Member # 770
knuckle swap issue
Not hard core tech, but this is just pissing me off at this point.
1978 fj55 disk knuckles, 1972 housing. Knuckle rebuild kit from a vendor on the board. Everything fit well, bearings, races, etc. The problem is that the brass looking hub seal (holds on the backing plate and spindle) is too small to go around the hub body. With everything dissasembled it still does not go around it. Do I have the wrong one? Is there a difference? Am I just incompetant? (this is where my money is.) Can I put a slit in it to make it fit? Seems to me that if it is that tight, it is just going to burn up when the wheel moves. Anyone else ran into this?
My oversized hat won't fit your humungous head. |
Member # 1650
they always fit tight...i usually put new ones around an extra hub body for a week or two and make sure they're warm when i put them on (IF i put them on)
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid sideways in a cloud of dust, flopping into the hole totally worn out, shouting ..."holy shit...what a ride!" |
Member # 137
Sounds like the vendor swapped in an early drum brake hub seal. That seal is smaller dia., but more beefy than the disk brake hub seal.....
'72 FJ55 http://forum.ih8mud.com/showthread.php?t=76835 '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 '91 Ram W250 5 spd. CTD '93 Ram W350 5 spd. CTD '99 Ram 3500 4X4 5 spd. CTD Welding is like sex, it's all about the penetration! |
Member # 770
That sounds right. This thing is pretty stiff. Of course I am doing it in 10 degrees...
no heat in my shop. I brought it inside last night and tried to slip in on this morning, no dice. Too small. I can run without it for now?
Member # 1858
What is the ID (inside dimension) of your dust seal?
Ditto what Ige said, they will be tight on install, especially in cold weather.
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
Member # 770
If by tight you mean "no way is this going on with all the force I can muster", then yes!
Did not try to crank down on it using the bearing nuts, but I have thought about it. I can measure the diam. tonight. Can I run the old one with no seal? The seal came out as a seperate piece.
#8 (permalink) | |
Member # 1858
No, thats a drum brake one. If your seal looks like the one above, then it is a disc brake one... the only mishap could be on the manufacture but I have never heard of one being unusable. Where did you get the kit?
Member # 24859
The kits and seals or at least the one pointed to in the pic that we use or even have disassembled from old cruisers have always been seperate halves of metal with a solid rubber piece and a solid felt piece that is tight but streches over the ball.I found the felt harder than the rubber piece as far as not fing it up. Confusing ? when you said would not fit over hub.
You put the stuff on before you put knuckle on . Take a hack saw or thin cut off and make two pieces and I would put the 1 piece rubber wiper in too cause the felt pulls outa those old ones . What does not make sense is that kit seems to have old wipers but do the spindle gaskets match , should not if it is for the drum axle ?
Mellonhead |
Member # 24859
You got the right rubber pieces , I looked again , but I can tell by the shims that that kit is for small bolt pattern for the knuckles which would indicate drum stuff but a few I've seen from , mid , 70's had disc's with a different bolt pattern for the steering arms than the common mini disc knuckle . Maybe the 55 had discs with the small bolt pattern which is why the kit would be for the older stuff.
Mellonhead |
Member # 770
I can't remember where I got the kit. I have been on a parts buying rampage.
Maybe liquid off road? Maybe cruiser outfitters? It came with both size shim packs, so that does not help. peesalot- you are thinking of the axle side kit. This retainer holds on the spindle and backing plate. The axle side kit came as two pieces. I need to move the truck tomorrow. If this does not work, I will have to run without it, or cut slits in it to make it fit. Seems like it is close, but it just does NOT go on. Since I am swapping from drum to disk, the only spare knuckles I have are off a drum brake end.
#12 (permalink) |
Member # 770
I think I got the kit at liquid off road, who has been pretty good to me thus far.
It is definately the disc kit. Can I run without the wiper?
#13 (permalink) | |
Desert Rat
Member # 27432
You can definitely assemble and move the truck without the seal. What really worries me here is this comment:
Of course I'd rather believe that you just have your terminology wrong. When in doubt, I generally recommend contacting the vendor you purchased the parts from for advise.
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
#14 (permalink) |
Member # 770
I guess I could explain myself better.
I was talking about the wheel bearing retaining nut. It (the rotor/hub) slides on just far enough to get the nut on. Just not fully seating, as it can't get past that part. AFAIK, it is assembled correctly. The seal is seated fine to the backing plate, just the hub can't get through it. It is sitting in my warm house right now. We will see tonight.
#16 (permalink) |
Member # 24859
I'm with ya now rapid . I had same issue when doing by bolt on disc brakes to my drum axle. The bracket for the calipers was thicker than old backing plate so it moved the wiper outboard causing it to hit hub so I deleted the wipers and packed the little cavity with heavy ( old school yellow axle grease) grease to keep shit outa the seal in back of hub.
If it don't fit it is for the smaller spindels and hubs ( drum stuff ) I would not use the spindle nuts to press the hub thru the wiper , it should just rub on the shoulder on back of hub.
Mellonhead |
#17 (permalink) |
Member # 19837
You might have tried this:
Will the seal fit over the hub when the hub is not on the spindle and the seal is not attached? The inner wheel bearing sometimes does not want to go onto the spindle and mimics the effect of the seal not going around the hub.
If it does not go easy just force it David Dearborn Atlanta GA www.urbanlandcruisers.com TLCA Associate member Got a question, need an opinion, do you love puppies, just want to talk or stage a cage match? For all of these issues and more PM Mark, 65SWB45. |
#18 (permalink) | |
Member # 1858
#19 (permalink) |
Member # 24859
I could not use either cause the thickness of the caliper bracket caused the seal ring to interferewith back of hub.I thought about modifying it to work but was in a hurry and only had old ones anyway. I will get some disc ones and see if they fit thanks for the info.
Mellonhead |
#20 (permalink) | |
Member # 1858
When using Toyota parts, the hub dust seal should fit without a problem... if using aftermarket parts, I would chat with the manufacture about why their kit doesn't have provisions for a needed dust seal. I will post up the specs (inside diameters) of the disc/drum hub seals in a couple minutes...
#21 (permalink) |
Member # 16737
Someone correct me if im wrong. But the only drum hub seals that I have worked with all came with just a felt packing that you put in the metal ring.
Did they come up with a new seal for the drum hub like a disc one?
72 Rockwelled yeah whatever... All my shits heavy. |
#22 (permalink) | |
Member # 22144
You'r right on the felt and the metal ring for the back of the knuckle.I also think either felts would work.
Don't piss down my back and tell me it's raining tlca#6722 |
#23 (permalink) | |
Member # 16737
(foghorn voice)No No No boy.....yah got me all wrong. Bout a sharp as a bowlin ball!(foghorn voice off)
I do mean for the hub itself. Not the wiper felt on the ball of the axle. All the DISC brake hubs that I have done, have that metal ring with a rubber lip that bolts onto the spindle bolts, like rabid posted. The DRUM ones were a metal ring with a grove for a felt packing that you could pull out and replace. Quote:
#24 (permalink) |
Member # 22144
Now i know what your talking about
.Maybe i should read all the replies on the post and not a selected few.Thanks for reminding me by saying "keep your eye on the ball"and not the space in between.
#25 (permalink) | |
Member # 1858
Just as I stated... If you have the removable seal style... then it is DRUM brake... if you have the rubber seal one, it is disc brake... ![]() I forgot to measure those ID's... tomorrow...
