1966 FJ40 build-up - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2007, 08:11 AM   #151 (permalink)
Member # 1767
Originally Posted by swilson View Post
My 2nd daughter was born Jan 19.
Congrats!
Awesome build.
TLCA #8123
Lone Star Land Cruisers - 79 FJ40
JasonH is offline   Reply With Quote
Old 02-05-2007, 10:00 AM   #152 (permalink)
lurker
swilson's Avatar
Member # 143
I can't find the receipt for it... and I bought it nearly 2 years ago. Its been sitting on the shelf waiting to be installed.
I got it from Santa Clara Truck Wreckers (408) 727-2244.
The other cool thing about it I forgot to mention.... you don't need to cut the reinforcement off the firewall on the late model cruisers to make room for a vacuum booster... or have to run any adapter to space a vacuum booster off the firewall. I did make a cut through the reinforcement to clear a hydraulic line, but I went way overboard and will be welding it back up. It really only needed a cut the size of a fingernail to clear the hydraulic line. Other than that the hydroboost setup clears the reinforcement rib.
Scott Wilson - Member #143 - TLCA #5261 - 1966 FJ40 - Click for Build-up thread
swilson is offline   Reply With Quote
Old 02-05-2007, 10:01 AM   #153 (permalink)
lurker
swilson's Avatar
Member # 143
Originally Posted by JasonH View Post
Congrats!
Awesome build.
Thanks! Now if she'd only let us sleep through the night... sigh.
Old 02-06-2007, 11:27 PM   #154 (permalink)
lurker
swilson's Avatar
Member # 143
Got my dash finished up, minus the wiring of course. The aluminum plate was inspired by the one Jack Rice made for his truggy. It won't stay aluminum color, it'll be painted or powder coated. I filled all holes including the ash tray hole.
I didn't realize I was going 40 MPH... hmmm.
Old 02-07-2007, 12:58 AM   #155 (permalink)
Desert Rat
65SWB45's Avatar
Member # 27432
Scott, something about my size 13 feet made me cringe when I saw the placement of your gas pedal. That looks even tighter than the stock location. What was your motivation for putting it there
...............other than making sure I never steal your truck!
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 02-07-2007, 09:36 AM   #156 (permalink)
lurker
swilson's Avatar
Member # 143
All I can say is, pedal placement is still evolving
Old 02-07-2007, 01:58 PM   #157 (permalink)
mudtoy67's Avatar
Member # 30359
I love your build. The detail is amazing!
I must admit...I'm going to steal your dash.
The idea that is
BDR
67 FJ40 "Last Minute" - build thread
97 XJ
Texan. Saved my neck twice... once after he was dead.
mudtoy67 is offline   Reply With Quote
Old 02-07-2007, 02:42 PM   #158 (permalink)
Member # 852
I'm surprised you haven't put a Can-Back topper and swilson-bilt custom tire carrier on it yet...slacker!
Hi Scott!
Jim Brink
Ann Arbor, MI
ToyTech is offline   Reply With Quote
Old 02-07-2007, 03:12 PM   #159 (permalink)
lurker
swilson's Avatar
Member # 143
Hi Scott!
Holy smokes, its Jim Brink! And you're on the wrong side of the country now! And you wheel a.... RAV4? PM on the way
Old 02-07-2007, 03:14 PM   #160 (permalink)
lurker
swilson's Avatar
Member # 143
Hey thanks for the comments. Its yours for the stealing... 'specially since I ripped it off from Jack's truggy.
Old 02-07-2007, 04:02 PM   #161 (permalink)
NORCALFJ40's Avatar
Member # 51625
Looks great Scott! very nice work on the bezel!
NORCALFJ40 is offline   Reply With Quote
Old 02-07-2007, 07:11 PM   #162 (permalink)
Member # 64594
nice job scott! Ive been following your build for awile. I also have a 66 fj 40. can you pm me w/ a contact # I wanted to pick your brain about your hydroboost set up and stuff. Your instrument panel is killer.. Is that an overlay you bolted on or welded? Did you make or buy it? Anyway, thanks for the inspriation you do nice work.
SCALLYWAG99 is offline   Reply With Quote
Old 02-07-2007, 08:10 PM   #163 (permalink)
smokd's Avatar
Member # 26329
Nice work! Where did you find that tailgate?
If you have thin skin, thicken it. Sarcasm is the breakfast of champions........................BITCH!
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both" - Benjamin Franklin
KJ6NQX
DDJC
smokd is offline   Reply With Quote
Old 02-07-2007, 10:33 PM   #164 (permalink)
lurker
swilson's Avatar
Member # 143
Thanks. Its bolted on. I made it. Started with posterboard, transferred that to steel, then decided I wanted it thicker... so I got a sheet of aluminum. Once it was cut out I put a radius around the edge using a flap disc on an angle grinder, then a file, and finished it up with a dremmel with a sanding drum.
I'll PM you about the hydroboost.
Its made by Aqualu (http://www.aqualu.com), I sourced mine from Rocky Mountain Cruisers (http://www.rockymountaincruisers.com).
Old 02-08-2007, 08:21 PM   #165 (permalink)
freds40's Avatar
Member # 14437
Nice build. It's nice to see ya putting in the time on cleaning up all the little things. Makes me think of all the little things I bi-passed so I could wheel. Now I need to spend a TON of time to clean up my build.
Marlin Crawler Sales
www.marlincrawler.com
559-252-7295
brendan@marlincrawler.com
freds40 is offline   Reply With Quote
Old 02-09-2007, 12:15 AM   #166 (permalink)
lurker
swilson's Avatar
Member # 143
Here's what the new hydroboost bolt pattern looks like beside stock master cylinder bolt pattern (same as the clutch MC bolt pattern)
Boy did I goof when I cut the rib on the firewall. Tonight I welded the piece back in and with only a slight bend in the firewall rib it cleared the hydraulic line.
Old 02-09-2007, 02:54 AM   #167 (permalink)
Member # 12758
if it helps, good cheap source of hydroboost these days is out of some "M" series GM vans, astros, Safaris, etc. Setup looks almost identical to your power stroke. I got mine for $40 at pick n pull, seems hydroboosters seldom fail as far as I can tell...
dieselcruiserhead is offline   Reply With Quote
Old 02-09-2007, 06:19 PM   #168 (permalink)
Gunmetalcruz's Avatar
Member # 6569
Looks great, I wouldn't give up the ash tray on mine. I love it for holding extra valve cores and fuses.
Team FOH# 321
Thanks to the people making it happen
Weathertight,Polyperformance,CTM Racing Products,Levrett Transmission,BFGoodrich Tires,Kickass Offroad,Reid Racing,West Coast Differentials,Wide Open Design
Gunmetalcruz is offline   Reply With Quote
Old 02-09-2007, 11:37 PM   #169 (permalink)
lurker
swilson's Avatar
Member # 143
Mounted the PS cooler today.
This was a big moment for me... I've actually never seen this cruiser with the windshield and hood on since I bought it in pieces. I'll have to work on aligning the panels a bit more tomorrow.
And yes... the cage in back is a hint of things to come I liked the back half of the cage that came with my FJ40, but the front half didn't cut it. I bought a Metal Tech front cage kit and will be putting it on the back half of my existing cage.
Old 02-10-2007, 09:33 PM   #170 (permalink)
OnTheSpot's Avatar
Member # 34900
Why did you build the grill hoop so much lower than the radiator? I would be worried about it getting squished in a rollover or something.
Oh and that dash is sick!!!!
Applying the Beef Treatment
OnTheSpot is offline   Reply With Quote
Old 02-10-2007, 10:26 PM   #171 (permalink)
lurker
swilson's Avatar
Member # 143
The radiator hoop isn't done. I couldn't finish the top hoop until the hood was on... and the hood just went on yesterday.
Thanks
Old 02-10-2007, 11:14 PM   #172 (permalink)
lurker
swilson's Avatar
Member # 143
Battery trays went in today. Welded 'em into the Metal Tech Fenders. Blue Torch Fab makes some cool stuff.
Minor update on the 28 gallon Aussie tank. Modified the filler spout to fit. The instructions claim its as easy as cutting the stock filler shorter and rotating it a bit. Ha! The reality was I had to cut the end of the stock filler 3/8" shorter, lengthen it 1/2" (be welding in some new tubing) before the bend, and rotate it.
Not a huge deal... but if you're installing this tank, don't expect the filler to be an easy install.
Old 02-10-2007, 11:52 PM   #173 (permalink)
Member # 16589
Amazing build....would love the chance to bend up such a clean build....thought I'd throw a killer company out there for your rubber intake hoses http://store.airflo.com/rubber-hoses---clamps.html
Towner is offline   Reply With Quote
Old 02-11-2007, 06:48 AM   #174 (permalink)
Newbie
Tack's Avatar
Member # 31075
Good job man , your pics give idea for me !!
Tack is offline   Reply With Quote
Old 02-11-2007, 09:45 PM   #175 (permalink)
lurker
swilson's Avatar
Member # 143
Worked on the cage today. Spent hours with the grinder removing the welds from where I removed the front half of the cage.
Then I welded in some sheetmetal boxes I made for the corners. Each box will hold a 6x9" speaker and a 2" round LED light. The front of the cage will have a box housing 2 more 6x9s and two more LED lights.
