Help Needed Fj60 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2006, 08:38 PM   #1 (permalink)
Member # 34890
Send a message via AIM to confusedxj
Help Needed Fj60
Heres the deal
I recently swaped into my Zuk 83 FJ60 Axles. First Came the lockers. I am now installing 5.29 yukon gears. Problem is the ring gear is wide, so wide i cant get the center pin in AND i cant get the locker peices in to the differential. SO im stuck between a rock and a hard spot.
Does anyone know if theres a C-clip eliminator kit for this axle? or a solution to my issues (besides ordering a better locker)
Thanks!!!!!
confusedxj is offline   Reply With Quote
Old 05-29-2006, 08:46 PM   #2 (permalink)
Member # 3942
Did you try grinding a couple of gear teeth down? It's pretty common when fitting in an ARB with 4.88's or 5.29's.
60seriesguy is offline   Reply With Quote
Old 05-29-2006, 08:57 PM   #3 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
Yep, grinding 2 teeth a bit is the solution. I have had to do it to all my cruiser rear axles. 5.29 is actually a fair amount to make it clear.
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place.
2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th
2010 KOH Team CrossedUp Mike Klensin and Justin Reece.
2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH.
TLCA# 5305
RustyNailJustin is offline   Reply With Quote
Old 05-29-2006, 09:03 PM   #4 (permalink)
Member # 34890
Anytips on the locker halfs? i mean i know i can assemble the locker inside the carrier before the ring gear BUT i cant remember if the cclips have to go in before the center to halfs of the locker.
Old 05-29-2006, 09:14 PM   #5 (permalink)
Moderator
Member # 8568
I am assuming you are instaling a lockright,aussie,or easy locker?
You have to install the side gear pieces, set the C clips then install the center pieces one at a time, then center pin
TLCA# 5305
Old 05-29-2006, 09:30 PM   #6 (permalink)
Member # 34890
and there lys the problem... the center peices have to go in before the ring gear due to its massiveness. is there a way to get the clips iin after the cneter pieces? i mean i took them out somehow with only taking out the springs.
Old 05-29-2006, 09:39 PM   #7 (permalink)
Moderator
Member # 8568
Still assuming lockright?
put both side gears in and set the C clip on just one side I think its the left side you do first, there is a notch in the inner gear to drop in the C Clip after its instaled. You have to do it in a very specific order on those or it wont work.
Do you know the notch I am talking about? the gap with no teeth.
TLCA# 5305
Old 05-29-2006, 09:54 PM   #8 (permalink)
Moderator
Member # 8568
Here, figure 5 is what I am talkng about.
http://www.4lo.com/94jeep/lock-right...1000703MIB.pdf
TLCA# 5305
Old 06-02-2006, 04:18 AM   #9 (permalink)
Member # 34890
Thanks Guys. Gears AND Locker is in. samurai is crawlin at 103 to 1!
Old 06-02-2006, 07:13 AM   #10 (permalink)
181
LCOwner's Avatar
Member # 181
Post pics. I'd like to see a sammy on FJ60 axles.
Team Member: G-Man Racing #213
LCOwner is offline   Reply With Quote
Old 06-02-2006, 08:59 PM   #11 (permalink)
Member # 34890
here you go, heres some pics from 2 weeks ago, i have 36 IROKS on 10" MRW Beadlocks commin, they should be here tuesday
Before the axle swap
before the paint
