Front disc conversions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-26-2005, 08:24 PM   #1 (permalink)
Member # 26018
Does anyone know if the mini-truck front disc conversion is a better way to go (stronger) than using a newer l/c front axle with disc brakes?
Thanks
Fman is offline   Reply With Quote
Old 08-26-2005, 08:25 PM   #2 (permalink)
orangefj45's Avatar
Member # 6816
yup, wider stud pattern, do a search on this one as well you newbie fawker!
Maybe you outta stick to legos!
orangefj45 is offline   Reply With Quote
Old 08-26-2005, 08:34 PM   #3 (permalink)
Member # 48115
Send a message via AIM to my64fj40
Don't worry it took me a while to use search too.
my64fj40 is offline   Reply With Quote
Old 08-26-2005, 08:51 PM   #4 (permalink)
Pygpen's Avatar
Member # 8384
I gotsta disagree wid ya bro......
The late model LC stuff uses the same stud pattern as the mini truck stuff but has the better vented disks! That why I'm using FJ60 outers on my 55 disk brake conversion. I'll need all the brakes I can get to stop the big pig!
Avoid the bastard years of the LC disk brakes 75 thru 77, those are the ones Georg is thinking of, and they are weaker.
PMK
When the going gets Weird, the Weird turn Pro
Benicia, Ca.
My Cruisers
PMK
Pygpen is offline   Reply With Quote
Old 08-26-2005, 09:15 PM   #5 (permalink)
Member # 24859
Pat , stretch that to 75 thru 79 to avoid the bastard disc birf as well.
Mellonhead
peesalot is offline   Reply With Quote
Old 08-26-2005, 09:29 PM   #6 (permalink)
Pygpen's Avatar
Member # 8384
I wasn't fully sure on the years of that bastard crap, I knew it was late 75 because my 4/75 cruiser was drums, and it lasted a couple years, up to when the mini truck came out in 79 I think. If you get 60, or 62 series outers, you'll be Okay..... big pattern knuckles, common birfs, and vented disks.
PMK
Benicia, Ca.
My Cruisers
PMK
Old 08-27-2005, 12:15 AM   #7 (permalink)
orangefj45's Avatar
Member # 6816
minitruck with vented rotors from the 4 runner and you're golden. no years to worry about.
and don't listen to mellonhead, that fawker thinks drums and course birfs are the shit!
Old 09-17-2005, 04:55 PM   #8 (permalink)
Blow-In's Avatar
Member # 46734
Bumped this to find when doing this conversion what to do with the tie rod,do the mini truck TRE have the same thread as 45s?
[url=http://www.pirate4x4.com/forum/showthread.php?t=550810]86 TRUGGY BUILD[/url]
[url=http://www.myspace.com/trailtoys ]MY SPACE[/url]
If Rocks Had Pussy`s Our Lives Would Be Perfect!!!...
Blow-In is offline   Reply With Quote
Old 09-17-2005, 05:04 PM   #9 (permalink)
Member # 22408
Post a larger version of your avatar and you'll get an answer (from someone!)
Rat70FJ is offline   Reply With Quote
Old 09-17-2005, 05:21 PM   #10 (permalink)
Blow-In's Avatar
Member # 46734
so what i got is the last model that had drums front end in my 45s and I`ve got a complete front end from a 84 4runner including the tie rod,I also have a prop valve and a 80s master cylinder for when i was doing the rear disks on my 4runner and one more thing is it hard to replace the booster with the mini truck type?
Old 09-17-2005, 10:30 PM   #11 (permalink)
peiserg's Avatar
Member # 9598
i've got the MAF front discs and they work pretty well. nice kit, totally complete, but about $800 i think
Posted by Mantis:
I STILL can't fathom what she was thinking... "Gee, I'm high bidder on one stroller, better bid on another. Horray! I'm high bidder on that one too! Gee this is fun, better bid on another."
peiserg is offline   Reply With Quote
Old 09-18-2005, 01:30 PM   #12 (permalink)
cruiseroutfit's Avatar
Member # 1858
Couple of options...
Get 79'-84' stock FJ40 arms and use your stock tie rod. $$
Get tapered shims and use your stock tie rod. $
Use a cut & re-tapped FJ60 steering setup... $$
New parts.. $$$
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 09-18-2005, 03:35 PM   #13 (permalink)
Member # 22408
Kurt,
I think he's got an 81 fj45. Won't that have the correct arms?
Old 09-18-2005, 03:54 PM   #14 (permalink)
Member # 1858
Kurt,
It should per US specs, but I am not 100% sure in the case of late model OEM drum fronts such as his... they might have continued to use the smaller pattern, a pic might help
Here are the measurments:
http://www.cruiseroutfitters.com/tech_front_axle.html
Kurt Williams
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Mountain Yoats
Mojave Underground
Old 09-18-2005, 10:29 PM   #15 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Only runners that were vented were IFS and the disks were the wrong spacing.
You need IFS V6 calipers and Cruiser rotors for the correct spacing...
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 09-19-2005, 01:37 AM   #16 (permalink)
Blow-In's Avatar
Member # 46734
Yeah ,disks didn`t come out till 82
are these the inserts?
Old 09-19-2005, 01:42 AM   #17 (permalink)
Blow-In's Avatar
Member # 46734
Yeah IFS rotors are to small on the OD,I can use the 1st and 2nd gen MT set up or our 3rd gen had the thicker vented rotors
