Member # 8926
2F side cover leak
I replaced my side cover gasket yesterday after work, it was leaking above the fuel pump, Now.... it still leaks!
Just along the bottom between the fuel pump and the distributor! I didn't use any RTV should I have? It's a cork gasket from Napa. I cleaned the cover real well and the block. No warps or bends in the cover either. Help. Thanks, Mike
1971 (body at least) FJ55 - 2F, '78 axle & 4 spd w/3 spd T/C 2.5" inch lift, 31X10.5 MT.... yadda yadda yadda "It's not stupid... it's advanced..." |
#2 (permalink) | |
Re: 2F side cover leak
RockZombie:68FJ40 LPG350/sm420/d300/d60/d70 |
Member # 39
I use Toyota FPIG (black) instead of RTV on anything that requires a gasket on the engine. It is more expensive than RTV, but it has always worked for me.
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank |
Member # 582
I allways use a gasket adhesive/sealand on one side of cork gaskets (and others) then adhere the gasket to the removable part and let set.
Wipe a thin coat of oil on the other side and torque it down. Allows you to re-use the gasket a few times if you need to remove the cover. Old British biker trick Cory
FJ-40 HP 2F SM420, 4:88, Locked F&R, 98" WB, Sawsalled, Welded, dented, 36" SX's, 3spd gears in a 4 spd case, Newfields, Lots of other mods all done by Me... Towed to the trail with a 97 Crew cab 4X4 PSD (slightly improved) |
