Starting Problems
Hey everyone,
Over the past few weeks I haven't been able to start my rig. The PO had some guy do some major work on the engine and ended up putting in a Crane cams XR700 which worked for fine. I have since installed a Aisin carb from Mark's Offroad, A new XR700. Seems to get fuel ok and a spark. Occasionally I can get it to start, but with very little power and it dies shortly afterwards. And that's holding it at near full throttle. I have a 1962 FJ40 that has a 3 speed xfer case (manual shifter, nit vacuum), sm420. Is there something that I'm missing? Mark ahs given me some insight on some areas and hoping for a little input and other things that might be causing this or tests that I could do? Rob |
#3 (permalink) | |
Member # 16085
if its a 63 carb is will not have one, think it showed up around 67-ish on the large window carbs
2000UZJ100/92FJ80/90FJ62/86FJ60/82FJ40mustard/82FJ40green/78FJ55/67FJ45LBP/65FJ40LV/65FJ45LV/64FJ45LV/87 Chevy 3/4 ton beater |
Member # 11288
Rob-
Have you had the motor running since the cam and other engine work was done? In other words, was it running fine before you switched the carb? Just trying to get a baseline here.
Jim |
#5 (permalink) | |
Robert |
Member # 11288
Mark had you check that you've got fuel at the right level in the bowl and you get a squirt from the accelerator pump when you work the throttle right?
If you give it a dash of gas down the throat (or pump it several times) and it starts with no popping or strange noises, runs for a few seconds then just dies out, I'd start looking for a massive vacuum leak or suspect a plugged main circuit in the carb. You probably don't want to hear this, but..... if it ran fine with the old carb, it may be easier to just stick the old one back on to see if the carb is the problem.
Jim |
#7 (permalink) | |
Mark and I spoke briefly and he mentioned two things. #1 was that he wasn't in favor of the Crane Cams ignition, from what I gathered it has a short dwell angle 32 degrees. #2 he mentioned another guy that had the same setup and he fixed his by adding a pcv system. Seeing those, I think that I could easily test the pcv theory by removing my oil filler cap, that surely would give plenty of air flow. On the ignition issue, I guess I can always throw points back on. Btw, Now that I have rambled on, what's next? Robert |
Member # 11288
Don't know, I thought you had ruled out the ignition when you said it ran with the old carb. Have you had it running with the new ignition?
Jim |
#9 (permalink) | |
Rob |
Desert Rat
Member # 27432
Actually Rob, I don't remember saying 32. It's more like 25, which is what is typical for a V-8 application. The initial installation of any aftermarket ignition also has a significant impact on timing as well. With the Crane's 'universal' [we tried to fit everything with one product, so we fit NOTHING WELL]mounts, it would be hard to say where your timing ended up.
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
#11 (permalink) | |
Member # 11288
, yeah your timing could be off like 60 degrees and it might catch, gasp, and die when you try to start it.
Jim |
