62 knuckles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-06-2004, 02:50 PM   #1 (permalink)
hoop5's Avatar
Member # 31967
62 knuckles
I am currently tring to do the disk brake conv. from a '89 FJ62 to my '70 FJ40.
Do you have to grind off the lower part of the knuckle like the mini truck knuckles? I did a search and all I could find was mini truck knuckle swaps. I was told by several people that the 62 knucles would work, but I am having some issues.
Thnaks
Go Fast buggy built by Baertrax coming soon!!!
http://www.facebook.com/hoop5?ref=tn_tnmn
hoop5 is offline   Reply With Quote
Old 10-06-2004, 02:58 PM   #2 (permalink)
Member # 6863
Grind off the lower part of the knuckle?
No, you should just have to clearance the inner bottom of the ball on the end of the actual axlehousing. No grinding on the knuckle or any of the FJ62 parts. Only on the old FJ40 housing.
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
Old 10-06-2004, 03:11 PM   #3 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
Yup the 62 disks install the same as the mini's, same grinding on the 78' on down axel housings. I have a set of 1990 62's on my 79'. Good stuff.
Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service!
helocat is offline   Reply With Quote
Old 10-06-2004, 03:15 PM   #4 (permalink)
Member # 12758
Here is mine -
Note you grind on the inside of the knuckle. FJ60/2 and mini truck birfields are the same size if not the same exact units AFAIK...
dieselcruiserhead is offline   Reply With Quote
Old 10-06-2004, 03:23 PM   #5 (permalink)
Metal-tech'in
helocat's Avatar
Member # 10420
Oh ya.
As you grind remember to NOT make it so a 79+ birf just barley clears. Give your self an extra 1/6” to 1/8” of room. If that birf ever splits the bell and does not fully shatter you will be cursing that thing on the trail trying to get it out! A split bell brake makes the bell larger and normally just blinders the inner star and cage beyond recognition.
Larger bell due to split + tight fit grind = *%&$^#* on the trail.
Mark
Old 10-06-2004, 03:33 PM   #6 (permalink)
hoop5's Avatar
Member # 31967
Thanks guys for giving me a quick reply.
Hopefully we can get this on tonight and see how see works.
