The day before your F-ed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-26-2005, 10:43 AM   #1 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
Took LandCruiserJunky's rear axles out on Wednesday to replace the axle seals and found this little gem just about to blow inside. We've all heard the stories about center pins that had to be beaten out of the carrier. I've had 3 that I've had to get out that way come thru the shop over the years. This is the first time I got to see one basically just before the damage.
the warning sign: when you can rock the tire back and forth with the cover just removed and you can see the oil squeezing out either side of the center pin because the hole in the carrier is going oblong. This is what is putting the stress on the pin that causes the bolt to shear. SOoooo, if you see that your carrier is, shall we say LESS THAN PERFECT, buy yourself some cheap insurance and put in a fresh bolt!
In the photo, at the top of the pin, midsection, just above where the shiny part ends, you can see the crack in the pin. By the time this truck came back from the 45 run, it would have been F-ed. Pheewwwh!
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 08-26-2005, 10:50 AM   #2 (permalink)
orangefj45's Avatar
Member # 6816
yup, that would have sucked big time!
Maybe you outta stick to legos!
orangefj45 is offline   Reply With Quote
Old 08-26-2005, 11:00 AM   #3 (permalink)
Member # 24859
hey , thats not a carb. part . How'd ya get Mark to work on that ?
Mellonhead
peesalot is offline   Reply With Quote
Old 08-26-2005, 11:39 AM   #4 (permalink)
Discount!
dog walker's Avatar
Member # 156
Send a message via ICQ to dog walker
Hey, now thats kinda funny! I actually smerked a bit!
Jeff Fretwell
72 FJ40
67 FJ45
83 Toyota 4x4 LB
dog walker is offline   Reply With Quote
Old 08-26-2005, 11:43 AM   #5 (permalink)
cruiseroutfit's Avatar
Member # 1858
Wow, good tech.. never seen one "about" to break... good eye Mark!
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 08-26-2005, 11:52 AM   #6 (permalink)
Member # 23362
Send a message via AIM to bustanutley
I've had one break, it sucked hard, broke the carier to get the cross shaft out and take the axle apart. Good catch
FJ40
bustanutley is offline   Reply With Quote
Old 08-26-2005, 12:17 PM   #7 (permalink)
Pygpen's Avatar
Member # 8384
Mine was broke on my 75 40 when i got it, but I did not beat the pin out (although I was tempted). I got a tiny easyout with fine threads and drilled the pin. Came right out, easy-peasy. I replaced the pin and put in a lock-right and 35" tires..... I've barely looked at it in 7 or 8 years and about 20K hard miles.
PMK
When the going gets Weird, the Weird turn Pro
Benicia, Ca.
My Cruisers
PMK
Pygpen is offline   Reply With Quote
