Land Cruiser T/Case mount pics???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2004, 04:20 PM   #1 (permalink)
Member # 27592
Unhappy Land Cruiser T/Case mount pics????
I have been searching the archives for pictures of a rear transfer case mount setup for a Land Cruiser that is made to go over the T/case, in front of the parking brake drum and behind the T/case. It suspends the T/case from the top instead of supporting it from the bottom. Has anyone seen this mount setup or have a link to it?
75 SOA Land Cruiser (Gentle Giant) TLCA, LCML, BRC, CA4WDC, Motherlode Rockcrawlers-Jackson, CA.
sprung over is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 05:08 PM   #2 (permalink)
Member # 16720
http://www.pirate4x4.com/forum/showt...ighlight=rotor
GreenPig is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 06:20 PM   #3 (permalink)
Member # 21073
Send a message via AIM to treerootCO
Just got finished with the crossmember. It attaches to the frame with the two bolts. The plate just clears the gas tank (pre '79) and attaches with a sigle bolt that is threaded into the bar. The two holes in the plates are there so the rivets can be recessed allowing the plate sits flat on the frame. I think it should work out well....we will see.
“He who goes unarmed in paradise had better be sure that that is where he is.”—James Thurber.
treerootCO is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 06:36 PM   #4 (permalink)
nuclearlemon's Avatar
Member # 1650
are you running stock motor or v8? if v8, you may want to support the transmission instead.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid sideways in a cloud of dust, flopping into the hole totally worn out, shouting ..."holy shit...what a ride!"
nuclearlemon is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 07:56 PM   #5 (permalink)
Member # 27592
Installing a generation III 6.0L, NV4500 and Orion. If I support the transmission, the mount will hang to low.
Old 10-15-2004, 08:16 PM   #6 (permalink)
Member # 34756
Thanks, treeroot. I really appreciate the pics.
Fantastic use of the Energy Susp poly mount!
Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing.
4x4Poet is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 09:36 PM   #7 (permalink)
Member # 29301
Great design...
Something for the next cruiser
manny 72fj40
pic of current xmbr below...
mr_manny is offline   Reply With Quote Quick reply to this message
Old 10-16-2004, 09:59 AM   #8 (permalink)
Member # 27592
Talking Land Cruiser T/case mount pics????
Thanks for the replies, the great links and all the pics. Some great ideas and workmanship in these mount setups. It appears that the 420 & 465 do not have an output shaft that protrudes beyond the back of the transfer case. Is this correct? Anyone else willing to post some pics of their T/case or trans mounting configurations?
Old 10-16-2004, 10:58 AM   #9 (permalink)
Member # 1650
you are correct...the output on the muncies is just enough to get the gear on in the tcase.
Old 10-20-2004, 02:12 AM   #10 (permalink)
Member # 3259
Send a message via AIM to FIXXXXAH
DEFINATLY AN INTERESTING WAY OF DOING IT TREEROOTco.
MATt
[SIZE=1] "ANYONE WILLING TO TRADE FREEDOM FOR SECURITY DESERVES NEITHER."
TUBING AND BUGGIES ARE OVERRATED
METRIC ROCKS. [/SIZE]
FIXXXXAH is offline   Reply With Quote Quick reply to this message
Old 10-20-2004, 07:09 AM   #11 (permalink)
LC Hamma's Avatar
Member # 137
Just wondering why the stock 3 speed / tcase didn't have a mount on the back. Is there really a need for one if you're running a plate adaptor? I ran one of the AA style one's with their long adaptor & over time had a problem with the tcase backing away from the adaptor. Anyone NOT running a tcase brace to the frame?
'91 Ram W250 5 spd. CTD SC/SRW
'93 Ram W350 5 spd. CTD SC/SRW
'99 Ram 3500 4X4 5 spd. CTD SC/DRW
'12 Alaskan Camper NCO
If you drive a IFS GMC/Chebby & have a beard, shave that sh!t off
LC Hamma is offline   Reply With Quote Quick reply to this message
Old 10-20-2004, 07:42 AM   #12 (permalink)
Member # 1650
they didn't need one since the engine had mounts on all four corners and the trans and t case were light enough to be held by those mounts. many people have the problem with the aa mount. redfox told me that since he eliminated that and put a crossmember supporting his transmission he's never had a problem...over five years now. i did the same thing and so far six months later, not a drop
Old 10-20-2004, 08:15 AM   #13 (permalink)
Member # 2492
I've got that AA style that bolts onto the back of the t-case.
It sucks. It leaks all the time now. Even with loctite I have to re-torque them all the time.
I've spent a lot of money on trucks and beer. . .. . the rest I wasted.
Mark '73 FJ40 is offline   Reply With Quote Quick reply to this message
Old 10-20-2004, 09:17 AM   #14 (permalink)
LC Hamma's Avatar
Member # 137
SM420's aren't *that much heavier than the stock 3 speed. Now SM465's are
way heavier....... I wasn't gonna run one w / my plate adaptor, but hey what's a few hours of fab time & some scrap steel for a sound piece of mind that it'll be secured.
Old 10-20-2004, 11:12 AM   #15 (permalink)
Member # 24859
I came across a small oversite that may lead to the continued leaking of the A/A propeller style mount. In the A/A instructions it says to drill a hole in the mount to match the oil return passage in the cone and rear bearing area on the back of t-case . I checked , and sure enough , the PO never did this and my A/A mount leaked like hell. I put in orion so studs won't loosen in cast iron I hope and drilled the hole so the mount won't leak anymore. Check yours , if you have the mount that has a welded cone then you have to use a grinder or something and create a channel for the oil to flow to the return hole. My neww orion case had the return hole identical to stock case. The stock steel cones have a little stamped chennel that lines up with the return hole.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 10-20-2004, 11:57 AM   #16 (permalink)
Member # 21073
I included the oil passage on the back of my crossmember plate. No leaks yet.
SM420 = 135 lbs
SM4765 = 175 lbs
