shackle angles.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-07-2004, 08:56 PM   #1 (permalink)
Member # 29301
shackle angles....
I am wondering what are the recommended shackle angles, if any?
My fj40 has extended shackles in the rear which are practically vertical...Is this a good thing?
I believe 55 springs are slightly longer and may add some additional angle...
Thanks ,
manny 72fj40
mr_manny is offline   Reply With Quote
Old 05-07-2004, 09:00 PM   #2 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
45* rake is nice, btu it really depends on what springs you are running.
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 05-07-2004, 09:05 PM   #3 (permalink)
orangefj45's Avatar
Member # 6816
you're just gonna have to drive it down to whitey's place one wednesday evening so we can pick it apart, woops, check it out!
Maybe you outta stick to legos!
orangefj45 is offline   Reply With Quote
Old 05-08-2004, 07:20 AM   #4 (permalink)
Member # 260
Send a message via Yahoo to woody
ih8mud.com
tech links
left column, other suspension tweaks
see my writeup on shackle relocation
also see my writeup on the 40-55 pack swap.
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote
Old 05-08-2004, 07:54 AM   #5 (permalink)
Member # 29301
Nice write-up, exactly what I was looking for.
Did you have to lengthen your rear drive shaft w/55 springs?
thanks for the links,
manny 72fj40
Old 05-08-2004, 08:23 AM   #6 (permalink)
Member # 39
You can't just set them at 45* if you have arched springs or they may hit the frame on compression and limit travel and/or bend your springs. Ideally you want them around 45* when the springs are flat or against the bumpstops. With the shackles near vertical, you will usually get a harsher ride and the spring has to flex more before the shackle will actually begin to swing.
Here is my shackle angle when the spring is almost flat and the axle is hitting the bump stop.
Eric
Parts for Sale --> D44 shafts, 6 lug rims, air tank
Eric is offline   Reply With Quote
Old 05-08-2004, 11:21 AM   #7 (permalink)
Member # 4783
The effect of shackle angle on the effective spring rate is quite complicated because it depends on spring shape, the spring arch and the length of the spring, which determine how the eye to eye length varies with compression. The greater the arch, the bigger the effect of shackle angle.
Because a flat spring actually shortens during compression, a backward facing 45 degree shackle actually increases the effective rate (as compared to a verticle shackle), but this negative effect is minimal because the eye to eye distance decreases relatively little in response to the vertical deflection.
For the 4 inch lift spring that I measured, the eye to eye length increases by about 20% of the vertical deflection, so having the shackle angle at 45 degrees would decrease the effective spring rate by approximately 14% compared to a vertical shackle.
The over riding concern is that the shackle have enough movement to allow full compression of the spring. If the shackle movement limits the eye to eye lengthening of the spring during compression, it is like having no spring.
Edit: "effective spring rate" is just a fancy term for ride quality. If you decrease the rate, you "soften" the ride.
Pin Head is offline   Reply With Quote
Old 05-08-2004, 03:14 PM   #8 (permalink)
Member # 260
if you put in FJ55 rear packs or reverse your FJ40 packs, it relocates your rear axle back 3.5" and does require driveshaft work.
Pin Head is spot on with his notes on angle....I ran stock shackles for a bit when I was running SUA 4" Softrides, and they would compress to the frame, even at the stock location. Reworking to a 45 degree angle required a ~3" overstock shackle to maintain the angle AND allow it to not hit the frame on full tweak.
Took some experimentation, but worth it for the ride and flex.
