Wait this ain't Tx..
Rear 60 question
I found a d60 that someone has laying around and I have a few questions. Right now all I know is it is out of a 3/4 ton ford and it is a high pinion 44 front and a d60 rear and that they are only a few inches wider than a wranger.
I'll try to find out the year and what not to see if its worth it or not. I'm hoping the d44 is driver side drop so I can sell it to my brother with a family discount (+$100) I will still be running my front cruiser ax;e still and want to keep my 6 lug rims w/ beadlocks, so i've been searching and I can't find anywhere to get the d60 from 8 lug to 6. I keep finding stuff to convert a front d60 to 6 lug so it must be possible. Who does it? Anyone know anything about the axle with the info I have so far? Also, what is the width of a '69 cruiser axle?
"There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter." -Ernest Hemingway '69 FJ-40 - under construction |
#4 (permalink) | |
I'll also probably have to install disc brakes to clear the 15" wheels too.
"There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter." -Ernest Hemingway '69 FJ-40 - under construction Last edited by TxCruzr; 07-12-2006 at 09:04 PM. |
#5 (permalink) | |
Got some more info on the dana60.
never done it, but you switch it from full floater to semi using 9" axle big bearing ends and custom shafts.. so basically it becomes similar to a 9" rear or toyota 8" axle but w/ the dana 60 pumpkin
'65 fj45 Last edited by peterfj40; 07-13-2006 at 11:38 AM. |
So is it really worth it then? Seems like I would be spending more money to down grade it. I figured there were shafts that were 6 lug instead of 8 lug, isn't that what you would do with like a 9"?
Going to an auto with a different t-case = need center diff.
On a FF rear axle the hubs have the lug studs, not the shafts. The shafts are independant of the WMS
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
Old Rock Doc
Member # 915
Follow Peesalot's advice. Here is a direct link.
http://www.geartechhd.com/gallery/di...?album=2&pos=0 and a picture of the new hubs.
Got Rice? Last edited by Medusa; 07-13-2006 at 01:03 PM. |
#12 (permalink) |
If you need a centered diff your best bet is the hybrid axle. By far the strongest, cheapest setup you're going to get. You'll be able to build the whole axle cheaper than just the 6 lug hubs will cost, and you won't need a special jig to narrow it.
But if you're going to the trouble of centering it, I'd do it with an IFS rear to gain 3" of width, and put the IFS hubs on the front axle too.
'76 FJ40, "GIR". A bigger money pit than my tuition! TLCA member #12717 |
#13 (permalink) |
Member # 48807
I'm running a rear ford dana 60 from a 1970 camper special, 8 lug full floater, with 63" wms. the above hubs will work to convert them to 6 lug.
Jeeps are cool... BARBIE HAS ONE! |
#14 (permalink) | |
I'm currently running 3" spacers so that puts me at a WMS of 61". If it is really 66", thats 5" more than what I'm at, thats kinda crazy. If its 63" that'll be fine. I'll try to dig some info up on it. I have looked at Proffitts mini/cruiser hybrid and it is rather reasonable, specially since I already have the 3rd to shove in there. The only thing is that I want to be able to hammer on this thing all day and not have to think about the rear end falling out. But with a bigger cruiser pinion and later down the road some bling mini shafts, maybe it will be bullet proof? Whats the comparison of a mini axle shaft, a 9"?
#15 (permalink) |
Member # 6569
60 rear bore the spindles, 35 spline shafts, 35 spline spool or arb if you can swing it. Upgrade to a front 60 when you can. Run 8 lug and 6 lug till all 8 on all corners. Never compare 60's to yota crap. You can only polish a turd so much before turd don't float uphill. You can 5 bolt,cromo ALL DAY LONG, but in the end you wuill wish you went 8 lug 60's and let m eat. Chip away at it. Having toyoata stuff insures that you like to wrench on the trail. 60 good odds you won't have to touch them. Now that I have the yota people fired up, rant off
Team FOH# 321 Thanks to the people making it happen Weathertight,Polyperformance,CTM Racing Products,Levrett Transmission,BFGoodrich Tires,Kickass Offroad,Reid Racing,West Coast Differentials,Wide Open Design |
#17 (permalink) | |
I talked to Doug at extreme axle and he gave me some options but it really starts jacking the price up quick. I just happened to fall on this axle and was trying to see if it would work. Just trying to slowly collect parts right now. Also been looking at the ford 9" but it seems like I'd run into the same thing as the d60 but with less strength. Such a pain
#18 (permalink) |
Member # 1700
the ford d60 is not worth it in my opinion. that is unless you are planning on throwing money at it. it will come with the 30 spline shafts and be significantly wider than your cruiser front axle. you also know that it will have 8 lugs and that would have to be addressed.
i say find a centered taco rear axle or even a t100 (depending on desired width)and run that. money wise it just makes sense. the only real thing to worry about then is matching the gear ratio's. just my op.
High5 IT'S 1TON O' FUN! |
#19 (permalink) | |
I wouldn't consider a stock D60 to be stronger than a stock 9" by much. A slightly larger ring gear yes, put the 9" has better pinion support and 31 spl shafts.
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger |
#20 (permalink) | |
