t-case flange leak??
So I pulled off my front t-case flange today to re-drill for a CV pattern, and a bunch of gear oil poured out. Is this a seal problem or what?
Oh yea, it's a 1990 fj62.
'90 FJ62 LQ4, 4l80-E, 203/Split Case, 38" MTRs |
#2 (permalink) | |
well, there are many who know more than me, but here's my thoughts. When you pull the flange out, you are removing the sealing surface, as the i.d. of the seal rides on the o.d. of the flange. So, you probably don't have a leak, unless it also leaks with the flange installed. That being said, depending on how many miles you have on there, you might want to do some preventative maintenance (sp?) and replace the seal. Both of my output seals started leaking within a 5 months of each other, with about 360k miles on the truck, don't know if they've been replaced before (although i'm guessing they have). so, if you've got lotsa miles, might be worth the effort (minimal) to do it now. hth -Travis
'84 FJ60 Wanted: driver's side window regulator [email]tmanAg08@gmail.com[/email] TLCA #13379 gig 'em |
what he said, the flange is the sealing surface. if it didn't leak before you pulled it, and you are gentle when you reinstall it, no worries!
Mike "SpaceGhost" Smythe R U gettin' it? UROC Team #180 running: BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)! |
No leaks before pulling the flanges. The only thing is that the when I pulled the front d-shaft off, there was some oil trapped between the shaft and the flange. I don't think it's enough to worry about though.
Where would I find a couple of these seals anyway? THanks
Member # 19837
false economy not to replace the seal while the flange is off. NAPA has them
If it does not go easy just force it David Dearborn Atlanta GA www.urbanlandcruisers.com TLCA Associate member Got a question, need an opinion, do you love puppies, just want to talk or stage a cage match? For all of these issues and more PM Mark, 65SWB45. |
Member # 24169
i beleive like most transfercases, front ouput is a wet seal meaning it has lube so the the front bearing can get some all the time. lube between the flange and d shaft means you were leaking a bit throught the splines.
if no leaky before removal of the flange, reinstall, and clean the splines both on the transfer, and on the flange up with cleaner and shoot a bit of sealer (on the outer most flange splines) around to seal the splines from oozing.
TO EACH HIS OWN ** EMAIL ME click on my name scroll to "send email to HI C" ** |
