Carb Question? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-18-2005, 07:45 AM   #1 (permalink)
Member # 5389
Send a message via AIM to jnynuke Send a message via Yahoo to jnynuke
Carb Question?
Is anyone running a weber 32/36 on a 2F motor.I have a friend that is selling one pretty cheap so I need some information on it.I did a search allready and some people said they work fine and some say they dont and that I need a 38 for this motor.Its for a desmogged 83 fj60. I have a holly on it right now but I am tired of tuning it all the time and I had a weber before on a VW that ran great.
Before you say go back to stock dont bother. The aftermaket Holly,even with its problems runs so much better than the original ever ran.I also like the extra horsepower.Thanks
"If you cant get there in landcruiser you shouldnt be going"
jnynuke is offline   Reply With Quote
Old 03-18-2005, 09:51 AM   #2 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
I've got a Weber on the shelf right now that I just pulled off of an 83fj60 that went back to a Mark's Off Road modified Aisan carb.
If you really want a weber, you can make me an offer.
Yes it is true that the stock FJ60 carbs seem weak in the HP department compared to the toilet bowl Holleys and Webers. But the Aisan has room for improvement, and already has superior idle, off road and mileage characteristics.
If you're never gonna wheel the rig, then do whatever you want.
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 03-18-2005, 12:39 PM   #3 (permalink)
Member # 1767
Since you've already got the Holley adapter on there, I'd suggest using a Motorcraft 2bbl. It uses the same adapter. They work great and are cheap, plentiful and easy to build. It's what I run on my 2F.
TLCA #8123
Lone Star Land Cruisers - 79 FJ40
JasonH is offline   Reply With Quote
Old 03-18-2005, 01:02 PM   #4 (permalink)
Member # 5389
Is it the 2150 your talking about?They have them new at autozone for 99 with a 30 dollar core charge.Are they easy to adjust and how is the horsepower with it?Thanks
Old 03-18-2005, 01:10 PM   #5 (permalink)
Member # 5389
How did it run with the weber and what model is it?Also how much do you want for it? I can through in my old aisan if you want it. It was running when I pulled it about 2 years ago.
Old 03-21-2005, 08:19 AM   #6 (permalink)
Member # 1767
I think that's the one. Mine is from an early Bronco with a 302. I'd say powerwise it feels a little stronger than the worn out Aisin that was on it. The best thing is that it works so well off road and it starts and idles great. And it was cheap.
TLCA #8123
Old 03-21-2005, 08:40 AM   #7 (permalink)
Member # 13912
The weber 38/38 is a better choice for a 2F than the 32/36. Neither match the cfm of the aisn appropriate for that motor. The 32/36 could be made to work I suppose...I've heard good things about the motorcraft, but have not tried one myself. I trust Jason's view as a "discriminating driver," and he deos wheel his junk, so I'd have to say it works offroad well.
65swb45 has a good rep as a carb guy, so any dealings you have with him should prove successfull for you.
Visit [url]www.tlca.org[/url]; TLCA Member 6235
TLCA Prez Emeritus
chef is offline   Reply With Quote
Old 03-21-2005, 11:38 AM   #8 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
If you're REALLY interested in the Weber, tell me what to look for to tell the difference between the 32 and the 38 cause those things all look the same to me!
Heck ya I'd give you credit for the stocker.
MarksOffRoad.net
tlca #1086
Old 03-21-2005, 11:46 AM   #9 (permalink)
Member # 1282
32/36 will work for a 1F, but is too small for a 2F.
ranger is offline   Reply With Quote
Old 03-21-2005, 11:48 AM   #10 (permalink)
Member # 13912
Hey 65swb45;
38/38 both barrlelare same sized, and both open at the same time. 32/36 will have one barrel smaller than the other, and the small one opens first...
TLCA Prez Emeritus
Old 03-21-2005, 10:37 PM   #11 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
Originally Posted by chef
Hey 65swb45;
That would mean that if it had two sets of gears that meshed like a window regulator, that would be the 38mm right?
MarksOffRoad.net
tlca #1086
Old 03-22-2005, 04:55 AM   #12 (permalink)
Member # 13912
Yep, I believe that to be the case...
TLCA Prez Emeritus
Old 03-23-2005, 10:01 PM   #13 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
Got a pic. I guess it is the 38mm.
MarksOffRoad.net
tlca #1086
Old 03-24-2005, 04:56 PM   #14 (permalink)
Member # 5389
It looks pretty nice.Was the electric choke hooked up on it and if so where was it wired to.I picked up 32/36 really cheap but Ive heard it wont run that good on my truck so the 38 seems like a better option. How much do you want for it?
Old 04-06-2005, 11:48 AM   #15 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
I know we talked, but are you still serious. Thinking about posting this elsewhere. Let me know.
MarksOffRoad.net
tlca #1086
Old 04-06-2005, 03:10 PM   #16 (permalink)
Member # 16085
I had never come across the specs on a Aisin before, but in some FSM I found that the early-mid 70s 2 barrel Aisan carbs were 38/38
2000UZJ100/92FJ80/90FJ62/86FJ60/82FJ40mustard/82FJ40green/78FJ55/67FJ45LBP/65FJ40LV/65FJ45LV/64FJ45LV/87 Chevy 3/4 ton beater
Landpimp is offline   Reply With Quote
Old 04-06-2005, 03:54 PM   #17 (permalink)
Member # 21073
Send a message via AIM to treerootCO
The 38 38 refers to the size in mm of the throttle plates. A 32 36 has one that is 32 and the other is 36.
“He who goes unarmed in paradise had better be sure that that is where he is.”—James Thurber.
treerootCO is offline   Reply With Quote
