Changing lug studs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2004, 02:57 PM   #1 (permalink)
Member # 30511
Changing lug studs
I've gotta be doing something wrong here. I just started putting my 40 back together last weekend. I've had a broken rear lug stud since I bought the rig 3 years ago, so I figured I would change it out. If memory serves, these things are just pressed in right? I've got the axleshaft out, and was pounding the crap out of it. Wouldn't budge. I tried the same thing on my donor 60 axle and same result. Do I pound harder or should I bring it to someone with a press? I would really like a rolling chassis by next weekend, and this is buggin the crap out of me. Seems like it should be simple.
ken79fj40 is offline   Reply With Quote
Old 06-07-2004, 03:00 PM   #2 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Hit it harder..
Or use heat..
they are pressed in
BTW, just buy a new stud.. taking one out of a donor is a bit silly..
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 06-07-2004, 03:07 PM   #3 (permalink)
Member # 30511
Originally Posted by Jason M
Hit it harder..
Or use heat..
they are pressed in
Cool, will do. I was intending on buying a new stud. All the parts stores are closed in the sticks on sundays.
Old 06-08-2004, 04:14 PM   #4 (permalink)
Member # 19465
Send a message via ICQ to BumperJumper Send a message via AIM to BumperJumper Send a message via Yahoo to BumperJumper
Studs are cheap. I'd replace all of 'em, just for the piece of mind. I've caught wind of too many people doing restos who leave in old lugs and have 'em get sheared under higher than normal loads (muscle cars or old trucks with higher torque engines), and almost getting into accidents because of it.
Fully desmogged '88 FJ62 w/ 222K miles; Flowmaster exhaust, Mallory ignition, Tuffy center console, '88 Mazda MX6 front seats, fully Dynamat'd, four wheel discs
USAF Active Duty, proudly serving
BumperJumper is offline   Reply With Quote
Old 06-08-2004, 04:21 PM   #5 (permalink)
Member # 24859
you are supporting the flange and not just banging on the stud , right ?
peesalot is offline   Reply With Quote
Old 06-08-2004, 06:18 PM   #6 (permalink)
Member # 6863
You could lay a Mig bead on the button of the back of the stud(careful not to weld it to the flange ). that ought to get it hot enough to knock it out.
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
