Member # 42457
Fullsize 1-ton GM axles on a stock FJ60
Need some info on putting a 8 lug 14bolt and Dana 60 from a 70's K20 on a stock FJ60. Whats it gonna take?
Oh and first post, awsome site. Looking for some info on a spring project I want to do. Fullsize axles, bobbed rear, lockers, crossover steering and a 350 in a good condition FJ60. James
Member # 20879
freking newbe
if your fj60 has a drive train just lift and lock and sale your d60 front (to me, not for my toy) to pay for the lift and lock if it brakes then fix it welcome newbe
What? |
Member # 34369
welcome to pirate.. recc lurking a couple months before posting silly questions... stuff like this is asking for a royal flame.... search, read, build, ask as help is needed.... just a thought....
oh yea, buy a damn star and support the board.. chris
[COLOR="Magenta"][QUOTE=Earl_of_Burl] Q: What is Hell? A: A place that is without God. Q: How do you find God to avoid Hell? A: Through his son, Jesus Christ. Q: What does this mean to me? A: If you are living your life without accepting Jesus Christ as your personal savior, you are on the road to Hell.[/QUOTE][/COLOR] |
Member # 24876
what are your plans for it?? like mentioned keep the stock axles they are plenty strong. if you notice my sig, i have full size axles. i wouldnt have done it unless they came with the truck when i bought it....
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR] |
Kool Arrow
Member # 13666
GET OUT THE WELDER AND HIT IT .....
DO A SEARCH IT BEEN WORKED OVER ON HERE AND WWW.IH8MUD.COM and post pic I want to do that too
Member # 42457
I plan on running 36's, I want the fullsize axles. Once the 350 is in I don't imagine the Toy axles will handle the mud bogging and rockcrawling I want it for. Also plan to bob the rear, gut the interior and install a strong cage/bumpers. The future will bring big tires and more hp. I want fullsize axles so i dont have to fawk with them in the future.
Is it as simple as I think, just make spring mounts for the fullsize axles and bolt them on? Aside from the steering and driveshafts of course. |
thats about it, just put the purches on, and weld er up. then you will have to adapt a toyota end on the drive shaft. and hook up some steering.
not too dificult. oh, and dont worry about all these slackers, they were all newbies at one time SHane
1971 FJ40 w/ rust Build up 2003 Toyota Taco double cab 2008 Subaru Impreza STI 1998 Honda XR650L TLCA member #12202 Last edited by PARANOID56; 02-09-2005 at 02:09 PM. |
#9 (permalink) | |
Member # 1527
80, '72 GMC, Odyssey |
#10 (permalink) | |
Moderator
Member # 8568
Nope. Those had 14 bolt and 44.
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place. 2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th 2010 KOH Team CrossedUp Mike Klensin and Justin Reece. 2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH. TLCA# 5305 |
Moderator
Member # 8568
If you are looking for somthing thats already set up for 1tons,hydro,GM V8, bobtailed. The body is kinda beat but a new set of fenders and a little TLC it would look awesome. I will be selling the body and frame as you see it here soon, for cheep. I hate to take this baby apart but its replacment is just bad to the bone!
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place. 2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th 2010 KOH Team CrossedUp Mike Klensin and Justin Reece. 2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH. TLCA# 5305 Last edited by RustyNailJustin; 02-09-2005 at 04:57 PM. |
#12 (permalink) |
Moderator
Member # 8568
#13 (permalink) | |
Member # 42457
I'll double check the badges on the K truck and figure out for sure that its what I need. I know it has a 14bolt, a 3/4 ton 8 lug 44 wouldn't be a bad swap. |
#14 (permalink) |
Member # 22408
QUOTE=BigGreenMachine]
a 3/4 ton 8 lug 44 wouldn't be a bad swap.[/QUOTE] The 44 would be a waste of tim as an upgrade, other than being wider. There's good stuff for the L/C axles which make them stronger than a 44. If you're gonna do all the work, don't fuck around with a 44. Put in a 60. K30s had a perfect donor axle. |
#15 (permalink) |
Moderator
Member # 8568
Its not so cut and dry as explaned by "paranoid56" If you use a 60 the pirch on the drivewr side is cast into the differential so you pretty much have to move your spring hangers out about 1.5 inches on both sides. The back just cut and weld. If you have a 44 insted of a 60 I would not even wast my time a 44 is no stronger than cruiser with longs. go D60 or go home!
#16 (permalink) |
Moderator
Member # 8568
Also what Tcase? if you keep the FJ60 case you are going to have a centerd 14B so you have to do a case or build an off set 14 bolt. Just some more stuff to think about.
#17 (permalink) |
Moderator
Member # 8568
Here dude now I am really nurseing you along. I even searched for you
http://www.pirate4x4.com/forum/showt...0&page=1&pp=40
#18 (permalink) |
Member # 36002
LOL check mine out
Check Mine out .... I did a D60 front D70 rear swap ..the D70 rolled right under worked great , the D60 on the other hand was apain moving the mounts out ...If you want I will send you my web link etc with everything on it
Building the Super 60 ...SBC 383 Stroker th400 , NP203/205 . SOA Dana 60 Front Dana 70 Rear .... |
#19 (permalink) | |
Kool Arrow
Member # 13666
PM ME please HOW MUCH AND WHAT STAYIN IN IT>>>>
#20 (permalink) | |
Kool Arrow
Member # 13666
The 44 would be a waste of tim as an upgrade, other than being wider. There's good stuff for the L/C axles which make them stronger than a 44. If you're gonna do all the work, don't fuck around with a 44. Put in a 60. K30s had a perfect donor axle.[/QUOTE] The D44 swap is the same strenth axle BUT is also the same perch width as the d60 so for fabbing the set up it will work till you find the D60 ... remember its also about a1 1-2 shorter than the 60 if mock it all up
#21 (permalink) | |
I'm going 1-ton on my FJ55. This is what I've done / I'm doing:
Maybe someday I'll bob it too, but the storage space is nice if you fill it with people. Morgan
Morgan Fletcher, Oakland, CA - 76 FJ55, 94 FJ80 - TLCA #5973 Ad Astra Per Alia Porci! - [url="http://www.birfield.com/~morgan"]http://www.birfield.com/~morgan[/url] |
#23 (permalink) | |
Discount!
Sorry in advance for being rude, but somtimes it's just gotta be done!
Jeff Fretwell 72 FJ40 67 FJ45 83 Toyota 4x4 LB |
#24 (permalink) |
Member # 6569
I'm with Jeff, I would be stoked to have more options on shafts and to be able to see what breaks instead of a closed knuckle. Also the bad batch of longs is a royal pain for some of my friends. Easier to just avoid, and get junkyard shafts. I still do believe that the og longs are sronger then a 44 with ctm's and warn's. Drop all that coin into a turd front end with the new cromo shiz seems like a waste. I wouldn't feel so strongly if advocates of the turd front end didn't keep comparing them to 60's. When Long claims 40-44 inch tires are fine with the new stuff, is seems stupid. Yota axles will never be 60's and shouldn't be compared.
Team FOH# 321 Thanks to the people making it happen Weathertight,Polyperformance,CTM Racing Products,Levrett Transmission,BFGoodrich Tires,Kickass Offroad,Reid Racing,West Coast Differentials,Wide Open Design |
#25 (permalink) |
Moderator
Member # 8568
Very true, "yota axles will never be 60's and shouldn't be compaired"
Put a 60 stub by a birfield and the differance is insane. I have said it 100s of times, with first hand experence. I ran every after market birfield know to man and I broke them all. Every time I went wheeling I broke at least 1. I swaped to a 60 and have not broke jack shit. Now I can drive the way I want to and not worry about breaking a stupid birf!
