Member # 6752
My Stock 1970 Landcruiser with a "F" engine has a leaky rear main seal. Is there a simple way to replace it. Ie without removing the pan, crank shaft and Tranny? HELP!!!!
Thanks in advance, Mark Caswell <IMG SRC="smilies/bounce2.gif" border="0"> |
Member # 4783
You need to remove the tranny and flywheel to change the rear main seal, but not drop the oil pan. First make sure that it is not leaking from the oil pan seal. Mine was leaking at the rear oil pan gasket and just tightening the bolts little stopped most of the leak. The freeze plugs for the oil gallery (behind the flywheel) can also leak. It is usually best to wait until you need to drop the tranny to fool with the rearm main seal.
Member # 171
Definitely check the rear of the gasket on the oil pan. When you replace that sucker get the Toyota gasket because the aftermarket ones don't seat as well and will eventually leak. Also when you have the pan removed if you are not replacing it make sure and take the time to lay it on the ground and get the edges that seat on the block as flattened out as possible to get the best seal. <IMG SRC="smilies/biggrin.gif" border="0"> The best way to replace the rear main seal without pulling the tranny is to just pull the engine and voila no hassle with removing the tranny.
<IMG SRC="smilies/biggrin.gif" border="0"> [ 08-28-2001: Message edited by: Sloan ]
"Fawk no it isn't safe, we're at 18,000' on K2 in a blizzard!" Bill Pierson |
Member # 6752
Thank you all for all your help. It was what I figured but didn't want to accept. I changed out a rear main seal on a 1989 Jeep 4.0 L. buy just droping the pan but I figured this would be a lot more difficult.
Again, Thanks!! Mark Caswell |
Member # 171
There is a kid in Ojai named Jessie that has a small 4x shop try and track him down. He drives a Toyota truck and runs with a good sized group of wheelers up there. He shouldn't be too hard to track down. I had him do my clutch a couple of years ago, nice price and no worries. I know that's pretty vague but that's all I got. <IMG SRC="smilies/biggrin.gif" border="0">
Member # 4783
Actually, dropping the tranny is a push when it comes to labor and difficulty compared to removing and replacing the oil pan and rear main cap. The tranny comes out pretty easy with a tranny jack.
