Bolt Size...
505 views 1 reply 2 participants last post by  cruiserbrett
#1 · (Edited)
I in the middle of a 350 swap and I was wondering if anyone knew the bolt size and thread for the bolts that hold the pressure plate on the flywheel.
Search but didn't find anything.
Thanks.
- Rico.
Edit... Don't know if it matters but the motor is a 1990 Van Motor. had an auto behind it so no pressure plate bolts :D
#2 ·
I think they are 3/8"-16, but the shank diameter is crucial since there are no dowel pins. Mr Gasket makes a set, and you can get them at Kragen etc... there is a chance you have metric ones, since GM had a nasty habbit about that time of having both std and metric stuff on motors. I would figure out what thread they are, and if metric, hit up the dealer, if std, you should be able to get a set cheaper at the autoparts store.
