Adding oil to A/C
Fairly soon I'm going to get the stuff I need to service my A/C, and replace the receiver/drier in the process. The manual says to add a small amount of oil when replacing it, but how exactly do I add the oil? Do I just pour it in to the high (or low) pressure line while the system is open, or what?
Fully desmogged '88 FJ62 w/ 222K miles; Flowmaster exhaust, Mallory ignition, Tuffy center console, '88 Mazda MX6 front seats, fully Dynamat'd, four wheel discs USAF Active Duty, proudly serving |
Member # 13391
I have always poured ester oil into the compressor with the compressor out of the vehicle and let it sit for a few hours to work its way in. This could be completely wrong so you might want to get more info, but it has worked in the past.
White Trash of the Elwood Chapter - WFFD - TORC4x4.org - www.marksoffroad.net |
Member # 6863
You can normally just pour it in if the system is open, but make sure you use the right type of oil. Ester oil is for r134a IIRC, mineral oil for r12.
I have enough projects for the next decade. Need two? |
Member # 4828
You would normally add 2-3 ounces of oil to the drier. If other pieces of the system have been drained of oil, add that amount also.
I am assuming this is normal maint and not a repair? What type of compressor does it have?
David TLCA 14788 71 FJ-40 TBI 327 w/TH-350 76 FJ-40 "project" |
#7 (permalink) | |
Member # 28045
[FONT=Tahoma][COLOR=Sienna]'76 FJ40, '78 F-250 400ci, '84 F-250 6.9L, '96 F-350 7.3L, '02 F-250 7.3L, '06 F-350 6.0L, '03 Pete CAT C15, and some other junk[/FONT][/COLOR] |
Moderhater
Member # 16980
under vaccum is the easiest way to do it. vacuum the system down, and let the machine suck it in...lol or if your cheap, and your using manifold guages, just take the yellow suction line you would hook up the can of refridgerant, and dip it in yer oil, open up the low side, and viola, its sucked into the system WITH A VACUUM STILL THERE....if not, when you vaccum it down, some of the oil comes out again
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
#9 (permalink) | |
#10 (permalink) | |
Member # 4828
(Thats mineral oil, and evacuate the system, and recharge)
