it will save some brake fluid. Macgyver; the benefit of a FJ60 Axle in the rear in my instance is the fact that my Hybrid front end is going to be a few hairs shy of 60" and the stock rear is only 55" So with a FJ60 rear I gain 3" of width, a better emergency brake setup, and a better drum brake setup (2 slave cyinders instead of 4) It's a done deal, all that left to figure out is the brake issues (I have an 83 mini truck 7/8" bore master cylinder with booster sitting in the shed) which I plan to branch down to the chevy discs in the front and run one line for the FJ60 rears.
#15 (permalink) | |
Member # 474
#18 (permalink) |
Member # 3760
hey rick, you should have got perches from steve when you were up there. They're 60 canadian and they long. BTW I saw you guys leaving in the red truck as I passed you in my blue toy
#19 (permalink) |
Damn, missed ya on the street, we had to get back anyway but I would have liked to have seen how you plumed your brake lines. I use WP's perches the biggest ones they make 3" x 5 1/2" there preety stout and only cost 10 bucks apiece. I should have picked up a 9mm brake fitting from Steve, that way I could have had a hard line made, 9mm to 10mm, now I have to disable my rig to pull one off so I can have a line made when we put the rear end in this Sunday. <IMG SRC="smilies/frown.gif" border="0">
#20 (permalink) |
Member # 2119
Hey Rick I called you back man what happened to ya? I got busy weldin up the rear in the 5, now its lincoln locked rear and lockrite front. See you Sunday morn you bring the donuts I will brew the coffee. Donuts optional I dont need them.
Oh and by the way I got your 9 to 10mm adapter hangin!!!!! <IMG SRC="smilies/eek.gif" border="0">
#21 (permalink) |
I hope you have a double flare brake tool hangin man <IMG SRC="smilies/tongue.gif" border="0">
I got perches, 10mm fittings, Toy mini brake hose, erl, ohh and a nicely cleaned and painted fj60 ass end minus the 3rd member (makes it easy to move around) brake pads are 24 bucks at schucks(both sides) and I paid 19 bucks for a new hose......I'm liken the financial future of this swap. I got your donuts hangin man <IMG SRC="smilies/biggrin.gif" border="0">
