Starter won't fit on gm bellhousing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-15-2005, 03:25 PM   #1 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Send a message via AIM to fj40_rico Send a message via MSN to fj40_rico
I have a 1990 350 chev that is being mated to a bellhousing from a 68 truck the bolts match but the starter does not fit. it's hitting the bellhousing. I was wondering if it would be ok to grind the bellhousing or do I need a different starter.
Thanks.
- Rico.
Rico
No Rigs...
fj40_rico is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 04:08 PM   #2 (permalink)
texican's Avatar
Member # 12349
use the 96 PU gear reduction, some need clearance and some don't, you can grind but this starter takes less grinding than the old big one
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
texican is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 04:33 PM   #3 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
So go to a parts store and ask for this starter, or is there more info I'm going to have to provide?
Thanks.
- Rico.
Rico
No Rigs...
Old 01-15-2005, 07:10 PM   #4 (permalink)
Member # 1926
Butch,
What if you used an aftermarket high torque starter from Jegs or Summit.
The starter from GM is not going to be cheap.
Charles
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 07:25 PM   #5 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Originally Posted by fj40charles
Butch,
Charles
Very important point
Rico
No Rigs...
Old 01-15-2005, 07:45 PM   #6 (permalink)
Member # 1176
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
June 28th 2003
Berg is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 07:46 PM   #7 (permalink)
texican's Avatar
Member # 12349
Thanks.
- Rico.
Ask for a starter for a 1996 GM 350
They are usually around $100 at most parts house's with a lifetime warranty.
Charles I have had more greive from these supposed Hi Po starters over the years, it ain't worth the trouble.
Butch
Old 01-15-2005, 08:39 PM   #8 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Butch,
Which years should I be looking for to get the mounting bolts inline (not offset) ???
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 09:00 PM   #9 (permalink)
Member # 24859
Butch , what year sb chevy had the horizontal bolts in starter flange ?
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 09:07 PM   #10 (permalink)
texican's Avatar
Member # 12349
Snipped from a thread over in Mud
You should setup a 900 number and charge for "tech support."
"Hi this is butch if you need me to tell you which tool you need to get the job done press 1"
"if you need to know what hole it fits into press 2"
Old 01-15-2005, 10:30 PM   #11 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
S
You should do it. You would get calls from me all the time
- Rico.
P.S. Thanks for the info.
Rico
No Rigs...
Old 01-15-2005, 10:39 PM   #12 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Very tempting but I hate buying electrical stuff from ebay. Thanks for the info though
- Rico.
Rico
No Rigs...
Old 01-16-2005, 07:42 AM   #13 (permalink)
Member # 1926
Butch
Is this a gear reduction starter from GM.. Not much technology involved in making one of these. They basically use a Nippendenso motor and have gear reduction. I believe they take a Nippendenso starter motor from a Japanese car starter and build a gear reduction box for it.
I've been using the one from Summit for a while. The first one I had would not quit spinning after I started the engine.
For the $100.00 price for the GM unit with lifetime warranty, I'd get it.
Old 01-16-2005, 08:09 AM   #14 (permalink)
Something...
fj40_rico's Avatar
Member # 18522
Going to
- Rico.
Rico
No Rigs...
