Kool Arrow
Member # 13666
what GM tilt colum
what colum are you guys using I'm lookin at a 82 sub for a motor swap and well its got a tilt colum in it ... is it too long ...I know welder fixes all but is this even the right thing to start with .... i searched but didnt find what people pulled theres out of or any good pics of the firewall mods...
thanx in advanced Joel |
Member # 6957
mines from a pontiac. i used the factory gm mount and cut the "ears" off. i then took the stock cruier and cut those "ears" off cause there oval hole and thus more adjustment. i welded the toy "ears" to the chevy mount. hard to explain and i'll get some pics for you this weekend if yoiu want.
#3 (permalink) | |
Kool Arrow
Member # 13666
no i understand how long is the whole colum and pics would be great ... anyone else |
Member # 24876
my buddy has one from ididit.com its polished bling (around 400 buck( it's from i think a 56 chevy replacement dealy...
another buddy has one from a bitchin' camaro... (junk yard, i think he said 75 bucks)
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR] |
Member # 12349
Floor shift Cherokee......search there are pix here of one I did......it's a GM column BTW
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
Member # 263
I can't answer your question directly, but then neither did anyone else.
Check out this page, it should help some: http://www.flamingriver.com/p_view_i...tem_design.jpg You could also call thier tech line and ask questions. Also, take measurements of your existing column and compare them to the truck column. You'll probably find your answer. Phil
1966 FJ45 LPB-1973 FJ40- KR6AWL MTA 4x4 - San Jose, CA Last edited by PJohnson; 08-16-2005 at 08:09 AM. |
Member # 25622
I dont know about the suburban column, but I ran into a similar issue with the camero/ firebird column I used. Took some minor fab work to get right, but it wasnt a big deal. I got mine from a mid 80's car, stick shift, tilt column. I trimmed the plastic housing down a tad to shorted the distance between the steering wheel and the dash (wish I hadn't done that, but oh well cause it put the steering wheel kinda too far away from the seat...), and also shortened the shaft that comes into the engine bay to clear my motor. I was able to slide a splinned shaft into the part I cut down on the engine bay side, and weded that onto the column. Again, not a big deal. This is deffinitely not a flaming river column, but was alot cheaper, and has all worked and looked decent for many many years now.
-Dustin
4Runner/ 325i / crf 50 / ttr 125 / wrf 450 / V-Star 650 Last edited by Rockzar; 08-17-2005 at 04:30 PM. |
#12 (permalink) |
Member # 12349
[QUOTE=kling-on
thats a little BLING for me ... but I will ck mine to the Sub one and probley make it work cause its what I got and this is a cheap ass build up [/QUOTE]Look this over good, cheap ass caught my attention, course you could have searched and found this on your own http://www.pirate4x4.com/forum/showt...ht=tilt+column
#13 (permalink) | |
Kool Arrow
Member # 13666
so i need to add lazy ass to cheap ass thanx guys that what I was wanting to see... you know butch I did search but that one didnt come up I guess I had something different on mine
#14 (permalink) |
Discount!
Holy shit........ I can't beleive nobody gave you any decent options out of that thread! Well I guess there were a couple ok ideas.. here's what I know:
GM Caddy 70's- mid 80's telescopic/tilt early 70's to late 70's Cameros, El Caminos, Chevelles, Novas, Etc.... Even 70's thru 80's GM trucks will fit with minimal modifactions. I would guess that even Ford and Chrysler products would work just as well, but I'm just not sure because I never have even bothered to check with any of them. I always seem to find what I need with GM Products.
Jeff Fretwell 72 FJ40 67 FJ45 83 Toyota 4x4 LB |
#15 (permalink) | |
Member # 25622
They are shaweet for a Cruiser. ![]() Dustin
4Runner/ 325i / crf 50 / ttr 125 / wrf 450 / V-Star 650 |
