Hysteer TRE question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2004, 09:03 AM   #1 (permalink)
Member # 1797
Send a message via ICQ to Cruiser Ken
I bought a set of high steer arms from rock buggy supply. When I got them they said they were drilled for toyota TREs. I assumed toyota meant FJ40 since the arms have the small bolt pattern (pre 79). The holes are too big for my FJ40 TREs. I had a 1-ton GM TRE laying around so I checked that as well. It's too big. So what TRE do you think fits? Mini truck? Is the mini TRE thread size the same as the FJ40, can I use my tie rod and drag link?
82 FJ45 94 FZJ80
Cruiser Ken is offline   Reply With Quote
Old 06-27-2004, 09:08 AM   #2 (permalink)
Member # 19739
FJ80??? That seems to be the most common toyota TRE used in the aftermarket HYSTEER kits. My Marlin HYSTEER uses those. Look on their website and see what TRE's they package with their KIT's and that should be you answer.
Keith
[QUOTE=Father Guido Sarducci]Beauty is truely in the Eye of the [COLOR=DarkOrange]Tiger[/COLOR].[/QUOTE]
Del3030k is offline   Reply With Quote
Old 06-27-2004, 09:49 AM   #3 (permalink)
Member # 1797
RBS doesn't have a pic or description of what comes with their kit. Mini truck and 80 series use the same taper but different threads for the tie rod. FJ80 threads are bigger. I'm going to go to NAPA with one of the arms and have them get a FJ80 or mini truck TRE to test fit.
82 FJ45 94 FZJ80
Old 06-27-2004, 04:11 PM   #4 (permalink)
Member # 1797
It is a mini truck/FJ80 taper. Bought some early mini truck TREs they are very similar to the 40 series TRE, same thread size, but bigger taper.
82 FJ45 94 FZJ80
