Member # 6863
Temp sender bushing sleeve v-8 v8
Since this has come up a few times before in the past weeks, here is what you need to make stock temp gauge work in your v8 conversion...
The bushing on the left is the part Advance Adapters "tricks" you into thinking you need(with NPT threads-same as the Toyota part), when infact the part to the right is the stock temp sender bushing that toyota uses in the heads of F and 2F engines. They look similar right? They are interchangable, and the only difference I can see is the fact that the threads end just a bit further from the hex on the AA part than the Toyota OEM one you have in the engine you just removed. So, what you need to do is take out the sender and this sender bushing(the one you already have in the F/2F head) and you can screw it directly into the Chevrolet Intake manifold with out and "adapter" like AA claims...
I have enough projects for the next decade. Need two? Last edited by cruiserbrett; 02-28-2004 at 08:35 AM. |
Member # 12758
Correct they are all NPT threads not metric standard... Which is why, when you buy an aftermarket temp gauge (mechanical or electric) it will work with pretty much any car.
Member # 37807
bump! i just picked up one of these adapters from toyota . and it looked exactly like the one on the left .even had the green thread sealer on the threads .
1978,fj40 small block SOA, sm465 3sp t-case 38.5 swampers |
Member # 1858
What did Toyota want for it?
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
#6 (permalink) | |
Member # 10429
Stupid metric thread on the plug...
Rich Q. FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's |
Member # 37807
can't quite remember i bought it with a bunch of other stuff . something like 6 or 8 bucks canadian ,easier for me to get it through the dealer than order from AA in the states .no shipping .maybe my receipt will show up one day and i will post exact price
EDIT $8.86
1978,fj40 small block SOA, sm465 3sp t-case 38.5 swampers Last edited by pbgbottle; 10-19-2007 at 09:07 PM. |
