3 leaf springs for a 40 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-02-2005, 01:17 AM   #1 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Okay, who happens to remember who made a 3 leaf springpack for a FJ40???
I assume that it is a old lift.
Any ideas?? ride quality??
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 04-02-2005, 02:12 AM   #2 (permalink)
Member # 9639
Send a message via ICQ to Advent Horizon Send a message via AIM to Advent Horizon Send a message via MSN to Advent Horizon Send a message via Yahoo to Advent Horizon
Rancho; bad.
'76 FJ40, "GIR". A bigger money pit than my tuition!
TLCA member #12717
Advent Horizon is offline   Reply With Quote
Old 04-02-2005, 04:00 AM   #3 (permalink)
Member # 507
#s of leafs
I finally ended up with three in each pack from a 2.5 pinnicle lift on a alum 40 body. It has been about 2 years with no problem. Bill
78fj40 alum tub 2.5 lift and lots more
mobiltoy is offline   Reply With Quote
Old 04-02-2005, 07:54 AM   #4 (permalink)
Member # 10067
Originally Posted by Advent Horizon
Rancho; bad.
yeah . what he said. they have all the flex and ride quality of a set of train tracks.
could be the worst springs out there I think.
cheers,
ryan
79 BJ40/42, 87 BJ70, 71 fj40 Parts mound.
seapotato is offline   Reply With Quote
Old 04-02-2005, 08:22 AM   #5 (permalink)
Toploader's Avatar
Member # 16737
Jason, I had a set of "Rugged Trail" 3 leafs in my first 40. You can tell by the orange spring bushings compared to the red ones used by Rancho if there still in the springs.
The best use for these old 3-leaf springs is to fab up a nice monster sized crossbow that can shoot driveshafts through 1/4 inch plate steel.
72 Rockwelled yeah whatever...
All my shits heavy.
Toploader is offline   Reply With Quote
Old 04-02-2005, 08:34 AM   #6 (permalink)
Member # 5286
lol
DEAR MADAM:
Old 04-02-2005, 09:39 AM   #7 (permalink)
upnover's Avatar
Member # 17729
2nd rugged trail.
Just make sure you wear you kidney belt.
wayne
Up and Over Innovations Inc. ------4wd sales,service and fabrications
Rhino Linings of Aston-------#1 spray-on liners
610-358-3179
W.E.Rock team#504 Unlimited http://www.teamupandover.com
upnover is offline   Reply With Quote
Old 04-02-2005, 10:30 AM   #8 (permalink)
ROCK HUGGER's Avatar
Member # 4329
Originally Posted by toploader
Jason,
Mark, I think YOU would be the only one that could shoot that bow.
ROCK HUGGER is offline   Reply With Quote
Old 04-02-2005, 10:53 AM   #9 (permalink)
Toploader's Avatar
Member # 16737
Im not kidding! Im going to build one up and show you guys.
I may use more than one spring for more velocity.
Chopped driveshaft from a duece with the splines sharpened to a point.
All my shits heavy.
Old 04-02-2005, 03:07 PM   #10 (permalink)
Member # 5286
I am going to try them as a mono leaf
DEAR MADAM:
Old 04-02-2005, 08:33 PM   #11 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
I never had problems getting the old 3 leaf Ranchos to flex on my junk because of the weight of all the spare parts and gear in the truck! I actually managed to snap one of the main leafs because of the load I carry on board.
Not as useful for a rock crawling rig as for a long range expedition rig. My .02
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 04-03-2005, 03:53 AM   #12 (permalink)
Member # 34756
Didn't Burbank Spring make 3-leaf springs for 40s?
Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing.
4x4Poet is offline   Reply With Quote
Old 04-03-2005, 10:05 AM   #13 (permalink)
Member # 24859
Jason , if you want em I got a whole set , 3 leaf , 9mm leaf each , I ran em soa on my 40 with 36's and made it thru rubicon 3 times with no issues and just took em off for the new alcans. stiff , yes , work , did for me , worst part was they wasted bushings almost every outing. and they are hell on mounts and shackles , they twist everything pretty good.
Mellonhead
peesalot is offline   Reply With Quote
Old 04-03-2005, 10:28 AM   #14 (permalink)
Member # 29
Thiose are Rancho springs. I have heard they are stiff, but they can be loosned up in tiome. I mean you are in the desert. Slap them under there, and go do some high speed runs through the desert.
Or another thing you can do is use the main leaf, and then swap in some stock parts. Make a sping set that works for you.
Dima
1974 FJ40 in the works
2006 F250 crew cab longbed powerstroke for towing duties
Flatty is offline   Reply With Quote
Old 04-03-2005, 10:59 AM   #15 (permalink)
Member # 5286
Exactly what I was planning amigo
My 72 will not be a rockcrawling rig.. just mild trail stuff..
DEAR MADAM:
Old 04-03-2005, 05:40 PM   #16 (permalink)
rockthedog's Avatar
Member # 19510
rancho............... i have a set as well, i ran them for a long time , about 20 years. so if anyone wants a set that are about as broke in as can be, you can have m'.
77fj40, 1 TON
www.wfoconcepts.com 530-268-9494
tlca# 12281
semi_budget 1ton build
/forum/toyota-land-cruiser/530636-semi-budget-1-ton-buildup-thread.html
linking the rear
http://www.pirate4x4.com/forum/toyot...king-rear.html
rockthedog is offline   Reply With Quote
