Tubeing in hf bender - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-08-2004, 06:39 PM   #1 (permalink)
Member # 11341
I modified the 1 1/4 die for the hf bender to bend 1.75 tubeing. First I widend it out to fit with the flap wheel on the dremmel then I welded a strip of steel to the lip to make the sides taller then I finished by running a beed with nickel rod along the inner rim and grindind that smooth with a flap wheel. I can bend a full 90* without kinking. This is a good alternative if you have more time than money.
Yeah I know I cant spell!
goldenarrow is offline   Reply With Quote
Old 03-08-2004, 06:41 PM   #2 (permalink)
Member # 11341
2
Old 03-08-2004, 07:47 PM   #3 (permalink)
Big DW's Avatar
Member # 9950
that's what I like to call the pidgeon squirt welding method....but hey...looks like it will do what you need it to do....lets see some of the tube work golden arrow...
[SIZE="4"][COLOR="Blue"]Operator, Quick...give me the number for 911!!![/COLOR][/SIZE]
Big DW is offline   Reply With Quote
Old 03-08-2004, 08:25 PM   #4 (permalink)
Member # 11341
Actully it looks better in person, and I did it on a old stick macine with rod I had never used before. the reason it looks ugly is I had to start and stop so many times cause I burnd up a rod every 3 inches my beads acualy look pretty for stick. then I had some nickel rod left over so that is what the three tack welds below the beads are.
Old 03-08-2004, 08:34 PM   #5 (permalink)
Member # 11341
It was a little hot for the size rod by I wanted it good and strong
Old 03-08-2004, 10:05 PM   #6 (permalink)
GloNDark's Avatar
Member # 2482
hell of an idea
Got pics of the tube ya bent with it?
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is offline   Reply With Quote
