Desert Rat
Member # 27432
project: save my sheet
Since everybody else has a name for their projects, I figured I should have one too!
Got the rear bumper done for the 45lwb, now I'm fabbing up some sliders for the back of the bed behind the back tires.Consensus was NOT to drill the sheet on the bed and make a rocker-type slider, but to use some square tube underneath the bed. Last time I was at Faultline, I had Simon weld up a pair of his modular frame anchors on either side of the framerails. Went back this morning and cut a pair of slider tube from some thick wall 2x2 tubing [trailer hitch grade] and angle cut them to match the arch of the wheelwells. Ground the ends and the caps so that Simon could come in and do a quick surgical strike on the welding [Phil, I swear Simon was working on your rig practically the whole time I was there! ]Ground clearance is now down from 22" to 19 & 3/4" Now I am taking a hard look at the suspension. I think next week I will change out my front ProComp 2.5" springs for some of my NHK 4" and trade out the stock rear shackles for some 2.5" from Downey. Prolly have to extend the brake lines for this as well. Seems like a lot of work for one run!
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
Desert Rat
Member # 27432
Oh yeah. If the suspension works out, I will prolly try to fab up a long slider between the front fenders and the rear wheelwells. Again, removable.
Member # 6816
how about callin git the "bumper-car-45"?!
post some pics you hippie. and i know you're not wearing your sandals when you're welding!?
Maybe you outta stick to legos! |
Desert Rat
Member # 27432
Too tired last night from all that barefoot welding and volleyball!
Here's a pic:
Desert Rat
Member # 27432
Installed
Desert Rat
Member # 27432
Thanks Gene. While Simon was figuring out the umpteenth custom gusset for Phil's 40, I took the sliders out to the truck, marked them, and cut them on the chop saw so that the leading edge matches the arch of the wheelwell EXACTLY! In other words, they look even better up close.
Of course since they are straight, they also magnify just how wavy the bed of the truck is! So when do you want to do your bumper?
#10 (permalink) | |
Desert Rat
Member # 27432
Member # 24859
Mark is that thing gonna make an appearance at rubithon , ? I got a funny feeling twiddy is brewing a secret 55 project but have no confirmation .
Mellonhead |
#12 (permalink) | |
Desert Rat
Member # 27432
If I keep the HJ and V-8 it, it will be SOA and set up to follow humbly behind Whitey's 45..................... And pick up all the free camping gear!
#13 (permalink) | |
Member # 22408
#14 (permalink) | |
Desert Rat
Member # 27432
If Georg is following Whitey, you're gonna have to deal with toploader to get to those Fosters!
#16 (permalink) | |
Desert Rat
Member # 27432
Sliders are now fully gusseted, painted and mounted. Time to move on to the suspension! Thanks again Simon!
#17 (permalink) |
Desert Rat
Member # 27432
Post counter is as messed up as the view counter!
#18 (permalink) |
Member # 8725
Damn, that is looking good Mark, keep up the good work (or should I say Simon). Whoever, its looking good.
'72 fj40 4 inch lift, 6 cyl, ps, 4wdisk, sm420, arbs '66 fj45 longbed project, 2F '78 fj40 2f/4spd, 2.5 inch lift |
#20 (permalink) |
Desert Rat
Member # 27432
One quick one shot this afternoon while I was working on the head for the 60:
#22 (permalink) | |
Member # 22259
thanks
78 fj40 350,nv4500,35's 65 fj45 350,sm420,4wdb,35's Alcans 2007 Black FJ Cruiser 1966 M416 -Mike |
#23 (permalink) |
Desert Rat
Member # 27432
slider and bumper:
#24 (permalink) |
Desert Rat
Member # 27432
