Power Steering Box Info/ Part Numbers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-30-2004, 08:32 PM   #1 (permalink)
Member # 14712
Ok...so I finally got my new Saginaw power steering box. Through the process I did some research and thought I would share some here. First off...here is a great link for cross referencing and digging out part numbers: http://www.rockauto.com/
All I researched was for flare fitting boxes. If you have or want Oring..look after 79. The following are flare boxes:
72 Caprice 3.5 turn 13/16 input Cardone 27-6537
74 Caprice 4.5 turn 13/16 input Cardone 27-6529
77 J20 3.75 turn 3/4 input 3.5 inch piston (this is the AGR Super Box) 27-6505
I got the J20 box today and it came in right, with the large piston. After some further research, I believe there is also J20 box with the 13/16 input(which would have matched my current u-joint). The application would be for a 75 or 76 J20, since I believe the input shaft change came in 1977.
Anyway, these part number might not mean anything compared to what you actually get in the box, but it should be a start. Also, Autozone was completely useless for finding any of these...I ended up at O'Reillys and their computers seemed to be able to find everything by either part number or application. Napa had about the same prices (I have an account there) but their shipping time was much longer. Napa numbers are the same as Cardone, except drop the first 2 digits (the 27). This is just what I've gathered since last week...so feel free to add or correct!
I'll let you guys know how the "super box" holds up.
Killerpee is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 08:10 PM   #2 (permalink)
Member # 14712
Well, not that anyone seemed even the least bit interested, but here's the update.
The J20 box installed right in place if the smaller saginaw. I had to trim my bumper a bit because I made mine so close. With the saginaw pump mod and the J20 box...I could turn the 39.5 IROKs at 2 psi with two fingers on the concrete. Pretty good I think. Lets see how long she holds.
Old 12-07-2004, 08:55 PM   #3 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
shhhhhhhhh
The J20 box is perfect..
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 09:10 PM   #4 (permalink)
rockthedog's Avatar
Member # 19510
thanks for the info......i saw this a while back.
i'm trying to figure out which shaft i have to decide which j20 box i'm gonna get.
do you know for a fact the shaft size was dif. before 77'?
did you do the saginaw pump mod from redneck ram?
thanks again for your research
glenn
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 10:47 PM   #5 (permalink)
Member # 24859
go measure your wb again , you still aint got the pump with the mod's yet ?
I got my front springs , so with 2 " back in rear and 3" up front it comes in at 95 with the tape pulled tight . Now when we wheel ? Sierra's done be burried after tonight , I mean burried.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 12-08-2004, 07:35 PM   #6 (permalink)
rockthedog's Avatar
Member # 19510
98.....98......98......98.......NOT 95
i'm gonna do the red neck ram mod on my pump 1st and see how it works
i called my source today and the j20 76 pn IS different than the 77 (hoping it's shaft size).......and i'm getting a smokin deal on it
i'm pretty busy till after the hollidays.........hope we can hook up with dave (spamman) for the snow run
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-08-2004, 08:12 PM   #7 (permalink)
Member # 14712
I am still not sure about the different shaft sizes, but I would be willing to bet the box comes in both. If not...it is very easy to just pull the end with the input shaft and mov it over to the J20 box.
Old 12-08-2004, 10:54 PM   #8 (permalink)
Member # 31647
I've been using the J-20 box for a few years and really like it. With pump mods and dual belts it doesn't make a single squawk unless I bury the steering stops. The only time I wish I had more steering power is if I get the wheels really bound up in the boulders. Just don't tell your Toyota it's a J**P part.
'74 FJ40 SBC, SM465, SOA, PS, HS, LR, etc...
'69 FJ40 Cruggy under construction
'83 mini wants to grow up to be a Hendrix Formula
SpanishTrail is offline   Reply With Quote Quick reply to this message
Old 12-09-2004, 11:22 AM   #9 (permalink)
Member # 1926
Not a HEEP part. It is a Saginaw box.
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote Quick reply to this message
Old 12-09-2004, 03:42 PM   #10 (permalink)
dp
Member # 25235
When I went hunting for my box they told me they were all the same between 69-76. All were 3.5 turn.
None of the parts dealers can get a 4.5 box for some reason.
So I went and bought a used 3.5 turn box from a 74 Caprice.
I guess the parts dudes were right.
dp is offline   Reply With Quote Quick reply to this message
Old 12-09-2004, 09:05 PM   #11 (permalink)
rockthedog's Avatar
Member # 19510
i did a little research today.....my napa parts conection got me the pn for 76 j20...... part #51-6529
i called the tech line for there vendor to check shaft diam......13/16", which is what i need, also it is a 4 turn box with a 3.5" piston .....apears to be the same as th caprice
it will be here in the morning .........at her cost!
glenn
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-09-2004, 09:26 PM   #12 (permalink)
Member # 14712
Nice score on that one...just make sure to measure the piston size to be sure they got you the bigger box.
Old 12-10-2004, 09:24 PM   #13 (permalink)
rockthedog's Avatar
Member # 19510
got it today ......yes it's the large piston.....from talking to the tech guy, it sounded like the 4 turn box IS the 3.5" unit.
thanks again for the research
glenn
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-10-2004, 09:35 PM   #14 (permalink)
Member # 24859
is that new box a 4 bolt mount ?
Mellonhead
Old 12-10-2004, 09:46 PM   #15 (permalink)
rockthedog's Avatar
Member # 19510
yes sir
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-10-2004, 10:02 PM   #16 (permalink)
Member # 24859
um , order me one ? please
Mellonhead
Old 12-10-2004, 10:35 PM   #17 (permalink)
rockthedog's Avatar
Member # 19510
i'm afraid my source will cut me off
if some how it seems cool to swing it i'll let you kmow
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 03-25-2005, 11:42 AM   #18 (permalink)
Member # 14712
Does anyone know if there is an o-ring version of the J20 (large piston) box, and if so, what is the year for it???
Old 03-25-2005, 12:58 PM   #19 (permalink)
cruzila's Avatar
Member # 6650
Don't you find the 3 turn box too twitchy on road?
I use a 6537C box from a 74 Fleetwood 13/16 input, big bore, 4 bolt, 4 turn mofo that I only need my pinky finger to drive with.
Scott Johnston
Rubicon Trail Foundation
Founding Director
Past President 2010-2012
Retired Director 2004-2013
DuraLine winch rope!!
cruzila is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 06:38 PM   #20 (permalink)
rockthedog's Avatar
Member # 19510
call ARI tech line 888-726-2234........... they are a wealth of info for boxess and pumps
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 06-09-2005, 10:53 AM   #21 (permalink)
yager's Avatar
Member # 10695
Send a message via AIM to yager
(im searching and obviously dont ever post in this section) but I have a 79' J20 box and it is a 3 turn box, i think its kind twitchy. Its defintly nitght/day difference in steering effort even with 38s...
killerpee - the 80ish up J20 boxes had o-rings (can't speek to the other differences. (i had verified this with my power steering hose catalog)
On the number of turns ? I seem to be hitting the internal stops and cant get lock to lock on the kuckles, m wondering if a 4 turn box simply has more internal throw ?? If my arm could more slightly more id be all set...
Mike Yager -
- Ecotec, Toy axles etc..
Stroke - Coumadin(warfarin) - INR - Heart Valve - Ask me (true story)
yager is offline   Reply With Quote Quick reply to this message
Old 06-09-2005, 12:24 PM   #22 (permalink)
Member # 24859
funny you mention that , I have the 4.25 turn box ( 4 bolt) and with tires on concrete at 15 lb. I can turn em easy but they stop just short of stops. jack up front tires and it goes stop to stop with no strain and is well within motion or range of box. I just figure with rolling it will go stop to stop when on concrete...
Mellonhead
Old 06-09-2005, 12:58 PM   #23 (permalink)
Member # 19342
Send a message via AIM to 69cruzer
box #'s
man what a great post.
thanks alot.
anyone know how much the j20 box should run me?
Thanks
Spence
69cruzer is offline   Reply With Quote Quick reply to this message
Old 06-09-2005, 07:24 PM   #24 (permalink)
Member # 14712
Got me on that one....I was thinking pitman arm length. A longer gives you more travel but would also make it steer faster.
