FJ60 rear axle question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-19-2004, 10:11 AM   #1 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Send a message via AIM to fj40_rico Send a message via MSN to fj40_rico
I am toying with the idea of swaping my rear axle for a fj60 axle. my question is what is the gear ratio on them and if they are different? can I just swap the 3rd out of the 40 axle. or the gears.
Thanks for any info.
- Rico.
Rico
No Rigs...
fj40_rico is offline   Reply With Quote
Old 12-19-2004, 10:13 AM   #2 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
60s have 3.73s. your 3rd member will go right into the 60 housing.You realise the 60 is 3 inches wider right?
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place.
2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th
2010 KOH Team CrossedUp Mike Klensin and Justin Reece.
2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH.
TLCA# 5305
RustyNailJustin is offline   Reply With Quote
Old 12-19-2004, 10:19 AM   #3 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Yep.
Thanks for the info.
- Rico.
Rico
No Rigs...
Old 12-19-2004, 01:14 PM   #4 (permalink)
Member # 12451
Dodge perches, your rear disks wont' work completely, need new brackets. get a IFS hub spacer kit for the front and call it "wide"..
Erik FJ45, FJ40, FJ62 TLCA #5303 Secretary
tornadoalleycruiser is offline   Reply With Quote
Old 12-20-2004, 01:32 AM   #5 (permalink)
OnTheSpot's Avatar
Member # 34900
I put a fj60 rear in mine and like it so far. the width is nice.
Applying the Beef Treatment
OnTheSpot is offline   Reply With Quote
Old 12-20-2004, 07:12 AM   #6 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
I'm planning on using the fj60 brakes. When you say disc do you mean drums?. I'm not planning on re-using my disc brakes. I'll probably trade the whole axle for the 60.
- Rico.
Rico
No Rigs...
Old 12-20-2004, 07:13 AM   #7 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Originally Posted by OnTheSpot
the width is nice.
That's the main reason why I want to do it. Also, I need an emergency brake.
- Rico.
Rico
No Rigs...
Old 12-20-2004, 08:35 AM   #8 (permalink)
Member # 12451
Ebrake? Don't you have one on your Tcase?
Options are good.. THe rear disks on an FJ60 rear axle are very similar to the FJ40 stuff but different brackets..
I'm not saying rear drums, I don't have any of those on my trucks.. I meant re-using your rear disks.. But whatever you wanna do is fine.. Options are good!
Old 12-20-2004, 09:36 AM   #9 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
I've tried to adjust that piece of crap and I can get it to work.
- Rico.
Rico
No Rigs...
Old 12-20-2004, 09:40 AM   #10 (permalink)
Member # 12451
Take it apart, beadblast the inside, re-assemble should work.. Well, till you take off with it engaged!
Old 12-20-2004, 10:09 AM   #11 (permalink)
cruiseroutfit's Avatar
Member # 1858
- Rico.
What doesn't work about it? It is by far cheaper to keep your current axle and get the T/C brake working (even assuming it needs complete replacing). The 60 swap will require a new pinion flange (or re-drill), new spring pads, shock mounts, brake lines, etc... Not to mention the cable you will need to convert from a dash PB handle to a floor style cable (not sure there is anything off the shelf you can use).
EDIT: Flang will only be needed if you keep the FS 60 3rd
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 12-20-2004, 10:42 AM   #12 (permalink)
Member # 12758
Rico it is not hard and actually works great with a floor mount ebrake. But oyu do have to spring for those parts as well. There is a 60 at pick n pull with ebrake and everything, you can probably get everything for $100?
It's also probably easiest to just fix your ebrake though even with the 60 axle, then you don't need to put in the floor mount ebrake...
dieselcruiserhead is offline   Reply With Quote
Old 12-20-2004, 02:51 PM   #13 (permalink)
Member # 161
What's the difference between a FJ60 axle and an FJ62 axle. I have f & r 1990 FJ62 axles for my 40. I dont really know too much about them except for the width difference. BTW the rear drums with E-brake look like they should be a good setup for me. My stock rear drums and T-case E-brake haven't worked right for years. I never rebuilt them knowing that someday it would all get replaced. I'm actually looking foward to that E-brake.
1967 FJ45LV-1972 FJ40-1986 FJ60
Rev. Parsley is offline   Reply With Quote
Old 12-20-2004, 03:25 PM   #14 (permalink)
Member # 25048
Correct me if I am wrong, but I believe the only difference between them is the gearing.The 60's being 3:73 ,the 62's being 4:10.Maybe the sway bars too?I have a set of both but not right here now or I could be more help.
incogrhino is offline   Reply With Quote
Old 12-20-2004, 03:40 PM   #15 (permalink)
Member # 24859
IIRC the 62 has a gusseted housing .
Mellonhead
peesalot is offline   Reply With Quote
Old 12-20-2004, 03:53 PM   #16 (permalink)
Member # 161
That's what I was hoping to hear. Thanks. Anybody else got any more good info for me?
Old 12-20-2004, 04:25 PM   #17 (permalink)
Member # 12758
The big thing is that the 3rd member is a 4.10 gearing (just like the early models) but that it has the '78 and later stronger fine spline pinion. So it has the benefits of later model 3rd members but because cruisers (both 40s and 60s) switched to 3.73 gearing (much better for the highway on stock tires) in 1979 the amount of fine spline 4.10 third members is very limited other than in 92 models and later. The 62's had them more or less to compensate for the automatic but offer the lower 4.10 gearing better for off road and more power.
Also the front axle is slightly improved, gussetted housing so less prone to bending and the pinons is slightly turned versus a 60 that is at 90 degrees. Ideally I want to put a 62 axle in the front of my 55 with 3rd member and all...
Old 12-20-2004, 06:18 PM   #18 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
It just won't grab. I've replaced the pads, adjusted it. I did have a bad rear t-case seal leak so I might have to replace the pads again.
The other reason why I wanted the 60 axle was for the extra width, but it sounds like wheel spacers will be cheaper.
- Rico.
Rico
No Rigs...
Old 12-20-2004, 06:37 PM   #19 (permalink)
Member # 12758
Probably comparable honestly, plus wheel spacers suck
but I do run then on my DD for what its worth though
Old 12-20-2004, 07:16 PM   #20 (permalink)
Member # 19837
- Rico.
Buy new pads, springs, pins etc.... measure the inside of the drum and possibly replace it also. Might need to get a new adjuster. The TC e brake works great and is easy to work on. A full rebuild kit is around $100
If it does not go easy just force it
David Dearborn
Atlanta GA
www.urbanlandcruisers.com
TLCA Associate member
Got a question, need an opinion, do you love puppies, just want to talk or stage a cage match? For all of these issues and more PM Mark, 65SWB45.
dd113 is offline   Reply With Quote
Old 12-20-2004, 08:03 PM   #21 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
what's better wheel spacers or rims with bigger offsets?
- Rico.
Rico
No Rigs...
Old 12-20-2004, 11:00 PM   #22 (permalink)
Member # 12758
Rims and as mentioned somewhere they are about the same price if you get your spacers for $100 (the cheap going rate).
http://www.pirate4x4.com/forum/showt...ighlight=ethan
Old 12-21-2004, 01:43 PM   #23 (permalink)
theferg's Avatar
Member # 15144
Rico I may have some 15x8s with 2" backspacing up for sale. I'm waiting on a shipment and then I gotta test fit the wheels, but if they don't fit, you have frist dibs if you want 'em...
-Ferg-
theferg is offline   Reply With Quote
Old 12-21-2004, 01:56 PM   #24 (permalink)
Member # 260
Send a message via Yahoo to woody
http://www.ih8mud.com/tech/e-brake.php
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote
Old 12-21-2004, 06:01 PM   #25 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
-Ferg-
Sign me up. Why wouldn't they fit. Which rims are they? brand?
- Rico.
Rico
No Rigs...
