Does anyone make lower gears for fj40 transfer case? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2001, 01:22 PM   #1 (permalink)
Member # 6515
Post Does anyone make lower gears for fj40 transfer case?
I'm building up a 1979 fj40 and this would make life a lot easier for me. Do they exist? Does someone plan on making them? How much would they cost? Input is greatly appreciated.
[ 09-05-2001: Message edited by: busdrivah ]
busdrivah is offline   Reply With Quote
Old 09-05-2001, 01:46 PM   #2 (permalink)
Member # 171
Post
Check with Marlin, I think they do but don't quote me. <IMG SRC="smilies/biggrin.gif" border="0">
"Fawk no it isn't safe, we're at 18,000' on K2 in a blizzard!" Bill Pierson
Sloan is offline   Reply With Quote
Old 09-05-2001, 04:00 PM   #3 (permalink)
Member # 474
Post
Sorry guys, Marlin does not make the Cruiser Crawler gears anymore - actually stopped a long time ago. I have heard about some Aussie gear sets, but I think they are for the later split cases, and the ratios werent all that great. If you dont already have an SM420 with a 3 speed tcase I would strongly recommend that. After that, you could go Dana 300 with a centered rear diff, or jump straight to an Atlas.
Rock on with the RockDogs!
KrustyKruiser is offline   Reply With Quote
Old 09-05-2001, 04:16 PM   #4 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Post
There is always the possibility of going to a dana 18 tcase. The gear choices are prety impressive. Although they are expensive... I heard that someone is making a shorter adapter for the 203/LC tcase if it ended up only lengthening the drivetrain by about8" or so it would be great!!!!
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 09-05-2001, 04:42 PM   #5 (permalink)
Member # 474
Post
If you want to go that route the get a late model split case off a 60/62 and use Jerry Nichols 203 adapter, ie 465/203/split case. There still may be a drivetrain length issue for an F powered 40. Check out the adapter at: http://www.mudrak.com/
Old 09-05-2001, 07:12 PM   #6 (permalink)
Member # 3942
Post
Krusty's on the money! FWIW, the split case is much stronger and the gear ratios are pretty close to the much vaunted early "3-speed" t-case. There are two Aussie gear projects that I know of, one from Marks 4WD and one from RockHopper, neither of which I've seen in person. I don't know of anyone with them in the US, either. One's less than 3:1 and the other one isn't much lower, like 3.1:1. The problem is that the tolerances inside the split case don't allow much lower gears. Still, coupled to the NP203 doubler you're talking (2.276:1 x2)= 4.55:1 in the t-case, not bad!
60seriesguy is offline   Reply With Quote
Old 09-05-2001, 07:52 PM   #7 (permalink)
Member # 293
Post
I have a 1985 split transfer case in my 40. I used Gear Master gears from Austrialia. Their avaliable from AA and give you a 2.81 low, not that great but lower than stock. Even at that ratio you still have to grind a bit out of the case to make them fit.
Dave67cruiser is offline   Reply With Quote
Old 09-05-2001, 11:01 PM   #8 (permalink)
Member # 1368
Post
The last time I talked to Marlin he was working on cruiser gears that would fit in the Wardens billet t'case housing. But the Warden case is around 1400 I think. For the money you would spend you may as well go with a Dana 300 or an Atlas. I am setting up the SM420 with the stock t-case for cheap.
69 FJ40, SOA, SR, PS, Chevy 350, SM420, ARB's, Disc brakes; Some assembly required!
rustbucket is offline   Reply With Quote
Old 09-06-2001, 12:27 AM   #9 (permalink)
Member # 256
Post
I run a sm420 and late model three speed
case it rocks..
I would buy the atlas before the wardens.
because the front out put on the toyota
is very small..
but you dont hear of a lot of peopple
breaking the toy output?????
Light travels faster than sound.
That is why some peopple appear
brighter than they are before they
speak.
Land Crusher is offline   Reply With Quote
Old 09-06-2001, 02:44 AM   #10 (permalink)
Member # 256
Post
I know that some peopple have figured out
how to use the toy truck gear reduction
in front of the 40 case.
wish I knew how they did it?????
would only add 6 inches.
speak.
Old 09-06-2001, 02:54 AM   #11 (permalink)
bubs's Avatar
Member # 3715
Post
Yes an australian company makes gears for 40's but they are for the split cases
marks 4wd adaptors
1994 Toyota Hilux
Budscustoms - Australian Custom Parts & Fabrication
http://www.budscustoms.com.au
bubs is offline   Reply With Quote
Old 09-06-2001, 04:08 AM   #12 (permalink)
Member # 2880
Post
Never looked at it but www.marks4wd.com
Guts is offline   Reply With Quote
Old 09-06-2001, 09:59 PM   #13 (permalink)
Dan
Member # 33
Cool
I have been runing the AA SM465-NP203 set up for 3 years and it is great. Strong and not very much money. Check out the Pirate4x4 tech story for more info.
<IMG SRC="smilies/blender.gif" border="0">
[b]Dan
77' FJ-40, Dual T-case 128-1 NP-203, TBI-350, Blender, 488's, Welder, 4WDB, Air, HAM[/b]
Dan is offline   Reply With Quote
Old 09-06-2001, 10:36 PM   #14 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
Send a message via AIM to lttlbddy Send a message via Yahoo to lttlbddy
Post
I saw a set of Marlin Gears for sale in the TLCA mag about a year ago. Something like $1600 just for the gears. Then about a month later, I do a favor for Marlin, stop and pick up a t-case and (guess what) a set of Marlin gears. Picked them up in LA and met Marlin in Bakersfield. It was the same set of gears. This guy really wanted lower gears.
Haven't seen any since. He didn't make many sets.
Steve
Premier Digital Printing
Pirate Special - $25.50 for 500 Business Cards
Great Deals on Tri-Fold Brochures!
email - steveg@digitalisc.com
Office: 714 283-2073 * Cell: 714 293-8790
ask for Steven Gardiner (aka LTTLBDDY) or Donna
Large & Small Format Printing - Laminating - Bindery - Mailing
Don't go to Kinkos! Call Us.
Stickers here: Stickers
lttlbddy is offline   Reply With Quote
