birfield or longfield? help please! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-23-2004, 05:14 AM   #1 (permalink)
Member # 35250
ok so i pulled my front axels in my 77 fj40
and i foulnd axels that are about 3/16 of an inch thicker than the stock spares the guy gave me with the rig. also they are about 1/2 inch longer and have way more splines on the hub end ,about thirty with out counting them..the stocks have 6-8...sorry no pics i cant find the cable to my digital...
help! what kinda axels are these?
BigValveTurbo is offline   Reply With Quote
Old 09-23-2004, 05:19 AM   #2 (permalink)
Member # 260
Send a message via Yahoo to woody
your old birfs are 1975-older coarse spline birfs from a drum front axle
the ones you received "new" are 76-newer fine spline birfs....depending on the measurements, they could either be 76-78 fine spline or 79+ fine splines (yes, there are minor differences)
how the hell you got shafted with 6-spline birfs in a 77 cruiser is beyond me, but it's possible the idiot PO installed a drum front axle in there (I've seen dumber)
Your old birfs make great paperweights....
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote
Old 09-23-2004, 05:26 AM   #3 (permalink)
Member # 35250
no no the fine spline were in the rig and the course spline were in an extra set of axels that came with the rig...
Old 09-23-2004, 05:37 AM   #4 (permalink)
Member # 260
aaaahhhh....the coarses are yer bookends then...
76-78 birfields are ~3/16" longer in the shaft, and ~1/16" thinner across the flat portion of the bell.
79+ birfs (cruiser and minitruck) are all identical, and can be used in a 76-78 housing with some tweaks....take your 4" angle gringer to the fish-mouth opening of the axle housing (NOT the knuckle and NOT the birf) and after a few seconds top and bottom, the later birfs will slip in there. Make sure you stuff rags all around to catch the grindage, and also stuff one inside the inner seal.
When you reinstall the spindle/hub, you'll notice that the birf no longer extends thru the lockout, but sits flush. You'll need a metric bolt and a fender washer here, rather than the square-clip that was used stock.
Old 09-23-2004, 08:00 AM   #5 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
The way these pirate guys feel about coarse birfs, the only way those could be associated with a longfield is when you find a 'long' field to play lawn darts with them!
We could even have a birfield lawn-dart tournament at Surf-n-turf
with metal detectors!
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 09-23-2004, 11:39 AM   #6 (permalink)
Member # 24859
not so Mark , I am sendin some cores to bobby right now to have em bobbified.
So drum long's are comin.. I am gonna try and get several sets together so if you might be interested in tryin em out just pm me.
Mellonhead
peesalot is offline   Reply With Quote
Old 09-23-2004, 10:56 PM   #7 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
Thanks John, but to borrow one of my favorite terms I've learned on Pirate, that's called polishing a turd!
While I am not thrilled with the breakage rate of coarse birfs, or the fact that I've gone thru eight of them, I am in favor of leaving well enough alone. I consider it engineering the weak link. I would much rather fish the guts of a grenaded coarse birf out of my knuckle than figure out how to get a broken inner axle shaft out that broke on the trail! And I'm not planning to upgrade the inners either.
No offense to Nolen, but his article on longs and pigs vs Dana completely bypassed what we can refer to as my plan C [as in Coarse]:
KISS!
And as for my original suggestion of birf lawn darts at Surf N Turf, I figure you and I could split up the donated 'darts' after the tournament to carry for free trail handouts!
MarksOffRoad.net
tlca #1086
Old 09-24-2004, 04:57 AM   #8 (permalink)
Member # 260
Actually, Mark, that axle writeup went thru the wringer on Saturday and passed with flying colors...I wedged the left front tire so hard under a rock that something important had to give...
interestingly, it was the front output SHAFT of the transfer case that split....looks JUST like a busted pinion (which, BTW, I'm quite good at....)
For you Orion builders who think you needed a stronger case and perhaps even that bling billet t-case nose cone, I'd consider a cryo-job on at least the front output shaft...
Old 09-24-2004, 10:55 AM   #9 (permalink)
Member # 24859
Mark , it is not polishing a turd cause it is getting the most outa what you got. I have extra inners that I'm going to martac so changing birf's and fishing inners will be easier. Do you really think the drum birf's modified will snap inners and have me callin pig ? If enough people feel that they will that have experience with longs then maybe I will just run the turd's. KISS ,
Mark , always a cold dose of reality , sending license light money today.
Mellonhead
Old 09-24-2004, 11:47 AM   #10 (permalink)
Member # 12451
Hey PeesAlot.. I'd carry a piece of welding rod with ya just in case?.. Attach it to a battery clamp to fish out the inner axle that broke.. The martack won't really help all that much if the splines twist locking the shaft into the diff or birf..
Probably only needed if you run a front locker tho. Or turn hard in reverse!
Just an idea..
tornadoalleycruiser is offline   Reply With Quote
Old 09-24-2004, 02:58 PM   #11 (permalink)
Member # 24859
I try to carry birfs and inners so unless its stuck in the third , which I gots me a spare all loaded with arb , I can fix on trail and do the hard stuff on the workbench. My idea is to carry stuff so I can replace broken shit. I just have not changed a pinion yet so I carry the whole third.
Mellonhead
Old 09-24-2004, 10:03 PM   #12 (permalink)
Member # 34756
You carry a spare third with an ARB installed Now that's investing in four wheeling!
You gots me envious.
Walt<><
Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing.
4x4Poet is offline   Reply With Quote
