Front Disc Conversion using FJ40 parts (not mini-truck) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-07-2002, 03:03 PM   #1 (permalink)
Member # 8421
Hey!
A friend wants to put front discs on his '72 LC, and has a line on some factory parts. He was planning to use the mini-truck discs, but might be able to get pieces off a '76 LC. I am wondering which parts he needs off this '76 LandCruiser - I know he needs the spindles, bearings, rotors, and hubs, but does he need the knuckles and the axle shafts too? We'd like to get away with only buying the parts necessary, to help keep down the shipping costs.
Thanks!
Richard
thecarman is offline   Reply With Quote
Old 01-07-2002, 03:21 PM   #2 (permalink)
Member # 6588
knuckles, steering arms, nuts, cone washers, hubs, tie rod,
in Oz, this is what needs to be done, as the disc fronts have bigger arms, different bolt pattern, larger studs, larger cone washers, different hubs, and different knuckles
best to just buy, everything, unbolt the eight bolts, remove the outers(with axles), bolt together, ship, unpack, install on yours
DONE!!
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 01-07-2002, 03:24 PM   #3 (permalink)
Member # 4687
He needs everything you listed and the following
birfields (plus inner axles to make life easy)
Knuckles with arms
"ALL" fasteners, cones and shims
dust covers/backing plates
calipers
Maybe the flex lines if they're in better shape then his
Basically, he would need everything but the housing and third member
steven@extremebends.com
Cruiser Parts
Some people are like Slinkies... not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Mud Guppie is offline   Reply With Quote
Old 01-07-2002, 05:55 PM   #4 (permalink)
MD11Fr8Dog's Avatar
Member # 5400
Send a message via AIM to MD11Fr8Dog Send a message via Skype™ to MD11Fr8Dog
He should just do what I'm doing, swapping my 76 front end onto my 75. That would be easier, wouldn't it?
Sean
8/75 FJ-40 - 2F, 76 DBs, SR, SOA 55 rear springs, PS, 36X12.5 TSLs, SM420/ToyBox/3spd tcase - 154:1, Mini-Longfields/Aisin hubs and front/rear ARBs.
:bounce2: [SIZE="3"][URL="http://gallery.mac.com/md11fr8dog#100070"]My Green Land Cruiser[/URL][/SIZE]:bounce:
03 Tacoma double cab, SR5, TRD, sliders, 3" Cornfed, Can-Back
TLCA #11877
MD11Fr8Dog is offline   Reply With Quote
Old 01-07-2002, 08:24 PM   #5 (permalink)
Member # 667
All the hard brake lines and the master cylinder and booster would help keep the hassles down.
Dave
Man who run in front of cruiser get tired,
Man who run behind cruiser get exhausted
-Chinese proverb
Beanz2 is offline   Reply With Quote
Old 01-07-2002, 09:22 PM   #6 (permalink)
Member # 3008
I agree. If you swap everything from the knuckes out It makes the swap easy.
Michael Harness, Owner [url]www.ACCToyota.com[/url]
71 FJ-40 SOA, EFI 5.0, NP435, 38.5 SXs
71-Cruiser is offline   Reply With Quote
Old 01-09-2002, 02:34 PM   #7 (permalink)
nuclearlemon's Avatar
Member # 1650
if he's running the dual master cylinder set up, make sure he removes the check valve from the front cylinder.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid sideways in a cloud of dust, flopping into the hole totally worn out, shouting ..."holy shit...what a ride!"
nuclearlemon is offline   Reply With Quote
Old 01-09-2002, 08:06 PM   #8 (permalink)
Member # 493
front discs
I pm'd you with a long reply on what I did.
mrgadget is offline   Reply With Quote
