Spool? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-27-2005, 07:15 AM   #1 (permalink)
Member # 4286
Spool?
Does anyone make a spool for a 73 cruiser? I need a locker that comes with its own carrier because mine is not useable being we welded it up. If no one makes one i will just go with a detroit.
jssena is offline   Reply With Quote
Old 05-27-2005, 07:54 AM   #2 (permalink)
Member # 11492
Send a message via AIM to CaverInaCruiser
Nope.
-James H
-76FJ40 HiPo2FSM420OMELockRite35's
"You're the guy from the Hamburger train, right?"
CaverInaCruiser is offline   Reply With Quote
Old 05-27-2005, 09:36 AM   #3 (permalink)
Eskimo's Avatar
Member # 10429
sounds like you've already got a spool then...
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is online now   Reply With Quote
Old 05-27-2005, 01:15 PM   #4 (permalink)
Member # 4286
Yea i did. Until it broke again. This has happened 2 times to different carriers. Both were welded up and only lasted a little while. We'll it looks like detroit is what i will be going to. Have you ever seen a good used detroit for sale ever? Maybe someone will chime in with one
Old 05-27-2005, 04:13 PM   #5 (permalink)
Member # 5767
Send a message via Yahoo to ginericfj80
Check With Texican. I seem to recall he used a Chevy application one. You might do a search for spool and Texican?
Eric V. 99 built UZJ100 FJ68 Project 74 FJ15 www.WildWildWestArt.com
ginericfj80 is offline   Reply With Quote
Old 05-27-2005, 04:17 PM   #6 (permalink)
Member # 5767
I guess it was W
http://www.pirate4x4.com/forum/showt...=texican+spool
Old 05-27-2005, 07:29 PM   #7 (permalink)
Member # 15396
Send a message via AIM to smtyblt
Give Lance a call at Iron-Pig Offroad. I just installed one from him, actually not a PIA at all installed it in 30 minutes. make that an 60 minutes because I already had it apart.
[SIZE=4]Don't sing it Bring it[/SIZE]
smtyblt is offline   Reply With Quote
Old 05-27-2005, 11:45 PM   #8 (permalink)
Member # 45843
I asked the same thing on mud a while ago
http://forum.ih8mud.com/showthread.php?t=34282
here is W's site
[url]www.4x4him.com[/url]
weak-link is offline   Reply With Quote
Old 05-28-2005, 04:20 AM   #9 (permalink)
Member # 35982
ARB comes with own carrier.
If you want to go welded, a trick is not to weld, but go to a foundry and get them to fill it with aluminium. Takes the pressure off one or two teeth, plus has a little 'give' in it.
andrewfarmer is offline   Reply With Quote
Old 05-28-2005, 09:22 AM   #10 (permalink)
Member # 45843
fill it? how do you get your c-clips out
Old 05-28-2005, 10:26 PM   #11 (permalink)
Member # 35982
Oops! - I'm running full floater - forgot about the C clips - you could probably blank out enough room to fit/remove them...
