Member # 19
I have a 72 FJ40 with 4 wheel discs. I've been using the stock drum brake master, which works fine, but it is failing. Is there a better & newer master that would be a direct bolt up or am I stuck with a rebuild or conversion project?
TNX Kurt
Real Toys .......... ___ aren't bought .. _[o=o]_ they're BUILT! . []-o--[] "Won Ton" Fo Dee |
Member # 4794
Put in a FJ80 master from 98 on. This is a disc disc master and has a built in proportioning valve, the valve adjust itself. The master will bolt on to any cruiser booster, if you are running one, or will bolt on to your firewall. It runs about $85 at your local auto parts, or better yet call your local recking yard and get it cheaper. <IMG SRC="smilies/biggrin.gif" border="0">
70 Toyota Landcruiser FJ40, 400HP 327, SM465, 3SPD T-Case, 38" TSL SX's, 15x10 MT's etc.... and more to come. 82 Toy 4x4 Truck, 4" lift, 33's, 150HP 22R, rebuilt 5spd and Tcase, stainless braided brake lines, powder coated frame....and more to come. |
